Milwaukee Tools
Discussion in 'Garage / Workshop' started by Sig45, May 20, 2020.
  1. Sep 6, 2024 at 10:16 AM
    #5141
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    Other
    Sig45[OP] and T-Rex266 like this.
  2. Sep 6, 2024 at 10:23 AM
    #5142
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    I use the same and it works great
    Sig45[OP] and T-Rex266[QUOTED] like this.
  3. Sep 6, 2024 at 10:34 AM
    #5143
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Wife wanted pliers last night to hang up our daughter’s cheer poster at the football games. (To snip excess zip ties) She asked to keep it. I told her she can have that china one and I’ll order a new pair for me …might as well get two options lol
    dleriche, Sig45[OP] and Foushee like this.
  4. Sep 6, 2024 at 10:44 AM
    #5144
    545
    545 Well-Known Member
    2015 Access Cab
    I found the Milwaukee line to be pretty good, so I switched over to it from stihl line that kept breaking
  5. Sep 6, 2024 at 10:55 AM
    #5145
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Are you only weed whacking or edging with it as well?
    Sig45[OP] likes this.
  6. Sep 6, 2024 at 11:08 AM
    #5146
    T-Rex266
    Elon
    Both. I edge one line (closest to sidewalk) with it. Does pretty well
  7. Sep 6, 2024 at 11:10 AM
    #5147
    Sig45
    Sig45 [OP] Well-Known Member
    Mark
    Maine
    I'm using the same. More so for convenience as it was in stock.
    T-Rex266[QUOTED] likes this.
  8. Sep 6, 2024 at 12:48 PM
    #5148
    joeyv141
    New Jersey
    Ok, so my opinion is based on doing yardwork for 9 yards for around 2.5 years in the southeast with saint augustine grass being the most popular. I did primarily use a 2 stoke echo but did use the current M18 trimmer for about 4-6 of those months, I was very impressed with the M18.
    I have tried out the following trimmer lines, all sized 0.095in - Milwaukee, Stihl CF3, Echo crossfire and black diamond, Shakespeare ugly twist and ugly line, and Rhino Tuff pro line twisted and straight. I have found them all to be fine with weed whacking, I think the Stihl lasted a little longer then the others for weed whacking. But for weed whacking and edging the very best I found is this Rhino Tuff Pro, I found that it left the straightest lines that looks like it is cut with a sharp edger where as other lines the edge would have a slight weave to it, I also found that the bright yellow is very easy to see even when going full throttle so you can make sure the string is long enough when edging. I did try out the Rhino Tuff 0.105in line and it produced a even better edge but it does hurt trees and fences so I went back to the 0.95in.
  9. Sep 6, 2024 at 1:39 PM
    #5149
    T-Rex266
    Elon
    Perfect. Thank you!
  10. Sep 6, 2024 at 4:26 PM
    #5150
    Toyko Joe
    Toyko Joe Here for the pictures
    You should use zip tie cincher they cut much cleaner and won’t cause any sharp edges.
    https://www.cabletiesunlimited.com/tools.html
    https://www.automationdirect.com/ad...ls_-a-_test_equipment/cable_tie_tools/pin.003
  11. Sep 6, 2024 at 4:44 PM
    #5151
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Are there attachments made to fit the weed whacker that make a permanent replacement for the line?
    I don't mean the brushcutter.
    Years ago I had one on my gas powered whacker. It was a 3rd part thing. Blades that swung out as it spun. Not rigid, it would deflect if it hit a hard object.
  12. Sep 6, 2024 at 4:53 PM
    #5152
    T-Rex266
    Elon
    Toyko Joe[QUOTED] and Sig45[OP] like this.
  13. Sep 6, 2024 at 5:45 PM
    #5153
    joeyv141
    New Jersey
    I have previously used a plastic blade version of this, never seen this style with metal blades but I doubt the metal is that strong and will need to be replaced after a few uses.
    https://www.lowes.com/pd/Shakespear...VvzMIBR0d9QdCEAQYAiABEgIkmfD_BwE&gclsrc=aw.ds
    2Toyotas[QUOTED] and Sig45[OP] like this.
  14. Sep 6, 2024 at 5:45 PM
    #5154
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    soundman98, atc250r and Sig45[OP] like this.
  15. Sep 6, 2024 at 6:16 PM
    #5155
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
  16. Sep 6, 2024 at 6:28 PM
    #5156
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    You all are a bad influence and I appreciate it. This was $30 off earlier this week and I found it because of a link in this thread. Since I happened to have a $15 off $100 offer from Home Depot I applied that too. Used the cordless ratchet to do a starter and front brakes on my commuter car today and it was so much nicer than firing up the compressor and dragging out the hose. I know it's not the greatest cordless ratchet they make but for light duty stuff it's great and if something is really tight I'll just break it loose with another ratchet first.
    https://www.homedepot.com/p/Milwauk...-M12-3-8-in-Ratchet-3497-22-2457-20/321639489
    Kbar, Sig45[OP] and soundman98 like this.
  17. Sep 6, 2024 at 6:50 PM
    #5157
    w.adventures
    Nowheresville, SC
    You will love them!
    atc250r[QUOTED] and Sig45[OP] like this.
  18. Sep 6, 2024 at 7:27 PM
    #5158
    joeyv141
    New Jersey
    I think I have a problem, had a dream last night that someone was throwing out brand new in box milwaukee m12 & m18 tools including - newest m18 recip saw and 1/2 mid torque impact wrench, newest m12 drill and impact driver and circular saw. Woke up sad cause while I absolutely don't need it I really want the m12 circular saw. Pretty rare that I remember dreams or nightmares, even rarer that I remember them after being awake for 10 minutes.
  19. Sep 6, 2024 at 7:50 PM
    #5159
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    My weed whacker died today :pout:It’s just straight up dead. Pull the trigger and nothing. I think I got it back in 2020.
  20. Sep 7, 2024 at 12:19 AM
    #5160
    Sig45
    Mark
    Maine
    5 yr warranty I believe.
