Mill down lift spacers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flightcancled, Apr 13, 2010.
  1. Apr 13, 2010 at 9:42 AM
    flightcancled
    flightcancled [OP] Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    So I have a set of used 3" lift spacers on the way to finish my lift. I am not actually sure though how much lift I need to level the truck. Goal here is not to jack the truck up, but to get it level after an AAL adds to the 1.5" rake I already have. (thank you Toyota :smash:)
    Is there any reason that I couldn't machine down the spacer as needed? I would be doing this very professionally, no dremmel crap. As long as I am there I am also think I am going to cut them asymetrically to compensate for the Taco lean (again FU Toyota).
    Thanks!
  2. Apr 13, 2010 at 9:47 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I think that would work
  3. Apr 13, 2010 at 9:49 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  4. Apr 13, 2010 at 9:57 AM
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    How much machining would cost?
    How much new spacers would cost?
    If you machine to much, the spacer will loose strength, research and get the right spacer for the look you want.
    Suspension components are not a place you want to skimp.
  5. Apr 13, 2010 at 10:04 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    I agree...
    If the OP has the ability to machine the spacers, I'd make your own set custom to the desired height.
  6. Apr 13, 2010 at 10:08 AM
    flightcancled
    For $35 for a set of 3" Toyotatecs the time and materials cost is totally worth it. I already know that I will be leaving at the least somewhere between 2-2.5 inches. Since there are commercially available spacers as small as 2" I am safe. I would be doing the work myself with some assistence from a gunsmith.
  7. Apr 13, 2010 at 10:17 AM
    Mandy3206
    San Juan PR
    I got procomp 2.25 spacers but are made of welded steel parts, not sure how thin you can get with aluminum, it's your truck, do as you wish.
  8. Apr 13, 2010 at 2:07 PM
    flightcancled
    It is something that I notice every time I drive the truck, and annoys me. As long as I am putting the effort in to level my truck why wouldn't I do it right?
  9. Apr 13, 2010 at 9:58 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    Sounds like you know what you're doing. A little time on the lathe and a bit of close inspection and you should be alright. Hard to say for sure without seeing the before and after though.
  10. Apr 13, 2010 at 10:26 PM
    arrowhead
    arrowhead Active Member
    I've done it not on a toyota but A ford.
    Worked great.
    I would say go for it.
  11. Apr 13, 2010 at 10:57 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    I think you need more lean!!! :mudding:
  12. Apr 13, 2010 at 11:40 PM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    I would recommend you look into coils, or 5100's. Use the bare minimum spacers just to take away the so called lean, if you want.
    I'm totally against using top spacers to achieve lift. Simply because they increase the amount of down travel beyond what the truck should safely operate.
    But that's just MHO.
    Good Luck!
