Mini Mod Day July 10th
Discussion in 'Arizona' started by XPOTRPR, Jun 30, 2011.
  1. Jul 5, 2011 at 1:11 PM
    #41
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Daaaamn... alright man. Well shitty to hear but youll get that fixed up and back on the road In no time.
  2. Jul 5, 2011 at 1:16 PM
    #42
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Damn what did I miss?
  3. Jul 5, 2011 at 1:29 PM
    #43
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Should of come out man.. lol Matt passed out on our couch.. we all being drunk, had to mess with him. My gf being the most antagonizing. Lol
  4. Jul 5, 2011 at 10:33 PM
    #44
    SGT Taco
    SGT Taco It all fun and games till its not.
    Scott
    Spring Hill TN.
    R.I.P. 2007 TRD, Land Rover Disco II, F250.
    Wife rolled it 3x mod...
    I think that you can count me in on this also!
  5. Jul 5, 2011 at 10:38 PM
    #45
    SGT Taco
    Scott
    Spring Hill TN.
    Hey, i just put a new one in my truck and i got a killer deal from a distributor in mesa for about $150. Screw Toyota parts counter!
  6. Jul 6, 2011 at 12:35 PM
    #46
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Hey man i got ur pm too but thanks for the info. I had to bite the bullet though, i had limited time to do it and had to work that night. With my limited experience on workin with radiators id rather not screw anything up, so toyota did it last night. everything is back to normal but im $400 in the hole....
  7. Jul 6, 2011 at 12:49 PM
    #47
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Nice!
  8. Jul 6, 2011 at 12:51 PM
    #48
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Put me down as a "probable" on this one. I might wait to wire my new lights at this instead of f'ing it up myself. I already mounted the lights and ran the lead wires behind the grill, just need to wire up the harness to the new 6-device fuse block, install the 100A circuit breaker, and put in the new switch. I'll bring my Dremel and wiring stuff.
  9. Jul 6, 2011 at 12:52 PM
    #49
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    If you want, I'll bring that Access cab sub box with the subs in it.
  10. Jul 6, 2011 at 1:03 PM
    #50
    TidalWave
    TidalWave I have a shovel and no one will miss you...
    Mendy
    Surprise, AZ
    05 TRD DCLB
    4" Maxtrac Spindle lift, 33" BFG A/T, Avid weld on rock sliders and rear bumper, Smoked Projector Headlights, smoked tails and fogs, HID healights and fogs, flowmaster exhaust, Wet Okoles, debadged. Ready to take your milk money.
    Anyone familiar with the Hi/low HID harness and projectors?
  11. Jul 6, 2011 at 1:04 PM
    #51
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Definitely come on out Adam. I have a bunch of wiring to do also.. IF my HIDs and stuff get here. If not ill help ya regardless. I wired my Hellas up pretty easily.
  12. Jul 6, 2011 at 1:06 PM
    #52
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Not bi-xenons no.. but I ordered my low beam HIDs and hopefully they will be here by Sunday. I'm putting them in my projectors so I'm sure we can figure it out. they should be close to the same. Just a ballast, wiring harness, and thats it really.
  13. Jul 6, 2011 at 1:09 PM
    #53
    TidalWave
    Mendy
    Surprise, AZ
    05 TRD DCLB
    It would sound that way wouldnt it ;)
    Currently its all hooked up, grounded, etc. BUT, the low beams only work when the high beams are on. Nothing happens at all on low beams.
  14. Jul 6, 2011 at 1:11 PM
    #54
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Sweet, I would appreciate the second set of eyes so I don't botch it up! Sierra Expeditions wired my PIAA fogs so I haven't really played with much in the way of wiring in my truck yet with the exception of the stereo. My only real concern is making room through the firewall through one of the grommets and still keeping a good seal. Everything else is just time consuming because I want to redo everything to the new fuse block I picked up yesterday. Glad I have a giant can of zip ties.
  15. Jul 6, 2011 at 1:15 PM
    #55
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I used I wire hanger.. used pliers and bent and pinched closed a tiny loop on the end. Fed it through the gromet under and to the left of the brake pedal, then hooked the wires that I needed for the switch to the loop, and pulled it back through. The seal is still great because you can feel when you push the wire hanger through and back. Running the wires was the most time consuming. Making sure they are where you want them and not tangled.
  16. Jul 6, 2011 at 1:16 PM
    #56
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Ha I have a bent hanger in my tool box for just such an event.
  17. Jul 6, 2011 at 1:17 PM
    #57
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Hmmm maybe thy are switched around? I'm sure we can figure It out no problem.
  18. Jul 6, 2011 at 1:18 PM
    #58
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i bet you 5 bucks you stand there dumb founded scratching your ass for at least 10 minutes
    her and brian has tried to get them to work for hours trying everything every which way
  19. Jul 6, 2011 at 1:20 PM
    #59
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Don't be too quick to judge.. lol I did happen to stand like that when I wired mine up backwards tho.
  20. Jul 6, 2011 at 4:23 PM
    #60
    Racerboy221
    Racerboy221 Well-Known Member
    Bill
    Litchfield Park, AZ
    Tacoma 2.4, Std cab/bed, 18"wheels,airshocks
    18" Wheels & Tires, Airshocks, CB Radio
    Any openings for a noobie to loiter??
    I don't have any mods to add at this time but might be able to offer a hand some where along the way, if not a beer....like to meet some of the locals, too! LMK
