Miles on factory brake pads
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 81shark, Apr 23, 2012.
  1. Apr 23, 2012 at 3:59 PM
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    I think a lot has to do with how you drive.......I have an auto but i do more coasting than riding breaks. I hope to get between 75k-100k with mine
  2. Apr 23, 2012 at 7:00 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I'm guessing the high milers are not towing anything or putting anything heavy in the beds? I've had to replace front pads twice in 50000 miles. Second time there was hardly anything left.
  3. Apr 23, 2012 at 7:26 PM
    TastyHuman
    TastyHuman Oh. Bummer.
    2007 AC with 89k miles, still original with no problems. A lot of highway driving on this.
  4. Apr 23, 2012 at 8:17 PM
    CascoYota
    CascoYota Well-Known Member
    Casco,ME
    07 Access Cab V6 SR5
    2007 V6 AC here. 81k miles and both the pads and rotors are still in good shape.
  5. Apr 23, 2012 at 8:59 PM
    tinker2
    tinker2 Well-Known Member
    East Of The Big River
    08 access cab 4x4, just turned 70,000 today on my original front pads. I haul a 400 lb. atv quite frequently. I'm a coster to stops also.
  6. Apr 23, 2012 at 9:08 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    I have 83K on my original rotors and pads.
  7. Apr 23, 2012 at 9:13 PM
    joes06tacoma
    Joe
    Central Coast, CA
    06 4x4 AC has 59K on it with the original pads. Last time it was in for service I was told the fronts were around 60-70%. Not sure about the rears, but those always go longer.
    09 5lug at work has 63K on it with a moderately heavy load in it, lots of in town driving. I had the tires rotated 5K ago or so, nothing was said.
    A friend just had her 2000 4runners front brakes done at 115K. She bought it used at 30K miles. This is the first time she's had them done.
    My dad and I changed the brake pads and rotors on the front of his 96 V8 Dakota at 100K miles. The pads were still 40% or so, but the rotors had warped.
    I expect to get another 20K or more out of my 06's originals. Kind of surprised that the rotors don't look bad at all. Seems like something has to give if the pads are so hard.
  8. Apr 23, 2012 at 9:15 PM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    38k on mine and i've got about 20% left on the front. The rear is toast also...
  9. Apr 23, 2012 at 9:21 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    I'm averaging 60k on the fronts. At 121k miles, I recently put on my 3rd set of pads. Never had to turn the rotors because they wear so evenly. Measured the front rotors and they were worn down only half a millimeter! At this rate, shouldn't need new rotors until 200k miles or more.
    Also pulled the rears thinking the shoes must be getting close. Wrong! Shoes are almost half worn, and the drums are like the fronts...only worn half a millimeter. Don't need to even think about new shoes before 200k miles.
  10. Apr 23, 2012 at 9:31 PM
    sonocotaco
    sonocotaco Well-Known Member
    ken
    Rohnert Park
    2016 TRD Sport AC 4x4 Super White
    The way this truck drives seems to make you use the brakes less. Especially compared to the F150's and Sierras I drove at my last job.
  11. Apr 24, 2012 at 6:44 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    I am at about 77k and still have the original brakes.
  12. Apr 24, 2012 at 7:19 AM
    81shark
    81shark [OP] Well-Known Member
    what are you doing with your truck:confused:
  13. Apr 24, 2012 at 4:31 PM
    jtgroce
    jtgroce Got R Did
    That's what I was thinking how long rotors should last. I changed the original rotors on my '88 Toyota around 200k miles and they were actually below the minimum thickness lol, I don't see the need to change rotors everytime brake pads need replacing
  14. May 3, 2012 at 12:02 PM
    81shark
    i agree. it's bad, but i've changed pads without even checking rotors on my old beater cars.
    i will be getting the truck rotors checked out when i change the pads
  15. May 3, 2012 at 12:16 PM
    #35
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If the rotors aren't warped and still have good thickness, there's no reason to change them just because you're swapping pads. If the rotors need to be turned, then I'd rather spend slightly more money and just get new rotors.
  16. May 3, 2012 at 12:32 PM
    #36
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    I've got 80K on mine. Just got my car serviced on Tuesday. I've still got plenty of life on them. I'm mostly freeway driving.
  17. May 3, 2012 at 12:33 PM
    #37
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I changed my original pads and rotors at around 60k miles and they still had a little bit of life left. I just changed the 2nd set a few weeks ago and they were down to the wear indicators (started squealing) @ 108k miles. I hated those pads though. I will never buy the wearever golds again! I tow a trailer about 3 days a week and it's very hilly where I live (foothills of the N GA mountains). This 2nd time I didn't bother changing the rotors, I didn't have any vibrations or indications they were warped so I just swapped out the pads. I also changed the fluid and bled the brakes this time.
    I find it's easier to just buy new rotors than having to take the old ones to a shop and have them turned. My time is worth more to me than the measly $30 I would save if I had them turned.
  18. May 3, 2012 at 12:43 PM
    #38
    mquinnan
    mquinnan Member
    Michigan
    06 Tacoma
    Rotors? I have an 06 TRD Off Road and mine has drums all the way around
  19. May 3, 2012 at 12:45 PM
    #39
    Pugga
    Massachusetts
    No, it doesn't... You have rotors and pads up front, drums and shoes in the rear unless you did some serious modifications to make it that way.
  20. May 3, 2012 at 12:47 PM
    #40
    macgyver
    Brad
    Canton, GA
    This ^^^
    I inspected my rear shoes last brake change @108k and they still had plenty of life left in them.
