Miles to empty
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Phillip11625, Jul 9, 2021.
  1. Jul 11, 2021 at 11:15 AM
    chrono342
    chrono342 Well-Known Member
    2021 Blue TRD Sport DCLB
    That makes sense to me, but how the fuck are people claiming 450 miles? Is that all freeway driving and a deal with the devil?
    Phillip11625[OP] and Tacoma559 like this.
  2. Jul 11, 2021 at 11:17 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Less skinny pedal!
    chrono342 likes this.
  3. Jul 11, 2021 at 11:18 AM
    RedWings44
    Michigan
    A break in will make a big difference in MPG. I've been getting 21.5-24.5 recently at mostly 70 MPH. Keep in mind that as temps drop and winter comes your MPGs will also drop.
  4. Jul 11, 2021 at 11:31 AM
    GumShoe
    GumShoe Well-Known Member
    New Mexico
    MGM 2016 Tacoma SR V6 4x4 DCSB
    The 4 cylinder 2WD access cab gets 23mpg highway. So a 23 mpg multiplied to a 21.1 fuel tank gets 485 miles.
  5. Jul 11, 2021 at 11:32 AM
    chrono342
    Ah, I forgot about 4 cylinder tacos... That makes sense.
  6. Jul 11, 2021 at 12:03 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Interesting non-problem.
    Use a little math. If you get 18 mpg with a 20 gallon tank then you have a range of about 360 miles. Don't care what the ID10T cluster indicates.
    There are 2 methods to monitor, use a trip set or the little needle near the robot with 1 arm. When he points to E, then its time to fill. When the trip set indicates 350 miles, then it time to fill. Trip set have common usage on motorcycles to anticipate when to fill the go-go tank.
  7. Jul 11, 2021 at 1:03 PM
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    I'm on 35s with steep bumpers, full skids, rear swing out and camper shell. I'm heavy as hell.
    emund and Phillip11625[OP] like this.
  8. Jul 11, 2021 at 1:08 PM
    Bowhuntercoop
    Bowhuntercoop Well-Known Member
    2025 gx550 overtrail. 2025 limited off-road tundra.
    I get over 400 miles average and I’m on 285s. I just keep the shifts under 2k and try not to speed. Commute 45 miles one way and enjoy the drive! When I had 265s I would get over 450 miles per tank.
  9. Jul 11, 2021 at 1:13 PM
    chrono342
    I mean, I could eat ramen all day and save money on my monthly food budget, but sometimes you want to indulge and put your toe into in a bit.
    :burnrubber:
    Bowhuntercoop[QUOTED] likes this.
  10. Jul 11, 2021 at 1:24 PM
    RedWings44
    Michigan
    That'll do it!
  11. Jul 11, 2021 at 1:45 PM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    All the Tacomas that I have ever had that hit the empty light was able to go an extra 50 miles before totally dried empty. So there is a reserve pass the empty light. When you fill up you never get the real amount because there is some fuel left in the tank.
  12. Jul 11, 2021 at 1:46 PM
    chrono342
    While true, it's still probably prudent to fill up around the 'empty' mark.
    Tacoma559 likes this.
  13. Jul 11, 2021 at 7:58 PM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    After fill up mine says 385 miles to empty 95% of the time. A few times it says 415.
  14. Jul 11, 2021 at 8:11 PM
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    I've got an ultraguage and it has good agreement with the cluster MPG numbers.
    The DTE on the ultraguage is based on the tank capacity. The DTE on the cluster seems to gives about a 2 gallon (25-40 mile) hedge. My understanding for this is so that there's a couple gallons floating around as an "emergency" reserve so that the pump always has an adequate amount of fuel around it for cooling and consistent flow.
  15. Jul 11, 2021 at 9:45 PM
    #35
    tommygs3
    tommygs3 Well-Known Member
    tommy
    18 tacoma limited
    Fox 2.0 - KDmax tune - 5.29 revolution
    i dont bother with it... mpg is never correct even on a good day... i just pump when its 1/4 tank and enjoy my truck...
  16. Jul 11, 2021 at 9:51 PM
    #36
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    the dash genie is ok
    its onmly accurate to the environs & habits o Ur driving
    the MOST accurate is the tried & true actual miles / actual gallons used !!!!
    whether its commuter
    vacation
    hiway
    mountains
    wont give U ‘ miles to empty ‘................
  17. Jul 11, 2021 at 10:00 PM
    #37
    Vea
    Vea Well-Known Member
    2018 Tacoma or
    Anyone else’s fuel indicator off since the fuel pump replacement tsb?
  18. Jul 11, 2021 at 10:02 PM
    #38
    ROAD DOG
    FEW
    i routinely get 450 a tankful
    legal speeds
    hi way
    no way i get that in town altho yesterday the dash indicated i would get 19.5
    that i assume to be a combination of city/hiway
    as i have NO commute
  19. Jul 12, 2021 at 12:22 AM
    #39
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    do you mean the needle? yes. mine sits well past "F" for quite a while before it starts moving. i am wondering if they bent the float arm.
  20. Jul 12, 2021 at 3:34 AM
    #40
    Nirango kid
    Gilles
    Ontario
    It is hard for me to explain cause here in Canada is the metric system of which I hate. My tank holds 80 liters ( 21 gals) and usually get 600 km ( 373 miles) and when I hit empty and I fill up it usually takes 64-66 liters ( 16-17 gals )which means that there was still 14- 15 liters ( 3-4 gals) in the tank before fill up. I don't do this all the time I usually fill up when I am at 1/4 tank or less. Also our gallons are bigger than the U.S so I get about 25-26 mpg while you guys get 21-22 mpg u.s. if I am right.
