Milwaukee Tools
Discussion in 'Garage / Workshop' started by Sig45, May 20, 2020.
  1. Jul 5, 2024 at 10:50 AM
    #4901
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
  2. Jul 6, 2024 at 4:40 AM
    #4902
    Sig45
    Sig45 [OP] Well-Known Member
    Mark
    Maine
  3. Jul 6, 2024 at 6:07 AM
    #4903
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    I've got a really nice (I.E. expensive) Bostitch siding nailer that I probably couldn't sell for enough to justify the Milwaukee nailer. Even dragging around the 150' air hose isn't troublesome since discovering Flexzilla polymer hose.
  4. Jul 6, 2024 at 6:11 AM
    #4904
    Sig45
    Mark
    Maine
  5. Jul 6, 2024 at 6:14 AM
    #4905
    Sig45
    Mark
    Maine
    FYI - I have job this fall where I need to replace a fair amount of cedar clapboards and cedar shakes up on some dormers. It's all ladder work. Was looking for alternatives to manual hammer and SS siding nails to speed things up.
    I'm all cordless now and no longer have a compressor. I'm not building houses, doing big jobs, etc. so cordless works for my needs.
  6. Jul 6, 2024 at 10:05 AM
    #4906
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    It doesn’t. It’s a roofing nailer.
    it has the attachment to do vinyl siding. It doesn’t shoot siding nails.
    Sig45[QUOTED][OP] likes this.
  7. Jul 6, 2024 at 12:59 PM
    #4907
    BDSKJChris
    BDSKJChris Well-Known Member
    Albany, NY
    2019 Quicksand TRD OR DCSB
    Tested out the m12 tire buffer yesterday to patch a wrangler duratrac, the tool works very nice. It would be great if milwaukee made some 7/16 hex shank arbors to hold burrs to go along with the tool, having to make my own was less than ideal.
    soundman98 and Sig45[OP] like this.
  8. Jul 6, 2024 at 3:40 PM
    #4908
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Sig45[OP] likes this.
  9. Jul 6, 2024 at 6:52 PM
    #4909
    Toyko Joe
    Toyko Joe Here for the pictures
  10. Jul 7, 2024 at 6:37 AM
    #4910
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i would suggest a drill operated pump, more like this: hot tubs are a ton of water, having alternate options other than an obscene stack of m12 batteries is always better.
    ideally, a pump like this works better, as it still can use a garden hose output, but runs on 120v so it can run almost indefinitely. but it's $100.
    https://www.homedepot.com/p/Everbilt-1-3-HP-Automatic-Utility-Pump-EBAU33/308510354
    the m12 would work, but is really intended for remote operations where main power isn't available. a hot tub is going to have power nearby, so the battery options are really sort of 'extra'.
    Kbar[QUOTED] and Sig45[OP] like this.
  11. Jul 7, 2024 at 6:58 AM
    #4911
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Soooo I used to sell a good bit of the Paslode battery/gas tools. They're great if you don't let them sit. It will gum up and be rendered useless if it sits. I've torn many apart and cleaned them.
    Even though you're gonna be going up and down a ladder I'd recommend an air powered tool. Chances are it'll still work after sitting around.
    soundman98 and Sig45[QUOTED][OP] like this.
  12. Jul 7, 2024 at 9:02 AM
    #4912
    Sig45
    Mark
    Maine
    Thanks for the Insider Intel.
    Delta09[QUOTED] likes this.
  13. Jul 7, 2024 at 9:32 AM
    #4913
    Kbar
    Western WA
    22 OR
    I have a utility pump like that. I then use a shop vac to clean up the seat wells and the low spots the drain doesn’t let out. We’re only talking a couple gallons
    Sig45[OP] and soundman98[QUOTED] like this.
  14. Jul 7, 2024 at 4:35 PM
    #4914
    Cement_wheels
    This is what I like about my Bostitch. I oil it (air tool oil) before every use and it only seems to run better over time. When I used it last year to repair my picket fence it had sat for probably 5 years. Loaded the nails, ran some oil through it and no problems.
    Sig45[OP] and Delta09[QUOTED] like this.
  15. Jul 7, 2024 at 5:55 PM
    #4915
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    I hope you guys will forgive me but I pulled the trigger on some Ryobi tools to compliment my Milwaukee tools. Grabbed a battery kit with "free tool" deal. It was two, four amp hour and a 2 amp hour battery kit. Chose the pruning tool as the free tool. Mainly wanted Ryobi batteries for the clamp fan they offer. At off-road races when it's hot it looks like it'll be perfect. Not only does Milwaukee not offer a fan that interests me for that application but also if someone were to steal the fan and/or batteries I would rather it be Ryobi they are stealing than my Milwaukee stuff (Sure hope they don't steal anything though lol)
  16. Jul 7, 2024 at 5:57 PM
    #4916
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I've had one air tool failure over the years. I had a 16ga strait nailer that my grandfather had for years and I assume never oiled it. The plastic piston seal thing crumbled apart one day. I just bought a Harbor Freight replacement as I'm useless hand nailing things :rofl:
  17. Jul 7, 2024 at 6:04 PM
    #4917
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    They make adapters to use Ryobi with Milwaukee Batteries
  18. Jul 7, 2024 at 6:06 PM
    #4918
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Better watch your step... the Mod's might BAN you!!
    Oh.... wait a minute o_O o_O :D
  19. Jul 7, 2024 at 6:27 PM
    #4919
    crazychris4124
    crazychris4124 Earn those pinstripes
    Westchester County, NY
    '17 Inferno Moneypit
    Too many but also not enough mods
    what do you guys think of the Milwaukee 1/2" High Torque impact guns??
  20. Jul 7, 2024 at 7:39 PM
    #4920
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    Awesome power but is to large for some high torque small place usage. Think removing a stuck crankshaft bolt with the radiator in place.
