Milwaukee Tools
Discussion in 'Garage / Workshop' started by Sig45, May 20, 2020.
  1. Jul 10, 2024 at 2:21 PM
    #4961
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    The m12 1/4 hex impact driver is great for mechanic work, I use it regularly for fasteners up to 11mm, I have never used the surge ones so don't know how it compares. 13mm requires the m12 3/8 stubby
  2. Jul 10, 2024 at 2:56 PM
    #4962
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    A couple weeks ago I had to trail fix a CV. I was pulling my skids with my 12v 3/8 impact and one guy had the Dewalt 1/4 hex and popped on a 1/2 adapter and the 35mm socket and busted loose the axle nut. I was pretty shocked it got it let alone didn’t break the little adapter.
    Sig45[OP] likes this.
  3. Jul 10, 2024 at 4:31 PM
    #4963
    joeyv141
    New Jersey
    Goddamn thats impressive a 1/4 hex shaft didn't break loosening a 35mm, as a mechanic I guess most CV nuts I remove are rusty and stuck on place from the factory however many years ago.
  4. Jul 10, 2024 at 4:55 PM
    #4964
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    I had it apart a couple months ago replacing a axel
    seal.
    Sig45[OP] and joeyv141[QUOTED] like this.
  5. Jul 10, 2024 at 5:36 PM
    #4965
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    the non-service-service manual, while not showing the internals, has plenty of warnings indicating what's inside.
    https://documents.milwaukeetool.com/54-00-2745.pdf
    basically, they're using a charged gas cylinder as the force, and the brushless motor is being used to ratchet the gas cylinder upwards in it's travel, with the trigger releasing the cylinders force one notch every time.
    Sig45[OP] and GilbertOz[QUOTED] like this.
  6. Jul 10, 2024 at 5:42 PM
    #4966
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Interesting. Aye, I found a take-apart video. Didn't realize that -- apparently, according to this youtuber -- this style of electric nailgun loses a little gas pressure with every shot, and eventually needs recharging.
    I do not condone this video, dude is winging it, recharging with air, doesn't have a PSI specification, just winging it with first 150 PSI, then 180PSI, then eventually 210PSI. Does it even use air? Maybe it's supposed to be charged with dry nitrogen or something?
    FWIW my M18 framing nailer has around 5K shots on it since purchase a year ago, still seems to be operating fine & normally.
    https://www.youtube.com/watch?v=w03AfVsp8TM
    This guy only recharged his repaired M18 framing nailer to 160 PSI...
    https://www.youtube.com/watch?v=-xCEuIKXkeo
    soundman98[QUOTED] and Sig45[OP] like this.
  7. Jul 10, 2024 at 5:46 PM
    #4967
    Toyko Joe
    Toyko Joe Here for the pictures
    I’ve had a paslode framing nailer for 12 years at least. Worth every penny I paid for it. I bought ryobi trim cordless nailer recently and it’s a little underwhelming I had to really practice with it before I could even use it to nail any trim boards in the house. My 18g air nailer is as predictable as my paslode.
  8. Jul 10, 2024 at 6:15 PM
    #4968
    GilbertOz
    GilbertOz Driver
    CA
    Hmm, I generally like Milwaukee tools & have a ton of them, but their design of the M18 21º framing nailer WITHOUT a user-accessible fill port for the piston is -- f^%#ing stupid. If I had done my homework at time of purchase I would have bought a Metabo or other brand that has a user-accessible fill port & is designed to be user-serviced.. Apparently with just 110 PSI of plain shop air for the Metabo in the video below.
    Who knows what the wingnuts in the other videos I posted for their hack-job M18 refills were doing using 160 to even as high as 210 PSI (!) in a similar-sized electric-air nailer.
    https://www.youtube.com/watch?v=ii_L82J8WbU&t=130s
    soundman98 and Sig45[OP] like this.
  9. Jul 10, 2024 at 6:30 PM
    #4969
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I can tell you it definitely does. Eventually your max out your depth adjustment, then it becomes a $300 nail setter.
    I wore mine out rather quickly so Milwaukee recharged it for free, but I think the next time I’m on my own.
  10. Jul 13, 2024 at 8:49 AM
    #4970
    Marty65
    Marty65 Gopher
    Marty
    Lancaster SC
    4Runner trail
    Dog hair and river quiver
    Kbar, Tacman19, dleriche and 8 others like this.
  11. Jul 13, 2024 at 9:53 AM
    #4971
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    I bought that same grinder this past September. I'd never owned an angle grinder before, but had a specific need for it so I bought it. Since then I've used it a bunch of times for a number of different tasks. :thumbsup:
    Sig45[OP] and Marty65[QUOTED] like this.
  12. Jul 13, 2024 at 10:06 AM
    #4972
    GilbertOz
    GilbertOz Driver
    CA
    Anyone new to angle grinders, of any size (4" to 9") -- be sure to read up on good safety practices. They can be among the more nasty cordless tools out there. Wear rated safety glasses at a minimum, ideally a rated full face shield (although I admit I frequently skip the full face shield,) leave the grinder guard in place if at all possible, don't use damaged or expired grinding discs/wheels.
    Google image search "angle grinder injury". NSFW.
    Kbar and Sig45[OP] like this.
  13. Jul 13, 2024 at 12:57 PM
    #4973
    soundman98
    NW Indiana
    and ideally, never stare straight on to the rotating mass, even with protection. standing to the side minimizes personal injury risk even further.
    had a co-worker that at a previous job, the cutoff wheel shattered, and went clean through an old wood garage door...
  14. Jul 13, 2024 at 1:07 PM
    #4974
    GilbertOz
    GilbertOz Driver
    CA
    It's not too hard to keep the eyes out of the plane of the disc spin, but it can get more difficult when taking into consideration the jugular vein, femoral arteries, & genitals. The google images of angle-grinder-related injuries are, for the most part, not photoshopped.
    I think it helps considerably to use quality, name-brand grinding/cutting discs (i.e. Diablo™ yes, Harbor-freight generics no,) to replace them when they get to about 30% worn (subjectively,) to retire any that get chipped, cracked, delaminated, etc. immediately, & also to keep none that are older than maybe 2 years or so, depending on climate & storage conditions.
  15. Jul 13, 2024 at 1:13 PM
    #4975
    Marty65
    Marty65 Gopher
    Marty
    Lancaster SC
    4Runner trail
    Also don’t use an ordinary, grinding wheel made specifically for metal on aluminum. It can possibly build up on the wheel, throw it out of balance and potentially explode. I was a welder certified on coded vessels and piping, and the old rule of thumb was if it doesn’t throw a spark, don’t use an ordinary metal grinding disc on it.
    Tacman19 and Sig45[OP] like this.
  16. Jul 13, 2024 at 1:39 PM
    #4976
    soundman98
    NW Indiana
    the harbor freights hercules wheels seem to work quite well. at least as well as the fastenal supplied wheels at work.
    the ultra-cheap warrior one's though don't last all that long, and tend to throw as much dust as they do sparks...
  17. Jul 13, 2024 at 1:51 PM
    #4977
    Marty65
    Marty65 Gopher
    Marty
    Lancaster SC
    4Runner trail
    Not sure if these are still available but they slice through mild steel and CM like butter. It’s been a while since I checked but I would get them at national welders. IMG_3098.jpg IMG_3097.jpgIMG_3099.jpg
  18. Jul 13, 2024 at 2:14 PM
    #4978
    Kwikvette
    Fresno County
    4 run, 2 don't
    Two angle grinders live on my welding table; one of them is a Milwaukee Fuel and I've been beating the shit out of it for going on 3 years (last used it an hour ago) and it just runs
    I've got a Metabo HPT corded my wife bought for me on sale, at the same time I got the Milwaukee and it too runs flawlessly
    I will add that, I see no difference in a $150 angle grinder than a basic $25 angle grinder and I use them often for metal work
    I say this because even as a hobbyist, I find that you should have at least three angle grinders so you have a different wheel on each setup
    I've got five :anonymous:
  19. Jul 13, 2024 at 4:12 PM
    #4979
    GilbertOz
    GilbertOz Driver
    CA
    I've got 3. Milwaukee cordless M18 4.5" is the handy go-to for all kinds of little tasks.
    My favorite by far is the corded Makita GA4542C SJSII -- 4.5", soft start, variable speed 2,800 - 11,000 rpm. The low ranges on the variable dial are very nice for more delicate work and for just being generally pleasant & safer to use.
    Also a 9" single-speed Makita corded monster for heavy jobs.
    Sig45[OP] and Kwikvette[QUOTED] like this.
  20. Jul 13, 2024 at 4:22 PM
    #4980
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yep!
    Anyone using an angle grinder always needs more than a one at their disposal.
    I wouldn't call anything safer than anything else - just takes a person to know what they're doing.
    Be safe out there!
