Milwaukee Tools
Discussion in 'Garage / Workshop' started by Sig45, May 20, 2020.
  1. Jan 3, 2021 at 12:39 PM
    #141
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    With the M18, 6.0 ah, the HO is 2.30 lbs and the regular XC is 1.60 lbs.
    Can you feel the difference in weight if using the tool for hours?
    Can I use the standard charger while charging the HO battery?
    Can the rapid charger be use to charge the smaller battery pack, without heat becoming a issue?
    Sig45[OP] likes this.
  2. Jan 3, 2021 at 12:42 PM
    #142
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    I know you weren't asking me but I can give you some input. I have charged regular 5.0 XCs on the rapid charger and the big 12.0 on a regular charger without any issues. Also as far as weight you can definitely feel the difference in battery sizes. I have the 12.0 8.0 5.0 and 2.0 and you can definitely feel the difference between them especially if you're working over your head.
  3. Jan 3, 2021 at 12:46 PM
    #143
    Venom
    Kevin
    Massachusetts
    By reading, I'm guessing the stationary tools takes the larger battery pack.
    Anything is going to be better than my 1 or 1.5 ah battery in runtime.
    Sig45[QUOTED][OP] likes this.
  4. Jan 3, 2021 at 12:48 PM
    #144
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    Any charger will work, just takes longer. Think all my standard chargers are in a box in the garage now.
    I don’t use 6.0 in my drills or nailers. Usually the little 2.0 or 3.0 in nailers, and still using mostly the older 5.0 in drills. I believe its weight comes in between the 2 6.0 batteries, so I would have no hesitation to use either one in place of the 5.0 I use now. My impact just feels so nice with a 3.0, I opt for that if from time to time. And they charge faster than I can run them down, so 2 of those work well. As mentioned above, working above your head, lighter is noticeable. If you are only looking between the 2 6.0 options, I’d get the HO as they’ll be more versatile
  5. Jan 3, 2021 at 1:05 PM
    #145
    Venom
    Kevin
    Massachusetts
    Have you charged the small CP battery in the rapid charger?
    I've used a cordless Dewalt drill for sheetrocking. Going from a small battery to a much larger battery I can definitely feel the weight different. Shoulder were sore for days.
  6. Jan 3, 2021 at 1:10 PM
    #146
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Love my Milwaukee tools. Have more on the way, but they've been dependable. No issues with any of mine...
    @Sperrunner
    SR-71A, Sig45[OP], Venom and 2 others like this.
  7. Jan 3, 2021 at 1:13 PM
    #147
    Gen1FTMFW
    I've been building a bumper for my GX470 and I will admit that the M18 grinder absolutely eats batteries. I have a couple cheap HF plug in grinders that I've used more so that I'm not constantly changing/charging batteries.
    Sig45[OP] and Iwilltaco like this.
  8. Jan 3, 2021 at 1:18 PM
    #148
    LarryDangerfield
    Tyler
    Northern Wisconsin
    That's actually the one battery I haven't charged on the rapid charger. You had me curious so I just looked it up and read the description and it says it works with any and all batteries so that makes me feel better.
    Sig45[OP] and Venom[QUOTED] like this.
  9. Jan 3, 2021 at 1:18 PM
    #149
    Venom
    Kevin
    Massachusetts
    For the drill, should I pick up the 3.0 ah battery? The 1.0 or 1.5 ah battery (not sure which one I have) doesn't last long til the next charge.
  10. Jan 3, 2021 at 1:22 PM
    #150
    Venom
    Kevin
    Massachusetts
    I figured I'll ask. Lithium cells in battery pack doesn't like heat.
  11. Jan 3, 2021 at 1:22 PM
    #151
    Banggerr
    Banggerr Well-Known Member
    Excited to read through this later. Got some gift cards saved up and been eyeing Milwaukee stuff
    Sig45[OP] and LarryDangerfield like this.
  12. Jan 3, 2021 at 1:23 PM
    #152
    Venom
    Kevin
    Massachusetts
    Showoff :D
    Sig45[OP] and Gen1FTMFW[QUOTED] like this.
  13. Jan 3, 2021 at 1:25 PM
    #153
    Iwilltaco
    Under development
    You could, I just got them this year. Before that I always had the 5.0 in the impact and drill/driver, and still do. I just found the 3.0 is nice in the impact and had enough runtime. I never had the 4.0, and 6 didn’t seem enough a step from 5 to bother getting. Although in the 6.0 HO proves to be good in the 7 1/4 or sawzall, I might pick up a couple.
  14. Jan 3, 2021 at 1:26 PM
    #154
    LarryDangerfield
    Tyler
    Northern Wisconsin
    One of these days I'll have to make a picture like that :D
  15. Jan 3, 2021 at 1:55 PM
    #155
    Venom
    Kevin
    Massachusetts
    I was originally looking at the 5.0 but figure the 6.0 was close to weight with slightly more power, run time.
    I can't find a 2 battery combination kit. Something like a 3.0 and 6.0. The only one available at Home Depot 6.0 and 8.0 combo doesn't allowed to be ship to this area.
    I'm don't want to regret that I should of got higher ah rating.
  16. Jan 3, 2021 at 2:13 PM
    #156
    Iwilltaco
    Under development
    Yea, tool with battery deals are usually the best way to pick up batteries. But if you aren’t in the market for tools, they did have some good battery deals this year. The 2 3.0’s for 129 is a pretty good deal, but if you need bigger batteries you might just need to be on the lookout for deals. Or find a tool you want that comes with a good battery :thumbsup:
  17. Jan 3, 2021 at 2:14 PM
    #157
    medic2230
    Murph
    Bama! Roll Tide
    I joined the Milwaukee M12 bandwagon on Black Friday.
    Now you guys got me looking at the M18 vacuum. Those gift cards might just come in handy.
  18. Jan 3, 2021 at 2:19 PM
    #158
    Sig45
    Sig45 [OP] Well-Known Member
    Mark
    Maine
    Welcome Murph!
    :fistbump:
  19. Jan 3, 2021 at 2:21 PM
    #159
    Venom
    Kevin
    Massachusetts
    I wasn't looking at the 3.0 battery but you and Larry Dangerfield, made a good point about weight.
    There always next Milwaukee holiday sale.
  20. Jan 3, 2021 at 2:27 PM
    #160
    Iwilltaco
    Under development
    You bet. And Home Depot has them from time to time all year. Online they’ll have a battery or tool at regular price, and a + battery or bare tool. They can be really good deals.
    Thatbassguy and Sig45[OP] like this.
