miles per gallon way lower than factory numbers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by menof2amendment, Feb 19, 2014.
  1. Feb 20, 2014 at 8:04 PM
    #41
    bbaggett
    bbaggett Well-Known Member
    Trophy Club, TX
    2013 Tacoma Limited DCSB 4x4
    6" Rough Country lift, 295/65R18 Duratracs
    Exact same setup as you.
    2013 DCSB 4x4 Limited.
    In Dallas and average 16.1mpg after 26 fill-ups on fuelly. Not pleased with the mpg but it is what it is.
  2. Feb 20, 2014 at 8:10 PM
    #42
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    I've never known any vehicle to reach EPA estimates for mpg. Those figures come out of a lab.
  3. Feb 20, 2014 at 8:19 PM
    #43
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    Best ever for my 2010 DC SB Off Road (un-modified) 6 speed is 18.5 MPG.
  4. Feb 20, 2014 at 8:31 PM
    #44
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I've met or done better on every vehicle I've owned for the last 15 years.
  5. Feb 22, 2014 at 12:03 PM
    #45
    imatacomaowner
    imatacomaowner Well-Known Member
    cali
    tacoma 6 cyl 4wd
    If my math is correct, I only did 14.9 on my first measured tank (3 or 4th) That seems impossible. 2014 access cab stock with bfg ats . WHAT THE FUCK
  6. Feb 22, 2014 at 12:04 PM
    #46
    imatacomaowner
    cali
    tacoma 6 cyl 4wd
    And Ive been driving very mellow
  7. Feb 22, 2014 at 12:06 PM
    #47
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    join the crowd of wishful thinking
  8. Feb 22, 2014 at 12:54 PM
    #48
    imatacomaowner
    cali
    tacoma 6 cyl 4wd
    Its fucking garbage. Why are they so variable?
  9. Feb 22, 2014 at 12:55 PM
    #49
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    rabble rabble rabble Prius rabble
  10. Feb 22, 2014 at 1:26 PM
    #50
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Beating the new EPA ratings should be easily achievable in any stock vehicle, but not if you drive 10 mph over the speed limit like most people do.
    I average over 30 mpg on a vehicle rated 18/25 highway. Driving 60 I'll get 30-36 depending on wind.
  11. Feb 22, 2014 at 3:04 PM
    #51
    imatacomaowner
    cali
    tacoma 6 cyl 4wd
    then why the fuck am I driving mellow and getting 15!>?
  12. Feb 22, 2014 at 3:14 PM
    #52
    worthywads
    You're rated 15/18, what's you normal driving? A lot of stop/start is gonna suck.
  13. Feb 22, 2014 at 5:06 PM
    #53
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    Well I made a long trip today. I figured 30% city-70% highway. I kept it under 2000 rpm's or right at it the whole time. My truck has 835 miles on it now. I figured in at 19.7 mpg. I filled it with 93 with no ethanol fuel a see if it is any better. next time.
  14. Feb 22, 2014 at 5:21 PM
    #54
    SWOreBowHunter
    SWOreBowHunter Well-Known Member
    Oregon
    '14 AC 4x4
    Front: 5100s and 884x Rear: Dakars and OME Nitrochargers
    Toyota says the 4.0 and 2.7 get the same mileage, 18-21. My 2.7 gets 20 on average.
  15. Feb 22, 2014 at 6:54 PM
    #55
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I call BS on this, I don't see how this is in any way possible? Please explain.
  16. Feb 22, 2014 at 7:17 PM
    #56
    worthywads
    Yeah you are not the first.
    At front range altitude of 5300+ ft air is thinner, less wind resistance, and less power. I do hypermile including shutting off my engine on my daily commute. My commute is 10 miles of 45-55 and though there are 12 stoplights on the way I'm pretty good at avoiding having to stop.
    Yet without any hypermiling, just driving 60 mph, I can drive Boulder-Denver and get no worse than 30 mpg winter, and way better in summer?
    I drove to Mississippi a few years back and definitely saw the mpg drop with the elevation. Still couldn't get worse than 28 driving around the Delta in the summer.
    That's with charcoal filter still in place and Toyota air filter with 40K on it (might change at 60K), modified intake does NOTHING to improve mpg.
    I accelerate moderately but shift at 2000 rpm.
  17. Feb 22, 2014 at 7:26 PM
    #57
    OneFastGeek
    OneFastGeek Grand Master Fu
    Treasure Valley, Idaho
    2010 TRD Sport 4x4
    I drive like a grandma (according to the GF) and average about 20MPG on my 2010 TRD Sport DC 4x4 Auto. I live in Phoenix and do about 50/50 highway/street.
  18. Feb 22, 2014 at 7:31 PM
    #58
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    I 've only seen 18 mpg like 3 times with my first gen 2.7. And that's with about half highway half city.
  19. Feb 22, 2014 at 7:31 PM
    #59
    happy
    happy Well-Known Member
    Eagle, CO
    '14 DCSB SR5 4x4 Silver Sky
    CBI Moab 2.0, 2.5" Radflo Coilovers, Light Racing UCA, Dakar Leaf Pack, 265/75 16 Kelly Safari TSR, Leer XR100
    so gas mileage is no so good. is truck. use woman car on road.
  20. Feb 22, 2014 at 7:40 PM
    #60
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I don't have a issue with my mpg's because i've never bothered to check it.
