Milwaukee Tools
Discussion in 'Garage / Workshop' started by Sig45, May 20, 2020.
  1. Jul 18, 2024 at 9:22 AM
    #5021
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    I'd do a Fuel 3/8" mid torque 18v to keep in the truck. I keep a 1/4 Gen 2 Fuel with me, and while it mostly works, I'd want something stronger for field fixes. Bigger battery gets you bigger power too. Tempting to keep something small in there, but I learned from experience to keep a big one on me. And a charger...I have a bunch.
    Sig45[OP] likes this.
  2. Jul 18, 2024 at 9:40 AM
    #5022
    Toyko Joe
    Toyko Joe Here for the pictures
    I have the rear handle m18 saw. I would not buy it again. I would try the top handle or the M18 hatchet before I would recommend the rear handle saw to anyone.
    I modified my rear handle to have a more appropriate bar and chain and I’m still not entirely satisfied with it for what I spent. I think the top handle makes the most sense for what it is. I did a write up about two years ago in this thread.
    Sig45[OP] and Iwilltaco[QUOTED] like this.
  3. Jul 18, 2024 at 9:55 AM
    #5023
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    not that I've noticed. I have a m12 hatchet that I kept in the truck abut the top handle basically replaced it. I would recommend to watch a few videos on proper chain saw techniques as that's what might be causing the kick back. always under cut to relive pressure etc...
    I still have a few gas chain saws but I mostly use the m18 on in my back yard. its nice and quiet, small so easy to handle. surprisingly it gets most of the logs/trees cut no problem.
    Iwilltaco[QUOTED] and Sig45[OP] like this.
  4. Jul 23, 2024 at 3:26 PM
    #5024
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Thank you for the insight.
    Pulled the trigger on the following. With their current promotions and veteran discount it wasn't too painful.
    MILWAUKEEM18 FUEL Gen-2 18V Lithium-Ion Brushless Cordless Mid Torque 1/2 in. Impact Wrench w/Friction Ring (Tool-Only)
    MILWAUKEEM18 18-Volt Lithium-Ion Cordless Electric Portable Inflator (Tool-Only)
    MILWAUKEEM18 18-Volt Lithium-Ion High Output Starter Kit with Two 6.0 Ah Battery and Charger
    Kbar, Sig45[OP] and T-Rex266 like this.
  5. Jul 26, 2024 at 5:37 AM
    #5025
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Those supposed “breaker” bars are breakable. I use a slider for tough stuff my impact can’t get off
    Throw a cheater bar or pipe on the end of that and hang a tractor on it and it’ll bend not break. Those breaker bars will sever the pin holding the end before using much force
  6. Jul 26, 2024 at 7:38 AM
    #5026
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    Tough nut?
    Penetrating oil.
    50/50 acetone/ATF
  7. Jul 26, 2024 at 1:17 PM
    #5027
    Marty65
    Marty65 Gopher
    Marty
    Lancaster SC
    4Runner trail
    Dog hair and river quiver
    We were discussing cutoff wheels about a week ago and the wheels I was recommending I wasn’t sure if they were still available. Well I ran by Airgas today and I had to ask for them they were in the back. But they are still available. IMG_3181.jpg
    These if they are still made to the same standards are a good cutoff wheel!
    tacoma_ca, soundman98 and Sig45[OP] like this.
  8. Jul 27, 2024 at 9:01 AM
    #5028
    FieldTripTaco
    FieldTripTaco Well-Known Member
    Denver
    ‘21 TACO OR DCLB
    I pulled the trigger on this as I have found myself needing a jigsaw multiple times recently. Ended up using a buddy’s, who has the same model, so I haven’t opened it yet. Up in the air about keeping it.
    Kbar, tacoma_ca, Marty65 and 2 others like this.
  9. Jul 27, 2024 at 9:03 AM
    #5029
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just keep it, you never know.
    I bought a circular saw cause I needed it once for some 2x4's and I'll be glad I own it if the need arises again.
    I'm a metal worker btw.
  10. Jul 27, 2024 at 10:34 AM
    #5030
    Brownie_Man
    Brownie_Man Well-Known Member
    Maine
    2019 Off Road
    jubei, Kbar, tacoma_ca and 9 others like this.
  11. Jul 28, 2024 at 10:57 AM
    #5031
    Sig45
    Sig45 [OP] Well-Known Member
    Mark
    Maine
    Adding to the inventory. The 8.0 and charger were free with the purchase of the Vac and the 12.0 (which was $199...normally $249.). 12.0 is for the Vac. 8.0 will be used for the top handle chain saw. Wanted the new M12 Jig Saw, but not even available at my local HD, so I grabbed the M18 Barrel Jig Saw. Have plenty of extra 3.0's laying around for that.
    Need to track down some vacuum bags.
    Kbar, ETAV8R, soundman98 and 5 others like this.
  12. Jul 28, 2024 at 11:30 AM
    #5032
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    I use it without bags. I like it.
    Kbar and Sig45[QUOTED][OP] like this.
  13. Jul 28, 2024 at 11:53 AM
    #5033
    Sig45
    Mark
    Maine
    I always use bags. I'm usually working in homes and the added filtration is important. Can keep a filter like new for years. Simplifies disposal too.
  14. Jul 28, 2024 at 2:08 PM
    #5034
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Oh, yours is the big one.
    Ours is smaller.
    Sig45[QUOTED][OP] likes this.
  15. Jul 28, 2024 at 3:08 PM
    #5035
    Sig45
    Mark
    Maine
    I also have the small M12 Fuel vacuum for really small cleanups, my trucks, hard to reach areas, etc. I run a bag in that too.
    Use them in my corded Rigid's as well.
    2Toyotas[QUOTED] and Kbar like this.
  16. Jul 28, 2024 at 3:25 PM
    #5036
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    I will check it out.
    Thank you.
  17. Jul 28, 2024 at 3:28 PM
    #5037
    Sig45
    Mark
    Maine
    2Toyotas[QUOTED] likes this.
  18. Jul 31, 2024 at 12:38 PM
    #5038
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
  19. Jul 31, 2024 at 2:10 PM
    #5039
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
  20. Jul 31, 2024 at 2:13 PM
    #5040
    tacoma_ca
    Try that link I posted below the graphic. Just ordered today, it worked. You have to add the 12 Ah as the 'main tool' and a 5 Ah is the 'free tool. Looks like below, then when added to cart it rings up as $199 total cost whereas in the graphic before adding to cart it says $159. After added to cart, the 12 Ah is cheap as shown above. I plan to return the 5 Ah and just keep the 12 Ah for $110.
    Somewhat wonky with the price changing, so not sure what is up with the site but I rolled with it. This is an old link from my cart doing this, stoked they are trying to help me out today.
