Miles per tank
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacomuncher_559, Apr 19, 2021.
  1. Apr 19, 2021 at 5:35 PM
    DrewMaca
    DrewMaca Well-Known Member
    Drew
    2016 TRD Sport 4x4 Double Cab
    Generally 600.
    Kilometres - I live up north. Canadian.
    Agreed that there are many factors in determining the end result: speed you drive, weather, mods, road conditions, weight in vehicle.
    We are paying close to $5 per gallon of gas - be thankful you are not.
  2. Apr 19, 2021 at 5:36 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    91 octane. 384 per the refill notice after fill-up. averaged 21.5 mpg with 4.88's, stock tires, AT and no additional weight. Added a small mod - Magnuson SC - now average 20.5 mpg on same set-up. Yah I drive like a grandpa but now I have power when I need it. Did a highway trip of a few hundred miles and averaged 22+ mpg. AFR = less air equals less fuel to achieve the same ratio - so living above 5280 ft has that advantage but then again it has a negative of significantly less power. Win some, lose some.
    shotgunbilly420 likes this.
  3. Apr 19, 2021 at 5:38 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Yes
  4. Apr 19, 2021 at 5:41 PM
    shotgunbilly420
    I was just in moab, utah for a week and yeah high elevation gave me great mpg just no power
    GoldenBrew[QUOTED] likes this.
  5. Apr 19, 2021 at 5:42 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    With the stock 245’s i was getting about 330
    Now with 265’s, sliders, skids, fiberglass shell I’m getting about 260
  6. Apr 19, 2021 at 5:47 PM
    Twins09
    Twins09 Well-Known Member
    Dave
    Dutchess County, NY
    2019 MGM TRD Sport, 02 WS6 vert
    Vent visor, hood protector, door sill protector, next up eibach,SCS Ray 10s to be installed next week...
    I usually get about 320 to a tank. I made a trip from NY to Delaware and I got about 360+ out of the tank. That was right after the OV tune for 87. I usually drive a combination of highway and local trips average about 18.5. I have 2.5 lift on 265 70 17 with rocksliders.
  7. Apr 19, 2021 at 7:20 PM
    dylantran97
    dylantran97 Well-Known Member
    Colorado/Texas
    19 DCLB SR5
    450 usually. Will fill up around 400 with 2-3 gallons left in the tank. Truck is stock, with a contractor shell on it. Drive in CO with 85 octane gas.
  8. Apr 19, 2021 at 7:24 PM
    Uscgamecock7
    Uscgamecock7 Well-Known Member
    Nick
    West Columbia, SC
    2015 Tacoma Trd Sport DCLB 4x4(SOLD) 2017 Tacoma Trd OR 4x4(SOLD) 2024 T4R TRD PRO
    Mine shows up 373 alot after i fill up, the most ive ever seen is 415
  9. Apr 19, 2021 at 7:26 PM
    TermLimits
    TermLimits Owner of Valley Tuning
    Jeff
    Cleveland, Ohio
    2016 QuickSand Tacoma TRD OR
    ValleyTune.com Current Tunes: Valley Runner
    Hills of Ohio and PA, consistently over 400 a tank with the tune.
    When I lived in SC I was well into the 400s due to terrain difference
    shakerhood likes this.
  10. Apr 19, 2021 at 7:33 PM
    dylantran97
    Colorado/Texas
    19 DCLB SR5
    Definitely second this. When I lived in PA, I noticed all the highways were 55-65 and rolling hills... great for mpgs. Got 450-500 miles/tank sometimes and consistently 24-25 mpg on longer drives
  11. Apr 19, 2021 at 7:35 PM
    TermLimits
    Jeff
    Cleveland, Ohio
    Interstate sucks though. Paved by idiots it seems, 70 with constant up and down... Stock tune I lived in 4th gear at 15mpg, it NEEDED the tune haha
  12. Apr 19, 2021 at 7:46 PM
    Hofmann’s Tacos
    Hofmann’s Tacos Professional Asian
    Nor Cal / South FL
    2020 off-road 6MT (SFOB 2.0)
    SFOB 2.0
    Get OVTune, every 3rd gen needs it whether the owner knows it or not. Lol. Check out the KDMax 6.0 thread, the guys with automatic trucks say it’s better than OVtunes default 2.0 file.
    ... and if you don’t want to multiply your mileage by 1.07 get the hypertech speedometer recalibration tool.
  13. Apr 19, 2021 at 8:24 PM
    Tacoma1845
    Tacoma1845 Well-Known Member
    Anthony
    Central Virginia
    2018 Tacoma TRD Sport DCLB (Inferno- Premium/Tech)
    All stock. I drive mostly highways 55-70.
    Travlr, RedWings44 and rick carpenter like this.
  14. Apr 19, 2021 at 8:46 PM
    rick carpenter
    rick carpenter Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    I did pretty good last tank. Mostly ~17 mile round trip commutes to work and a trip to the boat on country roads, ~100 miles r/t.
    jtnumberthree likes this.
  15. Apr 19, 2021 at 9:16 PM
    #35
    m0wens
    m0wens Active Member
    2021 Taco
    The last 5 Fill-ups it’s between 330-360 DTE. I’ve only had my Taco for about 3 weeks so I’m still breaking her in. Running a 265/70/R16 Duratrac’s.
  16. Apr 19, 2021 at 9:32 PM
    #36
    OrangeRa1n
    OrangeRa1n Well-Known Member
    Houston Area
    TRD-Offroad 2021
    Well, first off the octane rating makes zero difference for MPG so you could save more by using 87. Isooctane (trimethylpentane) is necessary to prevent engine knock; which is a byproduct of preignition from high compression & temperatures. Technically (chemically) speaking, fuels containing higher octane contain less energy than those with less, however, this is such a minuscule amount that it would be unmeasurable in your Tacoma. In reality, whatever octane you put in will make zero difference with the Tacoma, only your wallet. To prove my point... ethanol has an octane rating of 105 due to the fact that it has an enthalpy of vaporization four times greater than gasoline (i.e., it lowers the temperatures to prevent knock). However, the energy density of ethanol is 30 MJ/kg while gasoline has an energy density of 46.4 MJ/kg. So if you run straight ethanol, you will lose around 35% fuel efficiency (which is also why many E85 conversions require larger injectors). In short, octane makes no difference in MPG, it does not measure energy density.
    Secondly, I get around 340 miles per tank when I'm traveling but only around 240 when I'm not. The MPG calculates when the truck is idling (which I do a lot), so this affects your distance to empty calculation.
  17. Apr 19, 2021 at 9:36 PM
    #37
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My truck usually does over 400 in the Summer.
    SilverBulletII likes this.
  18. Apr 19, 2021 at 10:33 PM
    #38
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    Best Ive gotten to date, last summer with the stock size tires, 450 when low fuel light came on, 470 when dte hit 0.
  19. Apr 19, 2021 at 11:42 PM
    #39
    Big SpartacuS
    Big SpartacuS Member
    2021 Black SR5
    I've had my '21 for a month now and when I drove it off the lot it read 410 to the zero. After two fill ups I'm hovering in the 370-380 range. I live in So Cal, the hilly part with traffic in both directions
  20. Apr 20, 2021 at 12:00 AM
    #40
    Mr.Hustler
    Mr.Hustler Well-Known Member
    2018 Magnetic Grey Metallic TRD Off Road 4x4 [AT]
    It's a secret
    I drive using the setting TacomaSupra...my tanks get me 280 on average.
    If on the rare occasions I switch settings to TacomaCorolla, I can squeeze out around 325. But there's no fun in that.
    Sig Taco likes this.
