Milwaukee Tools
Discussion in 'Garage / Workshop' started by Sig45, May 20, 2020.
  1. Jul 7, 2024 at 7:39 PM
    #4921
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    like this?
    https://www.milwaukeetool.com/Products/2767-20
    just like everything else, i'd love for it to be more, but otherwise works on 98% of everything i use it on.
    and if it don't take it off, i'm already planning for the torch, BFH, and my long breaker bar with add-on cheater bars, and getting a replacement bolt, because it's not going back together how it's coming apart.
  2. Jul 7, 2024 at 7:52 PM
    #4922
    crazychris4124
    crazychris4124 Earn those pinstripes
    Westchester County, NY
    '17 Inferno Moneypit
    Too many but also not enough mods
    which m18 impact do you recommend? mostly using it for lugnuts
    Sig45[OP] likes this.
  3. Jul 7, 2024 at 7:54 PM
    #4923
    Kwikvette
    Fresno County
    4 run, 2 don't
    Definitely don't need high torque for lugnuts
    I've got a first gen M18 mid torque that I use for lugnuts, and on the trail many times
    Still runs like new years later
  4. Jul 7, 2024 at 8:00 PM
    #4924
    crazychris4124
  5. Jul 7, 2024 at 8:02 PM
    #4925
    Kwikvette
    Fresno County
    4 run, 2 don't
  6. Jul 7, 2024 at 8:33 PM
    #4926
    crazychris4124
    ok thanks, looks like I can get it with (2) 6.0 packs and charger for $270
  7. Jul 7, 2024 at 8:35 PM
    #4927
    Kwikvette
    Fresno County
    4 run, 2 don't
    Home Depot hack deals are normally the best way to go for the most savings
  8. Jul 8, 2024 at 1:32 AM
    #4928
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    The mid torque impact has plenty of power for 80% of vehicle work. If you get the m12 stubby impact its a good small companion to the mid torque impact.
  9. Jul 8, 2024 at 4:53 PM
    #4929
    crazychris4124
    or just get this??
    Only need something for when I or someone else needs their wheel replaced on the trails
    https://www.homedepot.com/p/GEARWRE...-lbs-Electronic-Torque-Wrench-85076/310123712
  10. Jul 8, 2024 at 5:00 PM
    #4930
    soundman98
    NW Indiana
    torque wrenches are only as good as their last calibration date.
    harbor freight has some click type torque wrenches that can be had for $10-20 at different sales times. i would suggest one of those first to see if you use it before blowing the money on a fancier $150 version.
    but torque wrenches are really only for the last final tightening step. it won't help at all for wheel removal or initial installation.
  11. Jul 8, 2024 at 5:05 PM
    #4931
    joeyv141
    New Jersey
    What type of work are you doing needing a torque wrench? Honestly I pretty much only use mine for internal engine/transmission bolts.
    The click type ones are probably a better bet if your not using it regularly.
  12. Jul 8, 2024 at 5:06 PM
    #4932
    crazychris4124
    Just repairs on the trail, probably go out once a month or two
  13. Jul 8, 2024 at 5:13 PM
    #4933
    joeyv141
    New Jersey
    I definitely would not bother bringing a torque wrench on a trail run. While every single bolt and nut has a torque value including valve stem nuts, the radio antenna, and the internal trim bolts. You get a feel for how tight is right fairly quickly and 95% of bolts/nuts do not require a exact torque. Spark plugs for example have a exact torque spec but when you buy new ones there is an acceptable torque range listed on the box.
    soundman98, Sig45[OP] and Kwikvette like this.
  14. Jul 8, 2024 at 5:17 PM
    #4934
    Kwikvette
    Fresno County
    4 run, 2 don't
  15. Jul 8, 2024 at 8:31 PM
    #4935
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    How do you feel the 235# for the axle nut or 90# for the lower spindle bolts after trail swapping a CV? Can you hit 235 with a normal 1/2 ratchet wrench or just let the Milwaukee high torque eat.
    Gen1FTMFW and Sig45[OP] like this.
  16. Jul 9, 2024 at 2:34 AM
    #4936
    joeyv141
    New Jersey
    Its a bitch torquing a axle nut down with a torque wrench cause you have to hold the hub still and need a lot of leverage to hit 235 ft/lb, not something I would do on a unlevel muddy trail side. I would just run the m18 mid or high torque till it doesn't tighten any more.
    Edit - realized I dont think I answered your question. I would rather the high torque for a axle nut especially for breaking it loose but with the mid torque and fully charged battery I would trust it to remove and tighten a axle nut assuming its not rusted in place after 10+ years.
  17. Jul 9, 2024 at 5:57 AM
    #4937
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    If you’re running around with a big ass rattle gun for wheel nuts you better grab some torque sticks. I love my 2767 but I use my 1/4” 2757 more.
  18. Jul 9, 2024 at 11:01 AM
    #4938
    Kwikvette
    Fresno County
    4 run, 2 don't
    New M12 hedge trimmer arrived
    This thing is sweet
    dleriche, w.adventures, Kbar and 2 others like this.
  19. Jul 9, 2024 at 2:04 PM
    #4939
    Kwikvette
    Fresno County
    4 run, 2 don't
    Didn't get a before pic, so here's a quick screenshot of the lavender plants I trimmed down
    Freaking thing was huge and would get in the way when bringing stuff in or walking the stroller out
    The trimmer was quick to trim it all down
    It's 102 degrees out though so actual trimming of everything else will be done on another cool morning; ain't going to do that shit now
    My only gripe is how unbalanced it is; this is because you need to use your wrist to manipulate it at different angles for trimming stuff like this down
  20. Jul 9, 2024 at 2:15 PM
    #4940
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Nice. I've been putting off trimming out front as I have an old school PITA corded version.
    As for your gripe... what size battery are you using? My bro in-law had the same complaint with the leaf blower until I recommend he use a larger battery.
