Milky substance in oil cap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacotruck93, Mar 14, 2018.
  1. Mar 14, 2018 at 5:17 PM
    tacotruck93
    tacotruck93 [OP] Well-Known Member
    Zach
    Akron,Ohio
    2012 TACOMA TRD OFF ROAD
    DA3705CB-6C5C-445F-9842-FA0470ADA727.jpg Has anyone seen had this happen when you go to change the oil? It’s like a creamy/milky substance in the fillet tube and oil cap.
  2. Mar 14, 2018 at 5:18 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    if you do a lot of short trips, that will accumulate. Just wipe it and continue. harmless, but try to drive longer
  3. Mar 14, 2018 at 5:19 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Normal. Short trips and not getting to normal operating temps cause it.
  4. Mar 14, 2018 at 5:20 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    It's just condensation evaporated from the motor. A long road trip, getting the engine nice and hot, it will get eaten up.
    JDawg562 and tacotruck93[OP] like this.
  5. Mar 14, 2018 at 5:21 PM
    tacotruck93
    Zach
    Akron,Ohio
    Are you saying just in general because yeah I only live 10 minutes from my job and that’s about all the commuting that I do. But thank you for the advice!
  6. Mar 14, 2018 at 5:47 PM
    250taco
    250taco Active Member
    Completely normal. I used to get this on short trips all the time with Castrol. Switched to Mobil and no issues no matter how short the trip or temperature. Now, I'm not saying this is a "solution" as it might not work for every truck, but seeing as this is nothing to worry about, just a suggestion. I don't know enough about oil to have a good explanation for why my truck did it with Castrol but doesn't with Mobil.
  7. Mar 14, 2018 at 5:51 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Normal....carry on.
    BassAckwards likes this.
  8. Mar 14, 2018 at 6:03 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    I run Mobil in my truck and get foamy condensation
  9. Mar 14, 2018 at 7:30 PM
    250taco
    Yeah I figured it was just luck on my end! Just let me keep believing in Mobil!
  10. Mar 14, 2018 at 7:48 PM
    3X4X4
    3X4X4 Well-Known Member
    JR
    KS
    2006 Indigo Ink Blue TRD O/R
    Snug Top, Toytec Ultimate Lift, SPC control arms, N-Fab light bar with Hella DL, Yakima rack, factory locker, Cooper AT3 265X75X16, TRD exhaust and front skid
    A ten minute commute everyday will not necessarily hurt anything but the engine never gets to temperature long enough to "burn" off the moisture in the engine and exhaust. A good long run from time to time will help with that. But a vehicle must serve it's master's needs and the Tacoma will be okay.
    timbobzimbob likes this.
  11. Mar 14, 2018 at 7:50 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’m going to guess it’s condensation inside the block that gets circulated into the oil (like the moisture that builds on the windshield on cold humid nights) and makes milky steamy shit). On occasion I’ve noticed a small amount of water come out the Fumoto drain valve first before the oil comes out.
  12. Mar 14, 2018 at 8:00 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
  13. Mar 16, 2018 at 9:28 AM
    goonsquad08
    goonsquad08 Well-Known Member
    Michigan
    ‘12 DCLB Tacoma
    Hey fellas, I drive a short commute each day as well. Bought a second gen earlier this year and I had more build up than pictured on the cap. Figured it was nothing to worry about given the short trips. Changed oil a week ago and just made a long drive (Iowa to Michigan) and checked oil. Levels are fine but the sludge is still on the cap.
    Truck has been running fine. No issue or signs of overheating and the coolant level has not changed. Any advice?
  14. Mar 16, 2018 at 9:39 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Just continue on. Do you use an aftermarket oil filter?
  15. Mar 16, 2018 at 9:47 AM
    TaKoToy
    TaKoToy Well-Known Member
    Robbie
    Prince George VA
    2013 4x4 OffRoad, 2020 cement DCLB OR
    Mostly stock
    I use to get that when the dealer did the free services during first 25k miles. Switched to mobil after that and have not seen it again. Freaked me out the first time too.
  16. Mar 16, 2018 at 10:30 AM
    goonsquad08
    Michigan
    ‘12 DCLB Tacoma
    Running Valvoline full syn with a Wix XP filter.
  17. Mar 24, 2018 at 7:00 AM
    tacotruck93
    Zach
    Akron,Ohio
    I use Royal Purple with the stock oil filter
