Milwaukee Tools
Discussion in 'Garage / Workshop' started by Sig45, May 20, 2020.
  1. Mar 16, 2024 at 5:40 PM
    #4561
    Toyko Joe
    Toyko Joe Here for the pictures
    :benchpress:
    :eek::annoyed::goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy::militarypress:
  2. Mar 16, 2024 at 5:59 PM
    #4562
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    Where did you find this deal ?
    Sig45[OP] and LarryDangerfield like this.
  3. Mar 16, 2024 at 6:26 PM
    #4563
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    Home Depot. They’ve been blowing them out pretty much across the lower 48. My local HD was sold out, but a HD a few towns over had it.
    edit: as far as narrowing down which store has inventory; I use BrickSeek.
    Sig45[OP] likes this.
  4. Mar 16, 2024 at 6:35 PM
    #4564
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Grabbed this the other day
  5. Mar 16, 2024 at 6:37 PM
    #4565
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Best way to buy additional batteries is usually to buy a tool kit. Generally the tool ends up NC compared to just buying batteries alone.
  6. Mar 16, 2024 at 6:39 PM
    #4566
    Kbar
    Western WA
    22 OR
    There’s always a holiday package deal with batteries and or another “free” tool
  7. Mar 16, 2024 at 6:59 PM
    #4567
    dfanonymous
    the best way, especially if you have all the tools is to get a special buy, buy the kit like you suggest, then return the tool you don’t need for the prorated price.
    The breakdown looks like this:
  8. Mar 16, 2024 at 7:38 PM
    #4568
    Kbar
    Western WA
    22 OR
    I “need” all the tools
    Sig45[OP] and T-Rex266 like this.
  9. Mar 17, 2024 at 8:16 AM
    #4569
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    and you should be grabbing this soon ;) [​IMG]
    Sig45[OP], Toyko Joe and Kbar[QUOTED] like this.
  10. Mar 17, 2024 at 8:49 AM
    #4570
    Kbar
    Western WA
    22 OR
    Definitely on my shopping list. My dumb ass looked at one last time I was there but didn’t grab it.
  11. Mar 17, 2024 at 9:26 AM
    #4571
    soundman98
    NW Indiana
    if i had known hf was working on it, i would've waited.
    i got the big boy instead.
    Sig45[OP] and Kbar[QUOTED] like this.
  12. Mar 17, 2024 at 9:40 AM
    #4572
    Kbar
    Western WA
    22 OR
    Saw that too. Problem is real estate. My garage is crammed full and I’m not building a shop with today’s inflation so yea. A dedicated bandsaw will be on my radar. I been looking at Jet saws. I got the little red drill press from HF and although it’s not that powerful, it beats hand drilling through thick steel. Plus that M18 drill I got almost broke my wrist lol
  13. Mar 17, 2024 at 9:42 AM
    #4573
    Kwikvette
    Fresno County
    4 run, 2 don't
    Does it cut square? I had to modify mine some 2+ years ago.
  14. Mar 17, 2024 at 12:13 PM
    #4574
    soundman98
    NW Indiana
    with the cut size of the larger hand-held bandsaws, that mounting rig would be more than enough for most needs up to about 4" square stock, which is plenty large enough for most home shops. i don't cut anything larger than that at work building trucks.
    my issue was that i have the m12 band saw, and a sawzall, but lacked a method of cutting anything beyond handheld accuracy, or a method to controlling blade deflection.
    2 years ago when i got it, swag offroad was the only one that offered a mounting option for handheld bandsaws, and it's designed for table top use, not longer stock cutting.
    https://www.swagoffroad.com/products/swag-portaband-pro-table
    i'm definitely at a space premium as well. the bandsaw went into the basement, which is entirely inconvenient for most of the projects that i build in the garage. and it's too heavy to be moving back and forth. it's a big pain to drag stuff down there to cut, then drag it back up to the garage. but i'm already pushing the limits of capabilities of my garage, so it can't live in the garage either...
    now i'm looking at a press for forming/bending, and that must find a home in the garage somehow...
    close enough. most of the projects i've done on it so far involved using it in the upright metal bandsaw mode, which i built a slide jig for to keep cuts square.
    i've only just recently broken into larger stock projects, but haven't needed to mate 2 edges together, so haven't compared how far off it is.
    the jet band saw at work measures square, but cuts about 3/32" off square. i just plan accordingly when using it. close enough, nothing a flapper disc can't fix!
    Kbar[QUOTED] and Sig45[OP] like this.
  15. Mar 17, 2024 at 12:18 PM
    #4575
    Kwikvette
    Fresno County
    4 run, 2 don't
    Gotcha, was considering their larger model as I have the older version you have.
    The guide is what I modified (easily) and it gives me really nice square cuts, but often times find myself needing something bigger so either look into their larger model (if it cuts reasonably well) or pony up for an Ellis.
    Kbar and Sig45[OP] like this.
  16. Mar 19, 2024 at 5:57 AM
    #4576
    BirchyBoy
    BirchyBoy Well-Known Member
    ‘20 Tacoma SR DCSB
    Sig45[OP] and TuRDLYFE like this.
  17. Mar 19, 2024 at 4:50 PM
    #4577
    soundman98
    NW Indiana
    i tend to avoid those, especially after the whole scam of the $29.99 laser rust removal tool-- those start at $13,000.
    i would suggest checking etsy or similar, as there's more chance your purchase will benefit an individual, instead of feed the next ad cycle.
  18. Mar 19, 2024 at 4:57 PM
    #4578
    Kwikvette
    Fresno County
    4 run, 2 don't
    Another company posted in this thread offering the same.
    It isn't hard to cut something like that as the cost of raw materials is much cheaper than the asking price.
    Once you've got a design, it's just rinse and repeat.
  19. Mar 19, 2024 at 4:58 PM
    #4579
    mysubiewasalemon
    Lol 13k is for the most bootleg China ones . My company was quoted 85k+ for a German made one and 135k for USA made
    soundman98[QUOTED] and Sig45[OP] like this.
  20. Mar 19, 2024 at 7:43 PM
    #4580
    soundman98
    NW Indiana
    all i know is i started looking into consumables, saw that just one common consumable is $2,500, and realized that the entire package for $30 is a scam--i admit, i really was close to purchasing it, but something told me it was too good to be true somehow.
    and once i saw the consumable price, i then understood that facebook allows anyone to knowingly scam everyone with products that can't exist, and trust in their advertisements turned me from low to lol.
