Milwaukee Tools
Discussion in 'Garage / Workshop' started by Sig45, May 20, 2020.
  1. Mar 13, 2024 at 6:09 PM
    #4541
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    Damn I'm surprised it wouldn't loosen your caliper bolts
    Sig45[OP] likes this.
  2. Mar 13, 2024 at 8:19 PM
    #4542
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Me too. Sad thing is I live in the high desert with no rust AND I had removed/replaced the calipers only a couple months prior (torqued to spec when installed). Like I said, very underwhelmed by the right angle impacts performance.
  3. Mar 13, 2024 at 8:50 PM
    #4543
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I don’t think 3/8” battery drive anything is a serious tool for breaking loose nuts/bolts and a rt angle version even less so. They make 1/2” drive versions for that purpose. Anything less is a convenience tool. Compact, lightweight, less expensive but at a cost in performance. Good for many things and even better at some but sometimes you just need a bigger hammer. I’ve been eyeing an upgrade myself for driving LDT’s and GRK concrete lags and though $200 seems better than $300 it would not be a bargain if it still couldn’t get it done.
  4. Mar 14, 2024 at 1:01 AM
    #4544
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    Worst Milwaukee tool I’ve ever bought. I hate it. It’s such a piece of shit you would think it’s counterfeit. I’m embarrassed to even mention I own one. I should just put it in the boat for a fish bonker.
    Gen1FTMFW[QUOTED] and Sig45[OP] like this.
  5. Mar 14, 2024 at 1:34 AM
    #4545
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    You said “battery” kind of spicy…like a 3/8s air is somehow pushing significantly better numbers in a similar class…
    I get this is the Milwaukee fandom/cult section here, but, the dewalt 20v max 3/8 stubby can bust nuts at over 450 ft lbs…
    I mean that’s getting close to pushing the strength of an 3/8th anvil itself. Pneumatics aren’t doing anything different. The aircat is what? 500 maybe? Pssf
    soundman98, Gen1FTMFW and Sig45[OP] like this.
  6. Mar 14, 2024 at 5:04 AM
    #4546
    Toyko Joe
    Toyko Joe Here for the pictures
    I’ve never used one, but I saw three in use the last time a transformer was swapped out at the factory by the power provider. They had two other Milwaukee electricians tools cable insulation jacket removal tool and crimping tools and a one Mikita cable cutter.
  7. Mar 14, 2024 at 8:11 AM
    #4547
    bagleboy
    Scott
    Norcal, Santa Rosa
    Maybe a bit. If you buy a tool to save weight sometimes all you get is less tool. And the whole 20V thing is just branding. 18 & 20V batteries both have 5-cell packs that max at 4.2V/cell. 18V is just the average charge during use which starts at 21V full and drops to 15V depleted. Thicker packs have 2-parallel sets of 5 cells to increase the amp-hours.
    jeezumcrow, soundman98 and Sig45[OP] like this.
  8. Mar 14, 2024 at 8:56 AM
    #4548
    dfanonymous
    You buy the cordless tool to cut the cord for the convenience, and you accept that it requires a battery pack. You buy a stubby for the size.
    I don’t think anybody is out there getting tennis elbow from mid torque and below impacts.
    I’m aware of the nominal voltages as well as the max charge. Nobody was talking about that. Dewalt has 18v tools in the US. They are old but they still exist. 20v max is a seperate platform, and they also make 12v tools of similar models. So by saying the 20v max stubby…I mean…that model.
    Now with stacked lithium, in that same tool you have a battery that weighs significantly less with higher discharge.
  9. Mar 14, 2024 at 9:18 AM
    #4549
    Gen1FTMFW
    Exactly this. I don't fish anymore, so for me it's just an expensive paper weight.
  10. Mar 14, 2024 at 10:18 AM
    #4550
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    It should be a sticky on top of this thread on a do not buy list.
  11. Mar 14, 2024 at 11:05 AM
    #4551
    Toyko Joe
    Or at least not for automotive uses. I still see lots of value for linemen and electricians. Just my $0.02.
  12. Mar 14, 2024 at 1:49 PM
    #4552
    Gen1FTMFW
    As an electrician, I hate and despise the right angle impact. I actually hate most impacts since the majority of the time they aren't really needed (for electrical specific work, could make an argument for rough in). Too many folks use impacts for panel hardware, DIN rails etc that is just overkill and end up causing more damage.
  13. Mar 14, 2024 at 3:45 PM
    #4553
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    I mean I’m a concrete guy, I could use it to beat stakes in:rofl:
  14. Mar 14, 2024 at 6:11 PM
    #4554
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
  15. Mar 14, 2024 at 6:31 PM
    #4555
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    It’s like the low voltage technicians I work with mounting TV’s that don’t predrill the lag bolts and just hammer drill them in and don’t stop until there are nail pops everywhere.
  16. Mar 14, 2024 at 6:31 PM
    #4556
    Gen1FTMFW
    Yeah. I could see how it is a more useful tool as a hammer, haha.
  17. Mar 16, 2024 at 6:56 AM
    #4557
    98tacoma27
    Ben
    Not Beech Creek
  18. Mar 16, 2024 at 5:29 PM
    #4558
    dfanonymous
  19. Mar 16, 2024 at 5:31 PM
    #4559
    LarryDangerfield
    Tyler
    Northern Wisconsin
    :eek:
  20. Mar 16, 2024 at 5:36 PM
    #4560
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    I have a M18 3/8 stubby and I don't care for it's torque performance either. Anywhere it fits my M18 3/8 mid torque fits and packs way more of a hit. AKA brake caliper bolts. Now granted I'm usually using swivel sockets to get in there correctly but the 3/8ths stubby leaves a bit to be desired. Which is weird, as it will break my lug nuts loose easily but struggles on some suspension stuff.
