Milwaukee Tools
Discussion in 'Garage / Workshop' started by Sig45, May 20, 2020.
  1. Jun 24, 2024 at 1:17 PM
    #4861
    Kwikvette
    Fresno County
    4 run, 2 don't
    Seen that site referenced here many times
    The odd formatting has kept me away...
    Sig45[OP] and T-Rex266[QUOTED] like this.
  2. Jun 24, 2024 at 5:45 PM
    #4862
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    it's my solution to what i saw as a problem.
    when i bought the place, the backup pump went out through the wall to the back yard, but only by about 6'. so if the backup were to ever kick in, it would empty the pit to the other side of the basement wall, which would then delay, but drain right back into the pit, repeating the process, but adding rainwater as well. it was also really irritating to have to mow around a pipe sticking out of the wall.
    i wye'd the backup into the main pump sewer output so that if the backup kicked in, it would actually get rid of the water to the original sewer line, instead of just regurgitating it to the other side of the wall.
    the pipe between the two before the check valves are nothing actually-- it's just a support for the pvc lines. i tried being fancy, and hole-sawed it like i was building a roll cage, hoping the surfaces would match up close enough that the glue alone would tie the pieces together. it didn't. which is why the zip ties are there. there's actually 3 tie-together pieces like that, the second is visible just at the top of the hole.
    it also helps support the backup pump-- the primary pump is sitting on the floor of the pit, and then the backup pump hangs off the pvc discharge pipe about 12" up. to give the primary pump the best shot first, with the backup being a 'worst case' take-over pump.
    i should note that i'm in a very sandy area, and at the top-most part of my block. either end of the block is about 4' lower than me. so my sump very rarely kicks in except at the most extreme rainfall events. i also share the power grid with the main school district buildings, so my power is quite reliable, and a high priority to get back running if it ever goes out.
    so that said, my backup battery ran into it's 5 year life span about 2 years ago, and i've since disconnected the backup pump-- it's just not needed enough given my location.
    Sig45[OP] likes this.
  3. Jun 24, 2024 at 6:16 PM
    #4863
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    Ok, I thought it was some way of venting it. I bought the main and backup as one unit. One pipe going out. When it drains and the pump stops it creates some kind of suction and the check valve flaps up and down. Really only goes off in the spring time around April but a lot. Then bone dry for the rest of the year.
    Sig45[OP] and soundman98[QUOTED] like this.
  4. Jun 25, 2024 at 5:33 PM
    #4864
    Pyrotech
    Pyrotech Well-Known Member
    The only decent piece I have left, is my McIntosh Mac-4100
    Been collecting parts to repair it, the Am Ferrrite antenna is broken, and some worn out jacks on the back. but I have a really nice back panel I picked up that will get swapped in. along with a recap.
  5. Jun 25, 2024 at 5:34 PM
    #4865
    Kwikvette
    Fresno County
    4 run, 2 don't
    Amp? Preamp? Integrated?
    I haven't rolled McIntosh gear in forever
  6. Jun 25, 2024 at 5:39 PM
    #4866
    Pyrotech
    Integrated.. Am/FM along with two phono Preamps and 2 Aux inputs
  7. Jun 25, 2024 at 5:42 PM
    #4867
    Kwikvette
    Fresno County
    4 run, 2 don't
    I see some MIT multicaps and Holco resistors in your future ;)
    Pyrotech[QUOTED] and Sig45[OP] like this.
  8. Jun 30, 2024 at 3:37 PM
    #4868
    Toyko Joe
    Toyko Joe Here for the pictures
    Went back to work on the dock. I used the hackzall m12 mostly. :sawzall:I was cutting into the seawall mostly 3x12 pressure treated I should have brought the chainsaw. I am Poooped. The heat was enough. At the end of the day it will be nice but man I picked a hot day.
  9. Jun 30, 2024 at 3:55 PM
    #4869
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Last time I used my m12 hackzall the electrician asked me if I had it in milking it mode :rofl: it got the job done but wasn’t fast doing it.
  10. Jun 30, 2024 at 4:01 PM
    #4870
    YotaKid
    YotaKid Well-Known Member
    AZ
    2017 SR 4x4
    I use this as a lighter alternative to my m18 stuff. Sometimes you don’t need a huge impact or drill. The 90 head is handy as well.
    Sig45[QUOTED][OP] likes this.
  11. Jun 30, 2024 at 4:08 PM
    #4871
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I don’t know if ya’ll have been paying attention to pipeline, but there’s been some cool things that will be released in the next year or so.
    new rear handle saw seems cool. I think the current one kind of sucks compared to, pretty much all the others really, imo.
    The first m18 roofing gun coming out too.
    And of course a ton of different light options.
  12. Jun 30, 2024 at 4:12 PM
    #4872
    YotaKid
    AZ
    2017 SR 4x4
    Milwaukee tools and Toyota Tacoma go together like cheese and crackers.
  13. Jun 30, 2024 at 4:19 PM
    #4873
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    Couldn’t help myself. It’s true. It’s funny. And I like the tools.
    YotaKid, Marty65, soundman98 and 2 others like this.
  14. Jun 30, 2024 at 4:26 PM
    #4874
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    Hmmmm, with the high lake levels we have right now, I’m thinking adding a backup system too. I need to see what’s out there.
    soundman98[QUOTED] and Sig45[OP] like this.
  15. Jun 30, 2024 at 5:47 PM
    #4875
    Sig45
    Sig45 [OP] Well-Known Member
    Mark
    Maine
    I'd love to see a cordless siding/fencing gun.
    dfanonymous[QUOTED] likes this.
  16. Jun 30, 2024 at 5:59 PM
    #4876
    Sig45
    Mark
    Maine
    Yes, I purchased it quite some time ago and it's my go to for light duty work, kitchen cabinets/hardware, etc. The ergonomics alone make it a winner in my book.
  17. Jun 30, 2024 at 10:13 PM
    #4877
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Still getting settled into mine, but definitely have a long way to go to keep everything organized. Need a lot of shelf, wall and modular storage options to keep enough room to use the lift effectively.
    The unit pictured below has done that from day one for me. Has yours ever automatically connected? I just assumed it came from the factory that way (manual BT connection each time).
    Appreciate the recommendation. Just added this to my cart.
  18. Jun 30, 2024 at 10:47 PM
    #4878
    dfanonymous
  19. Jul 1, 2024 at 4:16 AM
    #4879
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    At first it autoconnected and all a sudden it wouldn’t one day. I hit the BT button for 2 seconds and the phone prompt. After several attempts it finally paired and gave the distinct “low tone -medium tone” sound it makes when it successfully pairs with my phone. Ever since then, (about a month after purchase) I gotta manually re pair them. Sometimes it takes up to 3 tries to get them to pair. I remember researching this issue and found some Reddit posts saying it was common with this particular model and some folks couldn’t ever get it to pair.
  20. Jul 1, 2024 at 5:32 AM
    #4880
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Love the garage! The best house will have a rv garage (or close to) JUST for my tools, and it’ll be a full detail setup
    Sig45[OP] and Marty65 like this.
