Minimum speed at 4 hi
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sillyhuman, Sep 1, 2024.
  1. Sep 1, 2024 at 1:54 AM
    sillyhuman
    sillyhuman [OP] Member
    I see information about the max speed at 4 hi and 4 low. But what is the minimum speed you should drive at 4hi? I drive on dirt and gravel road and always have to slow down for turns and rocky areas? We that cause issues for my truck down there road?
  2. Sep 1, 2024 at 3:02 AM
    mike s
    mike s Well-Known Member
    South Carolina
    2019 TRD OR
    No minimum. You can even drive in reverse. Actually the only limit I know about is the speed you engage 4hi. I don’t think there is a maximum.
    MGMDesertTaco, 02Duck, Chew and 3 others like this.
  3. Sep 1, 2024 at 5:22 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    No min, no max. Have fun
  4. Sep 1, 2024 at 5:30 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Speed not so much but low range is easier on the transmission/torque converter if creeping along slowly off road and loading up the drive train.
    3JOH22A likes this.
  5. Sep 1, 2024 at 6:05 AM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    Mean like -4 mph?
  6. Sep 1, 2024 at 7:03 AM
    sillyhuman
    @Willy Lump Lump, yes. Some times even at 4 mph. There are some spots with lots of rock. Small to medium size and I really have to slow down.
    Willy Lump Lump likes this.
  7. Sep 1, 2024 at 7:07 AM
    Willy Lump Lump
    21’ dcsbmt
    This and that
    I said -4. Which is backwards.
    You can drive any speed the conditions will allow in 4hi. But if you’ve never driven in 4lo you should try it out, it’s a blast.
    MagicToolbox and musicisevil like this.
  8. Sep 1, 2024 at 7:25 AM
    sillyhuman
    @Willy Lump Lump , sorry, the term is new to me. No I have not tried driving back wards,but I can totally see I will need to do that. Thanks again
  9. Sep 1, 2024 at 8:22 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    I have climbed a mountainside "2 rut" for several miles (hanging on a rock face) - and found it completely blocked by a rock slide. You get very familiar with backing in 4 wheel drive.
    I-Give-Up and gudujarlson like this.
  10. Sep 1, 2024 at 8:46 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
  11. Sep 1, 2024 at 8:50 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    You need to be moving in most cases for the ADD motor to shift and truly engage the front diff. The only exception to that is if the ADD splines happened to be perfectly lined up, then it will shift sitting still.
    The transfer case takes very little alignment to shift. It pretty much will always shift no matter what. But you don’t get the light on the dash to go from blinky to solid until the ADD engages, so that is what you are usually waiting on. And if that isn’t lined up to engage, then you will have to move the wheels some before it will finally go.
    In other words, there are no minimums. The only limit is that you have to be below 62mph for the shift into 4H to be allowed. You need to pretty much be stopped for 4L shift and if automatic, you need to be in neutral.
    Chew likes this.
  12. Sep 1, 2024 at 8:51 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Reverse is a luxury most don’t need.
    44-16 Taco and Chew like this.
  13. Sep 1, 2024 at 9:29 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I grew up with a friend who's car did not have reverse,, yeah we chose pull through or flat parking spots, or had to coast back in to uphill spots. Even had a brick for a brake. Built character, though ya'll probably can't tell :D
  14. Sep 1, 2024 at 9:37 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    That’s why the AT OR Tacomas are fricking dangerous to do that in. Any vehicle that makes you put it in reverse and depend solely on using your brakes to control reversing speed on a steep slope is just asking for trouble. Being able to also use the engine to control your speed when coasting downhill backwards by staying in drive makes that maneuver much safer. Yeah, you can use your ebrake too but damn, having to put it in reverse to back up on a slope is stupid. Even worse if pulling a trailer.
  15. Sep 1, 2024 at 10:03 AM
    Willy Lump Lump
    21’ dcsbmt
    This and that
    You certainly don’t want to be in 4hi reversing down a hill in a manual truck. The slowest speed you can go in reverse is pretty quick.
  16. Sep 1, 2024 at 10:07 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Manual I would put it in 4LO if creeping along. Automatic, go whatever you are inclined.
  17. Sep 1, 2024 at 10:59 AM
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    Yep - been there - also had a VW bug - no reverse - no big deal - did like you guys did and sometimes just got out and pushed. Didn't do the brick thing tho - no that he wouldn't have if he needed to. For a while he either had to park on a hill or we had to push him so he could pop the clutch to start. Finally he got a decent job when he graduated college and bought a Ford Torrino (sp?) (he always wanted one) that was a money pit but it was a bad ass looking car.
  18. Sep 1, 2024 at 2:12 PM
    gudujarlson
    Minnesota
    Been there done that many times. Gravity is key.
    Don’t forget 4lo either.
  19. Sep 1, 2024 at 2:34 PM
    Bishop84
    Bishop84 Well-Known Member
    Gravel roads never need 4lo, 4hi all day baby.
    The idea behind 4lo is steep angles and hard challenges that need more torque or gearing.
    I've always felt like hard challenges in 4hi is hard on the converter or clutch so I always use 4lo and keep the strain down.
    gudujarlson likes this.
  20. Sep 1, 2024 at 3:28 PM
    Willy Lump Lump
    21’ dcsbmt
    This and that
    I don’t forget about 4lo. I’ve got 2lo also.
    02Duck likes this.
