Miles After Gas Light Thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoman101, Nov 2, 2009.
  1. Sep 9, 2019 at 2:49 AM
    Phessor
    Phessor Well-Known Member
    I didn't think I had one till the other day when my gauge went below "E", then I got a light.
    Thatbassguy likes this.
  2. Sep 5, 2020 at 9:23 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    close call today, VERY CLOSE
    i had it timed right once the light came on to make it into town and fuel up, i did have a gallon back in the bed because i was way out west in the rural sandhills and you just never know... might not be any place for 40 miles around!
    its the most gallons ever i put into the tank in one shot
  3. Sep 5, 2020 at 9:26 PM
    Tacoma1997White4x4
    Tacoma1997White4x4 America First
    West Covina, California
    1997 white 4x4 auto 4cylinder Singlecab, 2001 auto rwd 2.4l single cab flatbed
    Km3’s 31’s,Lift,Sliders,rear ARB air locker,on board air, armor, hi shell
    I dont have a gas light, just wen the line hits the bottom line ik ive used up 15 gallons and 3 gallons are left, I get 15 in the city mpg wise
  4. Sep 5, 2020 at 9:30 PM
    Wulf
    rock raisin
  5. Sep 5, 2020 at 10:47 PM
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    Speaking of gas light I have an 03 my ligth ever turn on those anyone here with same year rig that as a working light on low gas ? I do have the little gas pump on my cluster but never lights :confused:up
  6. Sep 5, 2020 at 11:01 PM
    rocky_mountain_dave
    rocky_mountain_dave Well-Known Member
    David
    2009 Tacoma Access Cab 4x4 4cyl 5spd
    2.4 liter 6 cylinder?
  7. Sep 5, 2020 at 11:12 PM
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    Light comes on almost below E. For my truck. Have you let it gone below E?
  8. Sep 6, 2020 at 6:39 AM
    wesb1023
    wesb1023 Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    Mine comes on with close to 2 gallons left. I’ve driven 40 miles after it first came on before, but try not to do that anymore. Once it comes on solid, and doesn’t turn off when you hit the brake and slosh the gas around in the tank, you’ve got around 1.5 gallons left. I’ve ran out twice, filled up both times, my factory tank holds 18.5 gallons on the money.
    I have since expanded my fuel system with two air tanks welded together that siphon back and forth with the factory tank. My truck now holds 32 gallons. The fuel mileage is still terrible, but being able to drive over 500 miles between fill ups makes me “feel” like I’m getting good mileage. Haha! I use my scan gauge religiously now, and update my fill up every time. The miles to empty on the scan gauge is very accurate this way.
    cruiserguy likes this.
  9. Sep 6, 2020 at 6:56 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Why would it suck up dirt only when it was low? It's the same dirt that was there right along. As far as cooling the pump if the truck is still running the pump is being cooled. The fuel goes right through the pump motor and all that is what cools it. The pump is capable of delivering nearly twice the fuel the truck uses the rest is returned to the tank so it's a loop until the truck comes to a hult for lack of fuel.
  10. Sep 6, 2020 at 7:15 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I found out when the truck hits 150miles I am out of Gas . What a surprise the first time quite embarrassing to be fair it was the first day I owned the truck
    So I now fill up at around 100 miles no more running out of gas .
  11. Sep 6, 2020 at 7:44 AM
    mcl77
    mcl77 Well-Known Member
    ive gone 35 miles in my 2003 after the gas light was fully on. never ran out of gas though. so not sure how long you can go without running out.
  12. Sep 6, 2020 at 10:49 AM
    skeezix
    skeezix Ol' Geezer
    Western Slope of Colorado
    1998 Limited
    Not much longer. The last time (and probably the only time) my low-gas light turned on I was in the boondocks so all I could do was drive... Just when the little oiled road hit U.S. 395 I ran out. That was about 35-40 miles after the light turned on. (V6 engine, going 60 mph at the time)
  13. Sep 6, 2020 at 11:38 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
  14. Sep 6, 2020 at 4:29 PM
    taco03Trd
    Carlos
    Riverside ca
    Yea I have an no light comes on
  15. Sep 6, 2020 at 4:31 PM
    #35
    taco03Trd
    Carlos
    Riverside ca
    At what mark did yours turn on ?
  16. Sep 6, 2020 at 6:03 PM
    #36
    wesb1023
    Westley
    Eastern NC
    04 Double Cab
  17. Sep 6, 2020 at 6:04 PM
    #37
    jbrandt
    Justin
    For me, it's whenever the gas light comes on and I'm in the middle of Nevada on Hwy 50...
  18. Sep 6, 2020 at 6:10 PM
    #38
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  19. Sep 6, 2020 at 6:19 PM
    #39
    mcl77
    man. i dont even know. i usually just see the gas light go on then i know i need to get gas.
    i only get gas when that light comes on.
    i set the trip counter as soon as the light stays on solid for a good couple miles or so.
  20. Sep 6, 2020 at 6:20 PM
    #40
    wesb1023
    Westley
    Eastern NC
    04 Double Cab
    That all depends on the truck and the gauge. You can adjust it if you have a steady hand and a little patience. Remove the cluster and then remove the clear plastic cover. Reinstall the cluster without the plastic lens, it could probably need a good cleaning anyway. I noticed that my needle would stay above 1/2 a tank then drop rapidly, and the gas light would come on before it got down to the empty line, upon filling up it would go higher than the full mark. I filled up at the same gas station every time and used my calculated gas mileage to remove the needle, it simply pulls right off and is held in place by friction, I then put the needle back on at exactly 1/2 a tank, according to miles driven. This method didn’t work out so great. I ended up waiting until the gas light came on solid, and put the needle on at the very bottom edge of the empty mark. This method worked for me, goes all the way full, without passing the mark completely and the gas light is on solid when it gets to the bottom of the empty mark. You may need to leave the cover off of the cluster for a few tanks to make sure it’s where you like it. Be careful not to push the needle on too far because it will contact the face of the cluster and stick, figured that out the hard way. Also make sure your truck is running when you push the needle back on, it will stay where it’s pointed, if it’s off a little, move it again, no big deal.
    taco03Trd[QUOTED] likes this.
