Milky Diff Fluid
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacomalex1949, Jan 3, 2023.
  1. Jan 3, 2023 at 1:12 PM
    tacomalex1949
    tacomalex1949 [OP] Well-Known Member
    Alex
    2021 Tacoma DCSB
    Going to change the diff fluid
  2. Jan 3, 2023 at 1:15 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    it has a breather on it?...how high up is it mounted
  3. Jan 3, 2023 at 1:18 PM
    tacomalex1949
    Alex
    2021 Tacoma DCSB
    up behind the tail light.
    to clarify, the modification moves the breather up behind the taillight. The stock breather just sits right on top of the diff.
  4. Jan 3, 2023 at 1:21 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Make a 8” loop in the tube so it holds the condensation at bottom of loop.
    lynyrd3 likes this.
  5. Jan 3, 2023 at 1:26 PM
    mushroom_man7
    mushroom_man7 Well-Known Member
    wont this defeat the purpose of a breather if too much water is blocking the tube?
    JoeT4R, doublethebass, SR-71A and 3 others like this.
  6. Jan 3, 2023 at 1:27 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    If its getting milky you got a buttload of condensation
    SR-71A, TexasWhiteIce and Rusty66 like this.
  7. Jan 3, 2023 at 1:29 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Any cracks/splits/wear along the hose? Might be hard to see since the tube is clear. I’ve done a diff breather relocate on 3 different vehicles and never had this issue across 3 wildly different climates including high humidity
  8. Jan 3, 2023 at 1:40 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    One of the many reasons folks don’t do this mod.
    BillyE, Junkhead, MadKatt and 2 others like this.
  9. Jan 3, 2023 at 1:40 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Can't tell you why, but have see test and results. Clear tude/ hose condensate more then black rubber tube/ hose. If I can find article, will post. Has to do with composition, of materials.
    50Buck likes this.
  10. Jan 3, 2023 at 1:54 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    OP : did you install a one way or two way breather??
  11. Jan 3, 2023 at 2:03 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I will trust the stock breathers until I prove them faulty.
    BillyE, Junkhead and doublethebass like this.
  12. Jan 3, 2023 at 3:53 PM
    DuffyBank
    DuffyBank Well-Known Member
    Blew out the axle seals on my 2nd Gen because of water getting in the stock breather. Relocated after that and never an issue. One of the first tweaks I did after getting my 3rd Gen
    Big tall dave, 71tattooguy and 50Buck like this.
  13. Jan 3, 2023 at 4:12 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    What type of fitting did you use on the diff housing, was there a gasket? What kind of breather did you use, and is the tube tight on both ends? Hose clamps?
    Toyota uses remove breathers on several of their vehicles without issue.
    Jeff
    BLtheP likes this.
  14. Jan 3, 2023 at 4:28 PM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    I think you have a bigger issue than the clear plastic hose. Probably a bad breather. If it were condensation then you'd expect there to be issues with the front diff as well since the breather is up in the engine bay and not right on the front diff.
    BLtheP likes this.
  15. Jan 3, 2023 at 4:29 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I don’t really understand that logic. Jeeps have had breathers on a hose exactly like
    the aftermarket Tacoma kits for ages. My 94 YJ for example. I don’t see how this introduces any more condensation to the Toyota axle than the Jeep factory version does to its Dana axles.
    What are the other reasons to not relocate the breather? I’m not anti-stock, but I don’t really see a downside to the relocation. I have a feeling the install on OP’s breather was the problem, not the parts themselves. They shouldn’t allow any more condensation into the diff than the stock breather, seeing as both are breathers. Maybe hose clamps weren’t tight enough, I don’t know.
    chuam likes this.
  16. Jan 3, 2023 at 4:31 PM
    '16goingon'17
    '16goingon'17 Well-Known Member
    Trailslayer
    NoVA by way of NWA
    2017 TRDOR 4x4 DCSB MT
    JBA STD UCAs. 6112/5160 @6/5. Wheelers 1.5" 3AAL with Superbumps. BROG molle headrest covers. GMRS & Ham radios with roof-mounted NMO Laird Phantom antenna. Thinkware front/rear dashcams, FreshMexicanTaco's DMM, Meso's dome/map LEDs & Flipfob, Swingcase on driver side. Accumulator Delete Mod (ADM). Two-wheel drive Low Range Mod (2LM). Overland Tailor Tune (OTT) 7.0. Extra juicy oil spill on the bed mat.
    Correlation does not equal causation.
    50Buck likes this.
  17. Jan 4, 2023 at 7:34 AM
    tacomalex1949
    Alex
    2021 Tacoma DCSB
    All points worthy of discussion. I’m not sure where I went wrong as I followed instructions as best I could but it was a while ago. I ordered some new fluid, when I do the change next weekend hopefully I will assess the breather system and if it seems the hose or whatever is causing issues I’ll go back to the stock breather for now.
    '16goingon'17 likes this.
  18. Jan 4, 2023 at 8:29 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I did the breather mod on my 2nd gen, but won’t do it on my 3rd gen until the warranty expires in 7 years. I don’t want Toyota potentially denying it due to this mod.
  19. Jan 27, 2023 at 11:40 AM
    BLtheP
    Plano, TX
    That isn’t typical for the ‘mod’. I don’t think you had your hose clamp tight enough or something.
  20. Jan 27, 2023 at 11:44 AM
    TireFire
    Olympic Peninsula
    Drive through some deep water with a hot diff
    HondaGM likes this.
