Milky oil in neck but oil looks fine?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Turdyota3000, Dec 19, 2016.
  1. Dec 19, 2016 at 5:16 PM
    Turdyota3000
    Turdyota3000 [OP] Well-Known Member
    Round da corner
    07 dcsb trd off-road
    Icon 2.5's, TC, yackety shmackety....
    Changed plugs and pcv yesterday because of excessive oil use (trouble shooting). Using two and a half quarts every 1,500-2000 miles so something had to happen. Opened my oil fill cap and BAM there it was. Looks like water in my oil, but my oil is clean on the stick.
    Moisture buildup from bad pcv and plugs? #6
  2. Dec 19, 2016 at 5:18 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Looks like condensation rather then a coolant leak, so perhaps the PCV was your problem.
  3. Dec 19, 2016 at 5:20 PM
    dusman
    dusman Well-Known Member
    Dustin
    Windsor, Maine
    2017 TRD ORDC MGM
    You do a lot of short trips ?
    k3v11n likes this.
  4. Dec 19, 2016 at 5:23 PM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Ive seen that plenty of times on many different vehicles. Usally happens when its colder out and the vehicle is driven short distances and never getting up to temp. I had a 2013 Tacoma TRD OR AC 4.0 and it did the same thing. Make sure you check inside and wipe out the cap. Allso the manual states plugs every 30,000.
  5. Dec 19, 2016 at 5:24 PM
    Turdyota3000
    Round da corner
    I sure hope so. I don't know where the oil is going because it doesn't smoke but I'm 2-2 1/2 low in between changes. I do on the other hand have black suet (like a diesel) caked in my tailpipe.
  6. Dec 19, 2016 at 5:25 PM
    FFBlack
    2019 TRD OFF ROAD
    Do you see any oil in the coolant?
  7. Dec 19, 2016 at 5:25 PM
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Soot*
  8. Dec 19, 2016 at 5:26 PM
    Turdyota3000
    Round da corner
    How short of trips are we talking? 1-5 5-10 10-20 miles?
  9. Dec 19, 2016 at 5:28 PM
    Turdyota3000
    Round da corner
    Sooooot haha!
    Haven't seen any oil in coolant but if I do?
  10. Dec 19, 2016 at 6:12 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    buddy of mine is having that problem, not on a taco tho, its not leaking, hes actually burning it lol did a compression test on each cylinder and one of them was running 2nd stroke pressures on the first stroke, he didn't have blue smoke either...at first, now you should see it haha
  11. Dec 19, 2016 at 6:20 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    @Turdyota3000, what you see in the oil filler neck and under the cap is caused by trips that are too short for the engine to reach an maintain operating temp long enough to cook out all the moisture in the motor. It is a good idea to drive the truck every now and then for 30+ minutes to get it up to temp and get the moisture out. What you are seeing is "normal" for our engines. If you see milky oil on your dipstick, or buildup in the coolant overflow tank, that is when you need to worry.
    My suggestion, go enjoy a drive once or twice a week. If you don't already, throw in a couple WOT accelerations (after it is warmed up), it will help clear moisture buildup in the exhaust system.
  12. Dec 19, 2016 at 6:44 PM
    WhiteTaco82
    WhiteTaco82 Well-Known Member
    Kevin
    Maine
    2018 Toyota Tacoma SR5 4x4 Access Cab - Super White
    Tinted windows, Bed mat, Truxedo Tonneau cover, White 3D Glove box letters, EyeCatcher Tailgate Letters, AVS Window Visors, AVS Bug deflector hood shield, Center console tray, Center console divider, Alla amber LED fog lights, LED map lights & license plate lights, Falken Wildpeak 265/75/16 Tires, Interior black and white console liners & TRD Performance Air Intake.
    I bought a 2005 Toyota Tacoma two years ago. When I did my first oil change after my purchase I noticed that same kind of milky residue underneath the Cap and in the filler neck as well. I called the dealership where I bought the truck and they said to bring it in and they look at it while I was there did they did a sniff test, a pressure test and an oil change as well. Everything came out just fine and they said it was probably just condensation. I wish I still had the photo because it looked exactly like what you are showing. Nothing to worry about, just normal condensation.
  13. Dec 19, 2016 at 8:05 PM
    Turdyota3000
    Round da corner
    Thank you all.
