Minimum suspension mods for occasional use slide-in camper?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Maddog99, Dec 6, 2022.
  1. Dec 7, 2022 at 6:35 PM
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    Your Gen1 would haul the camper better if you didn't need to take as many people (better payload). Your on the right track with airbags and sumo or timberne, maybe something to help with the sway.
    Take a look at the Round the world Tacoma build, he put a flat bed with a four wheel camper on it, some of his suspension mods might give you some ideas.
    https://www.tacomaworld.com/threads/driving-a-tacoma-around-the-world.585792/
    Timbren-Industries likes this.
  2. Dec 7, 2022 at 6:38 PM
    Bishop84
    Bishop84 Well-Known Member
    Timbren is not the right choice, I always suggest them for occasional towing/hauling, they ride terrible when in constant contact.
    Firestone airbags w/pump and gauge with rear hellwig sway bar is my typical suggestion for camper setups.
    YF_Ryan, RustyGreen and MaverickT883 like this.
  3. Dec 7, 2022 at 7:03 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Plus one on the Firestone bags + pump setup. I’ve had my truck towing 8k. Don’t recommend it, but hey, farm life lol. Yeah, I agree with the other commenters… I’d really go to a half ton for that camper.
  4. Dec 7, 2022 at 7:40 PM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    Roadmaster active suspension.I think it rides smoother than stock. Bolt on and zero Maintenance
  5. Nov 15, 2023 at 9:55 AM
    OverlanderNS
    OverlanderNS Member
    Tom
    Halifax
    2018 Tacoma Sport
    Amber fogs,LED interior,Bed Stiffners,OME 2" lift med springs
    Have a 2018 TRD sport. Went with OME 2” lift and level with hd springs. Also changed to 10 ply tires for the slide in. Slide in is an outlander xl 950 lbs.no problems so far and really good on logging roads for hunting season. Use spring loaded hold down bars over chains better on hiway I hope this helps.
  6. Nov 15, 2023 at 10:06 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I'm a highly active admin over on the Scout Campers FB Owners Group and the usual answer for someone with your use case is air bags and a nice bicycle pump. You should also look into upgrading to E-rated tires. They are stiffer and won't ride as nice, but at 30-35 pounds it's not too bad. But when loaded, you can air them up much higher (I run 60 front/ 65 rear) and you get far less wallowing around on the road, and much less lean in the corners. Steering is much tighter and altogether feels better.
    The Timbrens and like products can really give you a harsh/jarring ride depending on how you use your truck.
    My truck is mainly used for camper hauling duties now, so I went with a heavy duty leaf pack. But as it currently sits unloaded, I pretty much have a six inch lift in the rear and it rides like I don't have suspension, lol.
  7. Nov 15, 2023 at 1:23 PM
    Tanmann
    Tanmann Well-Known Member
    Richmond, VA
    2017 OR Access Cab
    Cardboard spoiler and skateboard wheelz
    I’m no expert but I would look at some lighter camper options. GFC, Ovrlnd, Super Pacific, Tune Outdoor etc
