Milwaukee Tools
Discussion in 'Garage / Workshop' started by Sig45, May 20, 2020.
  1. Jan 26, 2025 at 6:56 PM
    #5561
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    If you do this, be sure to shave off (took me 2 seconds sort the oscillator) the red nipples under where the inflator goes. You’ll need to remove the hose holder as well- just Velcro the hose to keep it wound up
    Sig45[OP] and Foushee[QUOTED] like this.
  2. Jan 27, 2025 at 2:44 PM
    #5562
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Question for you all:
    I have an M12 drill 2504-20. I do handyman work so it gets used often. It's a workhorse but one complaint is that when I am drilling with a paddle bit around 1" and on speed 2 (the fastest) and with the dial set to drill, it will sometimes just shut off under load. I release the load and it will work again after letting go of the switch and powering it up again. I've read the manual and can't find anything about shutting down when to load gets too great. On speed 1 (the slowest and lower gear mode) it will power through the wood. I'm always drilling holes in studs to run 12-2 or 14-2 wire and like the faster speed. Is there an official limit to the torque ft/lbs where it shuts off?
    Update:
    Sorry, I found it.
    Battery Pack Protection
    To protect the battery from damage and extend its
    life, the tool’s intelligent circuit monitors current draw,
    temperature, and voltage drops.
    In extremely high torque, binding, stalling, and short
    circuit situations that cause high current draw, the
    fuel gauge will flash, and then the tool will turn OFF.
    To reset, release the trigger.
    Under extreme circumstances, the internal tem-
    perature of the battery could become too high. If this
    happens, the fuel gauge will flash and the battery
    pack will shut off. Let the battery pack cool and then
    continue work.
    T-Rex266 and Sig45[OP] like this.
  3. Jan 27, 2025 at 2:57 PM
    #5563
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    Not sure what batteries you are using but the larger XC or newer CP batteries will help a lot. For heavy stuff like that I only use those battery types or else I fight what you described.
  4. Jan 27, 2025 at 5:33 PM
    #5564
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    If you want to go fast with a bit larger then 1/2 you should go to a 18V drill
    Sig45[OP] likes this.
  5. Jan 27, 2025 at 5:51 PM
    #5565
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    +1 if you're using it a lot like that, first-best option is to get an 18v drill instead. The 3.0+ batteries are better designed for larger loads like that.
    If that's not an option, make sure you're using the M12 4.0, 6.0, or best-case, the new high output 5.0. you're still going to have problems as part of the battery voltage/sizing, but it'll give it the best chance.
    Sig45[OP] and T-Rex266 like this.
  6. Jan 28, 2025 at 7:20 AM
    #5566
    knayrb
    Bryan
    Pure stock
    I'm using an XC 4.0 in the drill and use the smaller CP 2.0 in the driver. They are both about 3+ years old and both still charge to 4 lights. I can nearly drywall a small room with the driver on the small CP 2.0 battery. They are amazing. I was just wanting to make sure that the drill wasn't going out but that stopping under a hard load was normal. Thanks for the comments.
  7. Jan 28, 2025 at 11:05 AM
    #5567
    T-Rex266
    Elon
    The M12 4.0 is badass
  8. Jan 28, 2025 at 5:23 PM
    #5568
    oldgreg
    oldgreg Well-Known Member
    Greg
    2001 2.7 reg cab 4x4
  9. Jan 28, 2025 at 6:11 PM
    #5569
    soundman98
    NW Indiana
    FYI, all batteries will fully charge.
    As they degrade with time/use, you'll notice increasingly shorter run times between full and half charge. There won't ever be a point where they only charge to halfpower
  10. Feb 3, 2025 at 1:34 AM
    #5570
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    Decent deal if you return the 5 ah battery
    Also I pulled this from somewhere else, I’m not Jose.
  11. Feb 5, 2025 at 1:24 AM
    #5571
    dfanonymous
    These batteries not balancing might come as a shock to some, but there’s actually a lot of videos of guys pulling different tool batteries apart and finding issues in cell balancing. Im talking YEARS before this video ever came out.
    https://youtu.be/wG6W3hz8NMQ?si=hN2tTRia2n6lqp3_
  12. Feb 7, 2025 at 8:21 PM
    #5572
    soundman98
    NW Indiana
    i hadn't heard of it before, but putting the pieces together, it makes sense.
    they're not monitoring the individual cell voltage, just batches of cells, so the cells-per-batch will naturally drift away from a balanced charge.
  13. Feb 8, 2025 at 7:21 AM
    #5573
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    Seen that a few days ago, don’t know what country he’s in and if Milwaukee designs differently in other places but those batteries look fake.
    Sig45[OP] and Foushee like this.
  14. Feb 8, 2025 at 7:49 AM
    #5574
    545
    545 Well-Known Member
    2015 Access Cab
    Yeah, that’s what the batteries look like in the rest of the world
    No idea why they have different designs
    Sig45[OP] and gotblika[QUOTED] like this.
  15. Feb 8, 2025 at 11:05 AM
    #5575
    dfanonymous
    Global market. Same with dewalt batteries, except they make Dewalt put 18v on them. I guess the global market doesn’t know the difference between nominal discharge and max charge, but I digress.
    Either way, thats beside the point. There’s a decade worth of information, including from the US that have similar information about cell balance..or rather the lack there of.
    edit: I will add, Dewalt will actually do a top off charge if you throw it on the charger before using. It usually last a minute or less.
    Milwaukee on the other hand, if it’s green it’s green. Doesn’t matter if the battery has been sitting for 4 months.
  16. Feb 8, 2025 at 11:33 AM
    #5576
    T-Rex266
    Elon
    Milwaukee screwdriver dropped reading batteries for some reason. I took it apart, and all wiring are still soldered. Can’t figure it out. Sending back to Milwaukee for repair as it’s under warranty
  17. Feb 9, 2025 at 2:20 PM
    #5577
    T-Rex266
    Elon
    Took it HD. Told them it came in a kit and she didn’t ask for my receipt (which I had). She said to get a hardware guy to pull one out of a box from another kit and she’ll swap it. Love the hassle free exchange
  18. Feb 9, 2025 at 2:33 PM
    #5578
    dfanonymous
    I did that for a Traeger once I got at Home Depot. Something happened and it became electrified. It was a while ago, so I don’t remember, but it was something in the DC inverter, when I pulled it apart to see why I was getting shocked.
    They did a no receipt exchange. But, they don’t do them for tools because of abuse. I’m thinking the localities have control over that policy probably.
  19. Feb 9, 2025 at 3:11 PM
    #5579
    Sig45
    Sig45 [OP] Well-Known Member
    Mark
    Maine
    I'm repairing and rebuilding some large screen porch inserts (screens) for a customer. Basic 1x4 frame (52" tall x 44" wide) with screen stapled on the flat (inner edge). That is covered with a 1/2" x 1/4" half round trim. It's held in place with 3/4 crown staples.
    I don't think my M12 stapler will cut it. Going to pick up the M18 crown stapler for the job.
    I'll still use the M12 (T50) to attach the screen to the 1x4 frame.
    T-Rex266 likes this.
  20. Feb 9, 2025 at 3:33 PM
    #5580
    T-Rex266
    Elon
    Fwiw, the emp who I grabbed asked their Customer service manager. I told him I have a receipt for it from Nov. He didnt hesitate and approved for them to swap it despite being a different model number (as it was from a diff kit)
