Millenium Falcon Taco Build
Discussion in '1st Gen. Builds (1995-2004)' started by EB Group, Sep 17, 2015.
  1. Oct 28, 2015 at 6:25 PM
    #201
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I had a vibration in my rear that was fixed with 3* shims.
    I used this to read up on driveshaft geometry http://www.4crawler.com/4x4/CheapTricks/Driveline-101.shtml
    Check your angles and adjust using shims, etc... as needed. Not every truck will have the same issues so my fix might not be your fix.
    EB Group[OP] likes this.
  2. Oct 28, 2015 at 8:00 PM
    #202
    EB Group
    EB Group [OP] Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    Thats awesome. Thank you.
    I noticed my leafs are nearly flat when the truck is not jacked up and nothing in the bed.
    Time for a new leaf pack?
  3. Oct 28, 2015 at 8:26 PM
    #203
    EB Group
    Rudy
    Halifax
    StAndrew likes this.
  4. Oct 29, 2015 at 12:04 AM
    #204
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I too have no vibrations (at least driveshaft vibrations) because of 3* shims. It is becoming harder and harder to find 3* shims though. 2* and 4* are everywhere though. 3* seems to be the magic number. Remember you have a driveshaft with a double cardan joint (basic type of CV), it doesn't necessarily have the same required geometry of a solid driveline (one with only two u-joints), meaning "in the ballpark" on pinion angle is generally good enough to rid you of vibrations. But I would really consider having your driveshaft balanced now that you put it together without indexing it first.
  5. Oct 29, 2015 at 4:42 AM
    #205
    EB Group
    Rudy
    Halifax
    I would have to agree with you for balancing the drive shaft.
    I think I will end up removing the blocks from under the leafs, replacing the leaf packs, replacing the shocks and then I'll use the digital angle finder I have ordered to find out what angle shims I need and put them in.
    Then I'll see about getting the drive shaft balanced.
    Thank you for your input!
  6. Oct 29, 2015 at 4:57 AM
    #206
    EB Group
    Rudy
    Halifax
  7. Oct 29, 2015 at 6:59 AM
    #207
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Wow good attention to detail man. I know that must be time consuming! Especially for something that adds no "cool" factor. Truck is looking good btw!
    EB Group[QUOTED][OP] likes this.
  8. Oct 29, 2015 at 8:56 AM
    #208
    EB Group
    Rudy
    Halifax
    Thanks for reading through. It is pretty interesting when telling people how long I've been working on it and there is little to show visibly that a lot of time has been put into the truck. I've left the kool changes for later!
  9. Oct 29, 2015 at 9:03 AM
    #209
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yes. And get rid of those blocks. I vote OME leafs.
    If you go OME, they relocate your axel up an inch and your rear tries might rub the front tire wall. 4Crawler makes custom axel shims and relocation plates; if you do OME leafs, first install the leafs and measure the difference in axel position. Also measure the pinion angle and call 4crawler to order a custom one piece shim/relocation plate.
    http://www.4crawler.com/4x4/ForSale/Shims.shtml
  10. Oct 29, 2015 at 11:15 AM
    #210
    EB Group
    Rudy
    Halifax
    Awesome thanks.
    I was going to wait until I sort the suspension out before shimming as that obviously changes geometry.
    I only have 235/75/15 on the truck, do you think the tires would still rub?
    Also, if the OME leafs raise the axle how should I handle the front Suspension, I have longer bilstien struts and springs that raise the front to match the back.
  11. Oct 29, 2015 at 11:48 AM
    #211
    EB Group
    Rudy
    Halifax
  12. Oct 29, 2015 at 3:57 PM
    #212
    Camps
    Camps Well-Known Member
    Greg
    Bay Area
    21 TRD DC
    Fox, BR6, BAMF, SSO...
    I did this same thing on my 04 dbl cab. Started with the OME leaf pack, then added the AAL + the relocation plates from 4crawler. Before the AAL and relo plates, my rear tires would rub (285s). That fixed the issue!
  13. Oct 29, 2015 at 4:13 PM
    #213
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Couldn't say. My 285 65 r16's don't rub but it's damn close. I think with brand new tires and full tread they would rub. I could use a relocation plate but I hate f-ing with the rear suspension so Im kicking that can down the road.
    The OEM leafs push the axle forward so you need a plate that relocates the axel ~1" to the rear. I helped a local member do his install and he just went ahead and got a 3* 1" relocation plate from 4Crawler and installed it all on the first go round. Probably not the best way to do it; probably better to do the suspension and then measure what you need but it worked out in the end for him.
  14. Oct 30, 2015 at 6:03 AM
    #214
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    i have the 3 inch adjustable bilstein 5100's all the way around, with a AAL. I have no rubbing. I did however do the pinch weld "mod", and I have pretty much stuffed all 4 corners, with very little rubbing.
    Edit: Really like this thread. It covers some topics that aren't covered in most build threads. IE: Restoration instead of mods, or parts.
    I have found myself in the middle of tearing out the interior and stopping, because I didn't want to screw something up, and break a part, because I wasn't sure how it came out...so this has helped being able to see some things torn apart. Thanks.
  15. Oct 30, 2015 at 3:14 PM
    #215
    EB Group
    Rudy
    Halifax
    Hey Roll Tide,
    Thanks for your comments, very much appreciated. I'm really glad I could unknowingly be of help!
    I'm happy to answer any questions you or anyone else may have.
  16. Oct 30, 2015 at 3:18 PM
    #216
    EB Group
    Rudy
    Halifax
    So thanks to Speedytech7 I'm doing the steering rack guide bearing replacement/update.
    A before picture.
    I picked up a vibtage toyota cap today.
    Plain Jane Taco likes this.
  17. Oct 30, 2015 at 3:35 PM
    #217
    EB Group
    Rudy
    Halifax
    What am I up to now?
  18. Oct 30, 2015 at 3:36 PM
    #218
    Zona Scout
    Zona Scout The Local Marina Master Baiter
    Cody
    Tucson, AZ-->Oahu, HI
    2013 Wannabe Baja Badass Storm Trooper Knock Off Attempt
    Generic Cliche Bullshit
    I just fapped so hard to your build thread.
    Great work man! In about 15 years when my kid is ready to start driving, I plan on doing this with him. Probably not nearly as in depth, but enough that he will respect his vehicle because of the work that was involved.
    TRD_IRV likes this.
  19. Oct 30, 2015 at 3:37 PM
    #219
    EB Group
    Rudy
    Halifax
    The member on Yotatech who's walkthrough I am following used a different approach but this what I had availible.
    Just made a tool as I didn't have a hex socket large enough to use to install the new plug back in the steering rack.
    Speedytech7, StAndrew and Zona Scout like this.
  20. Oct 30, 2015 at 3:38 PM
    #220
    EB Group
    Rudy
    Halifax
    I'm at a loss for words!
    Zona Scout[QUOTED] likes this.
