Milky Oil Cap, Blown Head Gasket?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reece08, Jan 7, 2024.
  1. Jan 7, 2024 at 3:17 PM
    Reece08
    Reece08 [OP] Member
    Reece
    2008 Tacoma 4.0 Prerunner
    Is this a telltale sign of a blown head gasket? I haven't noticed any coolant loss, white smoke, overheating, or anything like that. I think the cap may have just gotten wet when I changed the oil last time because it was raining outside.The truck is a 2008 4.0L Prerunner.
    -Reece
  2. Jan 7, 2024 at 3:19 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Normal
    R0dzilla75 and Reece08[OP] like this.
  3. Jan 7, 2024 at 3:20 PM
    Reece08
    Reece08 [OP] Member
    Reece
    Thanks!
    IvanhoeTaco likes this.
  4. Jan 7, 2024 at 3:21 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    Nope. You’re just short tripping in cold weather.
    clean it up and drive on. That engine will keep ticking (literally) until you stop putting oil in it.
  5. Jan 7, 2024 at 3:33 PM
    BlueT@com@4×4
    BlueT@com@4×4 Well-Known Member
    2015 TRD PRO Tacoma
    to make sure look on dip stick if look like your oil cap definitely your head gasket blown.
    wilcam47 likes this.
  6. Jan 7, 2024 at 3:39 PM
    TacoTuesday1
    SD CA
    That's a telltale sign of condensation.
    Block test would be telltale sign of HG leak.
  7. Jan 7, 2024 at 4:05 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Confirm lots of short trips?
    grizquad and joba27n like this.
  8. Jan 8, 2024 at 6:32 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    It's a 100%, no doubts, absolutely sure sign you have moisture in the crankcase.
  9. Jan 8, 2024 at 6:45 AM
    timbobzimbob
    timbobzimbob Well-Known Member
    Tim
    Ottawa, Ontario
    05 DCLB 4x4
  10. Jan 8, 2024 at 6:46 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Check oil dipstick.
  11. Jan 8, 2024 at 7:12 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Go for about a hour ish drive on the highway then recheck. If you're not losing any fluid then you're probably okay.
    lt's a good idea to hit the highway for atleast an hour every two weeks or max once a month to get everything warm and clean up the engine a bit from condensation and fuel dilution along with making sure your battery gets a full charge. Especially in the winter time
    2015WhiteOR and Carlrf like this.
  12. Jan 8, 2024 at 11:24 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    These threads pop up every single year around winter time.
    2015WhiteOR and Naveronski like this.
  13. Jan 8, 2024 at 3:59 PM
    TacoTuesday1
    SD CA
    catch can
    30 dollars
    TOMB likes this.
  14. Feb 9, 2024 at 11:38 AM
    caffiend
    caffiend Well-Known Member
    2007 TRD Sport
    Time to replace PCV valve.
  15. Feb 9, 2024 at 1:57 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Thats the result of being too quick and shutting down fast
    Go at it for a long time and you wont see that messy buildup
    Works on engines too
    indigotacoma07II likes this.
  16. Feb 10, 2024 at 10:24 AM
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    Drain the oil. If mild shake comes out then you may have a head gasket problem needing further diagnosis.
