Million Mile Toyota
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Scoobarooo, Feb 29, 2016.
  1. Mar 1, 2016 at 8:48 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    There is a typo. It says Ford but should say "3rd Gen Taco"
    HAVVOKK[QUOTED] likes this.
  2. Mar 1, 2016 at 8:53 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
  3. Mar 1, 2016 at 8:53 AM
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    Free popcorn at every visit!
  4. Mar 1, 2016 at 8:57 AM
    PackCon
    Connor
    Bushed likes this.
  5. Mar 1, 2016 at 9:04 AM
    PackCon
    Connor
    No chrome, 6.5ft bed, and power seats (massage seats as a matter of fact). Beat that Toyota!! HA!!
  6. Mar 1, 2016 at 9:45 AM
    Scoobarooo
    Scoobarooo [OP] Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    Well, we actually use our trucks as trucks. You can keep your pavement queen with your non practical conveniences. Mine drives anywhere I need it too, fits 4 comfortably, and has a bed for cargo. All I need.
    OH, and my truck will out last a ford gasser any day of the week.
  7. Mar 1, 2016 at 9:54 AM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    You mean the power jokes? I'd rather be cummin than strokin :devil:
    grdgz97 and Scoobarooo[OP] like this.
  8. Mar 1, 2016 at 9:58 AM
    PackCon
    Connor
    o_O
    Not sure what you are trying to say.
    A midsize truck has serious limitations in terms of being used "as a truck".
    And a Tacoma doesn't fit 4 comfortably. At least not 4 adults.
    I'm not really into a F150 Limited Special Edition, but in terms of truck use, full-size beats out midsize any day of the week.
    I can't tow a 10,000lb trailer with a Taco. As much as I love mine, it really has limitations when hauling building materials, which is why I couldn't get rid of my 250. If I needed drywall, my Tacoma would do alright provided I was ok with going back and fourth to Home Depot 10 times.
  9. Mar 1, 2016 at 10:05 AM
    jim532
    jim532 .
    SoCal - 818
    2014 Prerunner V6 double cab
    all you guys are into F150 and Tacoma because you haven't experienced a real 4wd work truck such as the Honda Ridgline.
    Pmount, Nephree, ChesterTaco and 2 others like this.
  10. Mar 1, 2016 at 10:08 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Was this million mile Tundra a 6cyl or the v8?
  11. Mar 1, 2016 at 10:09 AM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    It looks like from the pictures that he has the 2UZ 4.7L V8 because the 5.7 has red on the side badges. So while that amount of miles is incredible if you were to expect any engine to do it it would be that one.
  12. Mar 1, 2016 at 10:17 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Did the Tundra reg cab ever come with the 2UZ or only v6?
  13. Mar 1, 2016 at 2:07 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Woo-hoo! I'm only 280 miles away from being 900,000 miles away.
    T-Rex266 and TRDSmacker like this.
  14. Mar 1, 2016 at 2:14 PM
    Thomas Jefferson
    Sacramento,CA
    '13 SR5 DCSB 4x4
    Oddly no. You could get it in a v6 or the 5.7 v8 but no 4.7/4.6 v8. Seems odd but they must have done the research on it.
  15. Mar 1, 2016 at 2:19 PM
    #35
    723rdCAT
    723rdCAT Well-Known Member
    Kentucky
    15 SR5 4x4 access cab mgm
    At Ramstien AB Germany my unit had a 1983 bobtail Ford F-350. It had as I recall 400,xxx on the odo. It had a gasoline engine. It ran fine the only issue was if you turned the steering wheel all the way left or right the power steering pump would overwhelm the engine. If you held for too long the engine would die.
    The issue increased under load and you couldn't use the truck to pull anything more than 10 tons so it couldn't pull the larger stuff like the engine stands for C-5s. But it worked great for errands around the base or as a back up when the two newer Rams with Cummins where already busy.
    The C-5 engine stands weighed about 19,000 pounds so even the Rams with Cummins worked pulling those. Of course we only needed to go 5 MPH on the flight line.
    Out trucks where very well taken care of so such milage would be the exception not the rule. Most drivers do not treat the vechiles they own well enough to reach 400K much less 1 million miles. Now a semi can do that easily there are trucks with well over 2 million still running.
  16. Mar 1, 2016 at 3:28 PM
    #36
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    No car guy admits to driving a Volvo though lol
  17. Mar 1, 2016 at 3:34 PM
    #37
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Well the owner is at over 3 million miles. Every million miles they've given him a new car but he doesn't drive them.
    MarX[QUOTED] likes this.
  18. Mar 1, 2016 at 4:21 PM
    #38
    MarX
    Mark
    NE Kansas
    Impressive, but I bet owner doesn't want to admit to getting another one lol.
  19. Mar 1, 2016 at 5:51 PM
    #39
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    :rofl:
  20. Mar 1, 2016 at 8:00 PM
    #40
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    125k a year is more than I've put on one vehicle. That's impressive for a V8 tundra but damn I would hate to know how much he spends on gas in a year.
    Cohutta and Scoobarooo[OP] like this.
