Milwaukee Tools
Discussion in 'Garage / Workshop' started by Sig45, May 20, 2020.
  1. May 10, 2022 at 7:14 AM
    #2381
    Toyko Joe
    Toyko Joe Here for the pictures
    I started out with a $149 brushed M12 impact, drill and oscillating tool when switching from Ryobi. I already had M18 Fuel 6 1/2” circular saw that I loved so I started to switch more tools over. Personally I started selling off tools I didn’t use to pay for the different to get more FUEL level tools. You don’t need Fuel level stuff, but the Fuel tools do have more features and a longer warranty. I’d say buy Fuel when it’s on sale as you need it.
  2. May 10, 2022 at 7:35 AM
    #2382
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Sig45[OP] likes this.
  3. May 10, 2022 at 7:40 AM
    #2383
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Starting new............
    How old are you?
    The reason I ask is twofold, M12 are much lighter and when you hit 64 or so, makes a HUGE difference. Plus, cost, batteries, etc..........how long you will use them all factors with age.
    I love my DeWalt 20V Max stuff and was a very early adopter...........it's now too late to go M18. The 20V max saws have been very good to me. Through a 6x12 beam yesterday...........
    That said I now own more and and wider variety of M12. I love the platform.
    If I started over at 40, I would go M18. But I have and love M12,and 20VMax
    Shitty answer. Sorry.
    Sig45[OP] and Toyko Joe like this.
  4. May 10, 2022 at 10:34 AM
    #2384
    tacoshell88
    tacoshell88 Not that well known member
    Michelle
    Somewhere along the Mexican border
    2021 DC Cement TRDOF
    Not sure. Maybe… I was just posting the deal.
  5. May 10, 2022 at 12:11 PM
    #2385
    thedutchtouch
    thedutchtouch rebmeM nwonK-lleW
    MD
    2013 DCSB TRDOR
    Not a shitty answer, important part of the equation. In my 30s so tool weight is not as big of a concern for me, though it's always a small factor. My understanding is brushed is lower quality than brushless but get somewhat lost when comparing the cost/utility/value of say m12 fuel vs m18 brushed. Also wondering if the comparison holds true across tools or if it varies by tool type how much the m12 vs M18 vs fuel of each vary in capability
  6. May 10, 2022 at 12:42 PM
    #2386
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    12v V. 18v is mostly about run time, and (depending on the tool) a bit about power. I have both an M12 and M18 Fuel driver & hammer drill set; I bought the M12 for a very specific job, assuming it wouldn't be great for every day use, but because of the significant weight saving with a 4ah M12 battery over an M18, it's become my go-to. The M18 tools, especially with a big battery get heavy quickly, so unless you need that capacity, in most cases, I would say M12 is fine. Not everything need be Fuel, no, but it's their top-flight brushless line, and FWIW, I always try and buy the best I can afford, where it matters. If it's a tool that's going to get regular or professional use, I would spend the extra $$ for Fuel versions. As for deals... you're on your own. You folks down in North Mexico get wayyyyyy better deals than we in the Frozen North(TM) .
  7. May 10, 2022 at 12:49 PM
    #2387
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    brushed vs brushless has to do with the efficiency, power and run time of the tool. Brushless tools can sometimes last longer in terms of useable life, although that depends on brand quality too.
    Tools are tools, the investment really depends on the user and the job vs the value.
    Pablo8 and Sig45[OP] like this.
  8. May 10, 2022 at 2:40 PM
    #2388
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    If you are considering the smaller m12 drivers, be sure to look at the m12 installation driver. It, with its offset and 90 degree heads get used more than any other driver for interior work. It also has a 3/8" drill head so it sort of does it all for small stuff. Perfect for installing cabinets or working on dishwashers where accessibility is more important than power. I have it and am glad I didn't get any other m12 drivers. That said, the clutch does give out pretty easily (highest setting is about right for a 3" drywall screw for affixing drywall, lower settings for cabinet hinges). This is all low torque, but that is on purpose. Higher than a 3" drywall screw requires you to use drill mode without a clutch. Also the top surface of the installation driver is very low profile, I just installed some casement window cranks with it and didn't have to even open the windows due to the offset head.
    For working of fences or exterior, m18 surge for fasteners and the m18 hammer drill are irreplaceable and top-notch where power is important. These 3 drivers cover just about everything up to I'd say a 3/4" dia, 12" long lag screw into a too-small predrilled hole into a railroad tie, then you need an m18 impact driver or wrench to finish it off.
  9. May 10, 2022 at 2:52 PM
    #2389
    dleriche
    dleriche Wanee Warrior
    D.J.
    Leander, TX
    2019 White ORD DCSB AT
    Love my m12 installation driver. My only complaint about it is the forward/reverse button on the top and not the traditional way on most drill/drivers. Takes some getting used to.
    tacoma_ca[QUOTED] and Sig45[OP] like this.
  10. May 10, 2022 at 3:07 PM
    #2390
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    I started with all m12 fuel. I have since gotten everything in the M18 fuel. I still like using the m12 circ saw and the impact driver for certain projects, but found I’d rather have more power the m18 offers the majority of the time.
    tacoma_ca and Sig45[OP] like this.
  11. May 10, 2022 at 3:24 PM
    #2391
    Brownmatthall
    2016 TRD OR DCSB
    Did I wait too long? :(
  12. May 10, 2022 at 3:53 PM
    #2392
    Brownmatthall
    2016 TRD OR DCSB
    Nevermind, just wasn't working on my phone for whatever reason. Wife pulled the link on her phone and it went through, pretty stoked on having an impact wrench finally. The ratchet set is just icing :D
  13. May 10, 2022 at 5:07 PM
    #2393
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Picked this up the other day
  14. May 11, 2022 at 6:20 AM
    #2394
    Toyko Joe
    Check out Northern Tool Deals. :eek: The stubby and hammer drill seem a little better than normal deals. :hungry:
  15. May 11, 2022 at 6:35 AM
    #2395
    Brownmatthall
    2016 TRD OR DCSB
    Oh cmon I just spent money on tools :anonymous:
  16. May 11, 2022 at 8:17 AM
    #2396
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Batteries.
    I pretty much don't buy (have plenty, don't use as much, etc) the small form factor M12 batteries anymore. Need more larger moar. :D:thumbsup:
    BTW the two generic 6 and 9Ah are still doing fine.
    https://smile.amazon.com/dp/B06XWVWT8J?ref=ppx_yo2ov_dt_b_product_details
    Sig45[OP] and Toyko Joe[QUOTED] like this.
  17. May 11, 2022 at 8:38 AM
    #2397
    Brownmatthall
    2016 TRD OR DCSB
    Hmm, I do need a new battery for my driver actually. I have a 4ah that's been dropped on and now sits crooked lol
  18. May 11, 2022 at 5:09 PM
    #2398
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Anyone have the M12 or M18 jobsite fan and use them for automotive? Looking to use it inside the car when doing dash work and such as well as underhood or anywhere else.
    DanishTaco and Sig45[OP] like this.
  19. May 11, 2022 at 5:12 PM
    #2399
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    I have the m18. Haven't used it in the particular situation you are talking about but it's definitely a nice tool. We use it working on vehicles in the summer and move it around to wherever we happen to be laying.
  20. May 11, 2022 at 5:14 PM
    #2400
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    D
    Do you think it would fit on the dashboard aiming at the front seats?
