Minor Lifting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GeorgiaCajun, Aug 15, 2023.
  1. Aug 15, 2023 at 11:42 AM
    GeorgiaCajun
    GeorgiaCajun [OP] New Member
    Donnie
    2023 TRD OFF-ROAD 4x4
    KD MAX TUNE
    Interested in slight lifting for 23 model crew short bed. Something under 3” My truck has 16’s and I may look into 17” but I don’t wanna
    do anything that will ruin the fuel mileage and drastically change ride quality.
  2. Aug 15, 2023 at 11:53 AM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    If fuel mileage is priority, I wouldn't change anything. If you're new to the truck game, start with eibach vs bilstein 5100. Welcome to TW.
    02Duck and Chew like this.
  3. Aug 15, 2023 at 11:54 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    If fuel mileage is a priority, you should lower it. And drive slowly.
    Chew likes this.
  4. Aug 15, 2023 at 11:54 AM
    JasonLee
    15 TRD OffRoad
  5. Aug 15, 2023 at 12:02 PM
    GeorgiaCajun
    Donnie
    KD MAX TUNE
    At this point it’s mostly cosmetic. I just want my truck to look a bit more 4wd than stock but nothing over the top.
    BBogey likes this.
  6. Aug 15, 2023 at 12:06 PM
    Clearwater Bill
    Billy
    Largo Florida
    Don't bother. Truck looks great as is.
    And again, don't bother. Truck is already at it's peak, especially if you have the tune in your profile
    Chew likes this.
  7. Aug 15, 2023 at 12:08 PM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    bilstein 5100s front and rear. Set the front to 2 inches and buy a 1 inch lift block for the rear. Should be under $500 in parts.
  8. Aug 15, 2023 at 12:08 PM
    turkeycreek29010
    turkeycreek29010 Well-Known Member
    Chuck
    Bishopville, SC
    2021 TRD Offroad
    TRD Lift, MKW Offroad M205 Bronze 17 x8.5 wheels, 265/70r17 General Grabber ATX, Hikari LED Headlight Bulbs, Diode Dynamics SS3 Max Amber Fog lights, Tyger Rollup Bed Cover, OEM Bed Mat, Havoc OffRoad HS2 steps
  9. Aug 15, 2023 at 12:35 PM
    Buggin112
    Buggin112 Well-Known Member
    Portland, Oregon
    2022 Tacoma TRD Off-Road
    I would start with removing the side steps that hang down.
  10. Aug 15, 2023 at 12:37 PM
    MonkeyChief
    MonkeyChief Detachable member
    ACORLR
    WTB Topper Lunar Rock 6’ Leer
    +1
  11. Aug 15, 2023 at 1:22 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I recommend you stay away from a spacer lift, and put Bilstein 5100's up front. You could set it @ 1" and perfectly level your truck.
    Or set it 2" up front, with a 1/2" block in the rear to give you a perfect 2/1" lift.
    Then if you have some ca$h leftover, upsize those Highway tires to nice 265/75/16 A/T tire.
    Burns, 02Duck and tacomasnbeers like this.
  12. Aug 15, 2023 at 1:24 PM
    fourfourone
    1/2" in rear block only gives 1/2" of lift.
  13. Aug 15, 2023 at 1:25 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    You may be right, I'm too lazy to look under my truck to measure.
  14. Aug 15, 2023 at 1:31 PM
    fourfourone
    Block sits right on top of the axle, the thickness of the block is the amount of lift.
    turkeyslayer66 likes this.
  15. Aug 15, 2023 at 1:31 PM
    BBogey
    BBogey Well-Known Member
    2003 Tundra, 2012 Tundra and now a 2023 Tacoma
    im showing how incredibly stupid I am when it comes to anything mechanical, but what’s the difference b/w a “spacer” and a “block”?
  16. Aug 15, 2023 at 1:37 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    This will kill mpgs more than a lift
  17. Aug 15, 2023 at 1:52 PM
    czukie
    czukie Well-Known Member
    Colorado
    ‘23 Tacoma Access Cab
    Ive had three 3rd gens and put pretty much the same 1” lift on all of them still got the same mpg’s as I did from day 1 from all of them. Lifts (under 3”) don’t kill mpg’s, heavy or big tires and other weight kill mpg’s.
    With that said, IMO all-terrain tires make the truck look more aggressive and give it the “4WD look”. Putting a lift on it while keeping stock tires is going to make it look wimpy IMO. Like skipping leg day.
  18. Aug 15, 2023 at 2:13 PM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    2” front and 1” back and slightly larger tires is what I did and I am pleased with the result.
    I recommend it
  19. Aug 15, 2023 at 2:40 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    2” lift is not crazy noticeable unless there is a stock taco right beside you, even then…
    If you want it just for looks and keep your MPGs, I would leave it stock.
    The only reason I lifted was to get better approach/brake over/departure angles and to be able to go into a bit deeper water. Well and sport suspension was pretty stiff so going with OME shocks made a huge improvement off-road, on road its a bit softer which is nice.
    turkeyslayer66 and Chew like this.
  20. Aug 15, 2023 at 2:43 PM
    Tucker2020!
    Tucker2020! Well-Known Member
    Upgrade to Bilstein 5100s for better ride quality. Lifting your truck won't impact gas mileage, bigger tires and more weight does. What I have found was that 32s and below didn't impact mileage too much - it was when I went 33s and bigger (now 35s) w/ more weight.
    MonkeyChief and czukie like this.
