Milky White Substance in top of Radiator
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jnorris, Mar 8, 2019.
  1. Mar 11, 2019 at 8:40 AM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    2003 Std Cab 2.7L 4x4 & 2024 Off Road
    Bilstein 5100s, Deaver Leaf Springs, JBA UCAs on 2003 King 2.5 shocks front and rear on Off Road
    I agree.
    "...coolants typically use a phosphate/ silicate mix as the main components in their inhibitor system. Conventional inhibitors like silicates and phosphates work by forming a protective blanket that actually insulates the metals from the coolant. These inhibitors can be characterized chemically as inorganic oxides (silicates, phosphates, borates, etc.)."
    xtremewlr[QUOTED] likes this.
  2. Mar 11, 2019 at 8:58 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    oil in water, not the other way around, IMHO
  3. Mar 11, 2019 at 9:06 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    It doesn't resemble ANY stop leak product I've ever seen. They're usually coppery or Barr's pellets are gooey black.
    It looks like a sediment issue maybe from tap water maybe not but I don't think it's anything to worry about, just flush it good and use distilled to make up your new antifreeze.
    I wouldn't worry about using tap for flushing unless you're on a well.
    If you can drink it, it should be ok for flushing. My water is delish, it's prob. better than distilled.
  4. Mar 11, 2019 at 9:10 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Negative on the tap water. Tap water contains minerals that cause buildup over time. Best to flush with distilled whenever possible since there are no hard minerals present in it and a gallon costs all of $1 or less. Tap water is fine if that is all you have access to in an emergency or otherwise but given a choice, I wouldn't use it.
    TartanEagle likes this.
  5. Mar 11, 2019 at 9:11 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Mine doesn't. Not everyone lives in rocky areas.
  6. Mar 11, 2019 at 9:14 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    If it's drinking water it does, doesn't matter where you live. Some are less than others tho. If you have to use a water softener at all, don't use it in your cooling system. Distilled water is so cheap and easy to find, why wouldn't you use it?
  7. Mar 11, 2019 at 2:33 PM
    Jnorris
    Jnorris [OP] Well-Known Member
    Jordan
    2005 Toyota Tacoma
    Correct coolant has not gone down at all.
  8. Mar 11, 2019 at 2:43 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    I was talking about flushing. God this is an anal bunch.
    But yes, my tap water is that good. It's tops. Refinery engineers here have said so. They demand it.
    eon_blue likes this.
  9. Mar 11, 2019 at 2:45 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    I'd still flush with distilled as there is some left, even when draining the block. Do as you like. I knew what you meant.
  10. Mar 11, 2019 at 3:14 PM
    austinsdad99
    austinsdad99 Well-Known Member
    1999 prerunner 3.4
    For what its worth how old are/were your Radiator hoses? I put a post up when i changed mine i had those tiny black specs floating around in my green coolant. Turns out my factory 200k plus mile upper hose had start to degrade and the rubber bits were getting all in the system.. Not saying thats your issue, but i did see some black bits in your pic. Can't say as far as the milky stuff... Id flush it then report back.
  11. Mar 13, 2019 at 12:03 PM
    Jnorris
    Jordan
    2005 Toyota Tacoma
    Well, ended up taking it to a radiator shop. They checked it out and said they had seen it before and was what they said was crap built up over time nothing to be worried about. My radiator cap they said was bad. So no telling what has gotten in there over time. The 1st thing he mentioned was either silicate build up or leak stop. But pressurized my coolant system and said all is well now.
    OneWheelPeel likes this.
