Milwaukee Tools
Discussion in 'Garage / Workshop' started by Sig45, May 20, 2020.
  1. Oct 6, 2023 at 1:36 PM
    #3881
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    I wonder what sizes battery I had tried now, I will have to think about getting me a pair of those 3.0
    Sig45[OP] likes this.
  2. Oct 6, 2023 at 3:18 PM
    #3882
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    I'm not sure what size batteries wouldn't fit because of the belt clip. I sort of freaked when I read your initial post. I grabbed one the the HD CP3.0 I had just purchased and tried in my Impact Gun. Maybe @Sig45 can enlighten us on a battery that would cause a problem.
  3. Oct 6, 2023 at 3:37 PM
    #3883
    joeyv141
    Virginia
    This was around 4 years ago, its entirely possible they made the batteries narrower or made the clips extend more.
  4. Oct 6, 2023 at 3:41 PM
    #3884
    Sig45
    Sig45 [OP] Well-Known Member
    Mark
    Maine
    I'm not sure why any battery would interfere with the clip. All the batteries are the same width/profile.
    :notsure:
  5. Oct 6, 2023 at 4:11 PM
    #3885
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    It’s not possible at all. 5 years ago, they (Milwaukee) released the 12 ah HO battery, the largest 18v battery they dun make, and it fit the gen 3 impact driver and drill. It looks stupid, but it fits with no modification or need to remove the belt clip.
  6. Oct 6, 2023 at 4:20 PM
    #3886
    Kwikvette
    Fresno County
    4 run, 2 don't
    Old pic from years back when I used to have a Tacoma, you'll see my old impact with a belt clip on
    Was never an issue on the 2.0 or 5.0 batteries I had
  7. Oct 6, 2023 at 8:02 PM
    #3887
    dfanonymous
  8. Oct 6, 2023 at 8:16 PM
    #3888
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Gotta say I'm very disappointed with my Milwaukee "cobalt" drill bits. They cut nicely but they are so brittle that they snap very quickly. The set was a relatively reasonable price... but to buy an individual replacement bit it's outrageous.
    In the last week I had to drill 8 holes in some 1/4 steel strap and I snapped two bits on the first hole. So I dug around and found my dad's old set that I'm sure he must have bought fifty years ago at Kmart for a couple of bucks... and I finished the job. And the 3/8 bit has a quarter inch shank on it. You could feel the bit bite in and cut and after the job was done the bit went back into the plastic case with the broken hinge from being used for so many years, and it will be there next time I need a bit that works.
    These Chinese drill bits are crap.
    szidls and Sig45[OP] like this.
  9. Oct 6, 2023 at 8:22 PM
    #3889
    Kwikvette
    Fresno County
    4 run, 2 don't
    I hate to say this but, you sure it isn't you?
    I only use Milwaukee cobalt bits, and all I do is metal work
    The other day someone posted on FB needing to drill through solid metal rod and I answered; drilled through it without issue using bits I've used to drill out rivets with as well as spring steel.
    I put my bits through its paces and not a single one has ever snapped, both on a drill press as well as a hand drill. Using the same set for well over a year now and I've gone through as thin as 16 gauge to as thick as 3/8" and sometimes a bit thicker (like the 1/2" solid rod).
    soundman98 and Sig45[OP] like this.
  10. Oct 6, 2023 at 8:23 PM
    #3890
    Cement_wheels
    Sucks when a company with otherwise decent tools puts their name on junk.
    Edit: No personal experience so maybe not.
    Travlr[QUOTED] and Sig45[OP] like this.
  11. Oct 7, 2023 at 4:34 AM
    #3891
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Interested in your review of these.
  12. Oct 7, 2023 at 4:37 AM
    #3892
    Sig45
    Mark
    Maine
    Boy, they're really expanding the offerings. I'll stick with my ISOtunes or the low tech foam inserts.
  13. Oct 7, 2023 at 4:40 AM
    #3893
    Sig45
    Mark
    Maine
    Just ordered the M12 Fuel Jig saw to replace the non fuel. Tired of the base plate coming loose and the dust building up in front of the blade.
    Toyko Joe likes this.
  14. Oct 7, 2023 at 4:43 AM
    #3894
    545
    545 Well-Known Member
    2015 Access Cab
    cp 3.0, xc 6.0 and 8.0 and HD 12.0 all have 21700 cells instead of 18650, and because of that, are wider.
    Milwaukee didn’t originally plan for this, but they will replace all tools that have an issue-
    2787-20, 2788-20, 2771-20, 2122-20, 2130-20, 2135-20, 2361-20, 2145-20, 2146-20, 2360-20
    Just submit a warranty claim. Since 2018 they have all been compatible with every battery
  15. Oct 7, 2023 at 4:47 AM
    #3895
    Sig45
    Mark
    Maine
    Good to know. Thanks for sharing.
  16. Oct 7, 2023 at 7:36 AM
    #3896
    Cement_wheels
    3M Worktunes for me. Don't like sticking things in my ears when my hands are dirty. Didn't like it in the Army(earplugs), don't like it now. I will use the foams when I know I wont be taking them out and back in. I realize you don't have to touch the part of the earbuds that actually go in the ear, but still. YMMV
    Sig45[QUOTED][OP] likes this.
  17. Oct 7, 2023 at 7:45 AM
    #3897
    Travlr
    Middle'a Utah
    Well that might be a valid question, but how would I know? When I can use fifty year old drill bits without any issues, doing the same job I would do with the newer bits and getting great results... what am I doing wrong?
    And really... are we saying that there has to be some kind of learning curve nowadays to properly use drill bits that have been made recently... that didn't exist back when they made drill bits that anyone could use with good results?
    I've only used two size bits from the set of Milwaukee drill bits and I've snapped both and replaced them, and snapped the 3/8 replacement again. And I haven't drilled more than ten holes with either bit. They cut great... until they snap.
    But I can't tell you how many holes I've drilled with the older set of bits and they cut and last.
    So tell me... what's the difference?
  18. Oct 7, 2023 at 8:09 AM
    #3898
    Kwikvette
    Fresno County
    4 run, 2 don't
    Exactly why I said "I hate to say this.."
    But again I only do metal work and it's on both thick and thin, mild and spring steel, aluminum, a bit of stainless, and add to that solid metal rod
    Like them so much I even have a step drill or two of theirs as well as larger individuals bits
    Both on the drill press (excuse the mess)
    And hand drill
    Those bits are over a year and a half old and if any were to have broken by now, it'd be these smaller ones who's finish is gone
    That's mainly because some of the shit I've clamped onto my press was rounded and would cause my bit to bend outward as it bit into the metal and it still never broke
    Guess it's one of those "your mileage may vary" but yes I do believe there's a right way and wrong way to use bits when drilling into metal; I doubt at this point you've done it the wrong way by the sound of things but I don't know...weird that I pretty much abuse my bits and never had any break
    Delta09, soundman98 and Sig45[OP] like this.
  19. Oct 7, 2023 at 8:18 AM
    #3899
    Travlr
    Middle'a Utah
    I'd have thought I got a bad "lot", a run of bits that were made from faulty stock, except that the replacements have snapped too. And they've shattered in both the hand drill and the drill press now.
    I went down to the local welding shop (a BIG outfit) last week and told the owner about my experience and disappointments, and asked him what kind bits he uses... and he says he can't find any decent drill bits that are made nowadays. They buy them in bulk from several sources and discard a lot because they break.
    Sig45[OP] and Cement_wheels like this.
  20. Oct 7, 2023 at 8:37 AM
    #3900
    Kwikvette
    Fresno County
    4 run, 2 don't
    Well shit, I hate hearing someone's hard earned money going to waste.
    The owner and boss of one shop I worked at had these old bits that he would actually sharpen instead of replacing. Takes some years of experience but it helps to really save money and you could get a bit to last you for many years of constant use.
    I lack that skill so I just buy my bits and I've always used that set I posted. In fact I took all those pictures this morning just for you.
    A lot of the stuff I've drilled into and repaired are posted in the welding section since I'm a fabricator.
    Sig45[OP] and Travlr[QUOTED] like this.
