Milky white residue in Oil Fill Tube and Cap???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMagnum, Jan 1, 2011.
  1. Jan 1, 2011 at 2:42 PM
    TacoMagnum
    TacoMagnum [OP] Member
    3" lift, Nitto grapplers on dicks, remote start. Amsoil synthetics and K&N filters... im a simple man really =)
    Hey guys, just did an oil change and noticed that there is a milky white residue coating the inside of the oil fill tube and the inside of the cap.. Never noticed this before! i have an 07' 6cyl. anyone else notice this?? Truck runs fine but seems to choke a bit on cold starts... kinda wierd... :confused:
    Thanks all, Cheers to 2011!
    Ray
  2. Jan 1, 2011 at 2:53 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I was wondering when this week's edition of this thread would pop up....
    I'm guessing you have a short drive to work? Where the engine can't warm up all the way before you have to shut it off?
  3. Jan 1, 2011 at 2:56 PM
    TacoMagnum
    Lmao! Ive been lurkin here for awhile and never saw a thread about it.. but yes i do take short drives a few times a day, and i did take a short drive before i changed it but ive had the truck for less than 7 months and put 11,000 on her so i do drive quite frequently. 45,000mi as of now. No problems so far!:D
    Thanks!
  4. Jan 1, 2011 at 3:00 PM
    TexasTacoma37
    The general consensus is that the milky white residue occurs on the cap and the filler tube because on short drives when the engine can't get up to normal operating temp, condensation forms on the cap and filler tube (the furthest points from the hot engine). Others will chime in with more detail. I'm only going on the discussion I've seen in previous threads.
  5. Jan 1, 2011 at 3:02 PM
    TexasTacoma37
  6. Jan 1, 2011 at 5:06 PM
    JKD
    JKD Well-Known Member
    And with the long, highly insulating oil fill tube on the 4.0, some people seem to have the problem even with long trips.
    Still won't cause any problems with the engine long-term. If you notice it, just check to make sure your oil fill cap is on nice and tight, and forget about the engine mayonnaise.
  7. Jan 2, 2011 at 8:03 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    On Friday...I could've put mine in a small jar and shipped it to you. :D
