Milwaukee Tools
Discussion in 'Garage / Workshop' started by Sig45, May 20, 2020.
  1. Sep 28, 2024 at 5:57 PM
    #5241
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    I find that as long as your wheels aren't corroded and/or damaged you you just hit a new baseline when the temps drop. Like if you were running 35 PSI when it was 70° out once you get down to zero degrees you might be down at like 27 PSI but then once you inflate it back to 35 it should stay pretty close
    T-Rex266, Kbar and Sig45[OP] like this.
  2. Sep 28, 2024 at 6:01 PM
    #5242
    Sig45
    Sig45 [OP] Well-Known Member
    Mark
    Maine
    We had a few cold nights recently (cold for this time of year that is). Daytime temps in 70's, but temps dropped to 40's at night. My normal cold psi dropped from 34 to 30. But like you, it all went back to normal after a couple of warm days and warmer nights.
    T-Rex266[QUOTED] and Kbar like this.
  3. Sep 28, 2024 at 6:02 PM
    #5243
    Sig45
    Mark
    Maine
    This is also true. Those first big temp drops have a big effect.
  4. Sep 28, 2024 at 6:12 PM
    #5244
    Toyko Joe
    Toyko Joe Here for the pictures
    I too grew up in central New York and Wisconsin. I can tell you that a soft tire in a cold snap or in slushy snow is bad news bears. It’s better to have your pressures right and all tracking well to avoid cold related car failures. Frozen fingers changing wet or frozen tires on the side of the road is no fun.
    prepared > lucky
    Tacos4ever15, Kbar and Sig45[OP] like this.
  5. Sep 28, 2024 at 6:14 PM
    #5245
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    So we recently had a temp drop at night. Averaging 70’s day and upper 40’s at night. I’m going to start monitoring my psi and see if there’s significant change. I usually run 31 cold. I’ve also found, for conversation sake, last winter a handful of miles of my commute will raise the psi a little. So there’s that variable to contemplate
    Sig45[OP] likes this.
  6. Sep 28, 2024 at 7:04 PM
    #5246
    Toyko Joe
    So of the last three bundles of sawzall blades I have gotten 8/10 of them are metal cutting. Which isn’t a big deal but I need wood demolition blades now and I have the question are the wood embedded nail 5tpi better for mostly wood or are the 7-9tpi multi material better for all around use?
    Also field service note both myself and my colleague who regularly use our m12 hackzal have been running into issues with the chuck release. Today I applied a few bursts of wd-40 and back to brand new. That was a close one. It’s easily the 3rd most used tool in my bag. Would have been sad to see that go in for repair.
  7. Sep 28, 2024 at 7:16 PM
    #5247
    Kbar
    Western WA
    22 OR
  8. Sep 28, 2024 at 7:22 PM
    #5248
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    after seeing the performance differences, it's definitely my future upgrade path as well.
    for now i just need to find that walking money tree i thought i had tied up in my back yard...
  9. Sep 28, 2024 at 9:56 PM
    #5249
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    Once a tire is inflated at 70°F, its pressure will drop by 1% for approximately every 5°F temperature drop. You will see a 10% pressure drop at 19°F.
  10. Sep 29, 2024 at 1:40 AM
    #5250
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    What effect does altitude have on tire pressure? Most certainly varies with temperatures too.
  11. Sep 29, 2024 at 3:47 AM
    #5251
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I've had my tires drop from 36 to 30 overnight the first cold snap. I swear some tires tolerate it more than others. The temp fluctuations this time of year I'm always dragging my hose out! :annoyed:
  12. Sep 29, 2024 at 4:48 AM
    #5252
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    https://www.milwaukeetool.com/Products/2848-20
    I've got this bad boi and it's the deal. I travel with it on road trips. Perfect for fluctuations in tire pressure and you don't have to deal with a hose.
    It's digital and it will do its own temp regulation. It'll inflate to the set pressure, monitor it for a couple seconds, and then readjust.
  13. Sep 29, 2024 at 5:15 AM
    #5253
    Sig45
    Mark
    Maine
    I'm spoiled with the Tundra displaying the actual PSI. I have to guess with the Tacoma.
    First World problems...
    Toyko Joe and Delta09[QUOTED] like this.
  14. Sep 29, 2024 at 6:16 AM
    #5254
    tacoma_ca
    Between sea level and 10k ft elevation, atmospheric pressure varies by ~3% per thousand feet change in height. Up at 20k to 30k feet the variation is about half that. The change isn't linear because increasing density drives more increasing density as one decends so the height vs. pressure relarionship is exponential (processes where a change in something drives more change so the change isn't constant i.e. linear).
    However the majority of the force that balances the internal tire pressure comes from the elasticity of the tire and internal cords, so only a fraction of the internal pressure balancing force would come from the atmosphere. To find out what fraction, you'd have to test the tire hydrostatically like how pressure tanks are tested every few years. Just an order of magnitude guess is elevation probably gives maybe a 1 percemt change in tire pressure per 10k feet and more expensive tires would have less of an effect based on better reinforcement.
    I'm not a tire guy but have worked on things like tubeless mtb rims and pressure vessels which have similar considerations.
    soundman98 and Sig45[OP] like this.
  15. Sep 29, 2024 at 7:18 AM
    #5255
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    Going from 1000 msl to 6000 msl is around a 5 psi increase for my tires. Driving from Nebraska to the front range in CO, I always have to let air out of my tires.
    tacoma_ca and Sig45[OP] like this.
  16. Sep 29, 2024 at 7:46 AM
    #5256
    Kbar
    Western WA
    22 OR
    I got the same one. It’s pretty accurate and a nice plug and play ordeal.
    atc250r and Sig45[OP] like this.
  17. Sep 29, 2024 at 9:56 AM
    #5257
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    Same here. Very handy to have. No running the compressor and dragging out an air hose or running around the car with a cord from the cigarette lighter.
    Kbar[QUOTED] and Sig45[OP] like this.
  18. Sep 29, 2024 at 10:57 AM
    #5258
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    I have a stupid question. I want to make sure this is the right line for my trimmer?
    My wife got the trimmer for me as a gift for Father’s Day, so I can’t see which one on the app
  19. Sep 29, 2024 at 12:51 PM
    #5259
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    Yeah 0.095 is the most commonly string size
  20. Sep 29, 2024 at 1:11 PM
    #5260
    Sig45
    Mark
    Maine
    T-Rex266[QUOTED] likes this.
