Minor Mystery...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tilt, Nov 7, 2009.
  1. Nov 7, 2009 at 1:14 PM
    Tilt
    Tilt [OP] Well-Known Member
    Lyle
    Alberta, Canada
    In between Tacomas at the moment.
    Today I found a small connector piece in (sort of) a pocket, just forward of my front (driver side) tire. It's a small plastic pocket space (with a hole to allow debris to fall through) kind of directly under the headlight backs. Anyway, this little connector piece was rattling around in there - too big to fall through the hole. I haven't had time to crawl under and see where it's from. Any guesses here before I do?
  2. Nov 7, 2009 at 1:21 PM
    alteredillusions
    alteredillusions Well-Known Member
    Wichita KS
    SR5 2.7 manual
    Speed nut for inner fender may be?
  3. Nov 7, 2009 at 1:21 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    It serves as a nut for body part bolts,etc.
  4. Nov 7, 2009 at 1:55 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Prolly dropped during assembly at the plant, doubt it one is missing. Worker probably grabbed another and moved on rather then fish that one out.
  5. Nov 7, 2009 at 2:23 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Flux capacitor :notsure: I only say that cuz I'm almost sure you can't time travel:D
  6. Nov 7, 2009 at 2:28 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    If you lay down under the pocket with the hole in it, you'll see a couple screws holding the pocket in place. The object you found is what the aft most fastener screws into...the screw also helps hold the bottom of the driver's side fender flair.
  7. Nov 7, 2009 at 2:34 PM
    Old Soul
    Old Soul Well-Known Member
    NC
    09 AC V6 SR5 2WD SWB
    not to many, love it the way it is
    if the fastener fell off then the screw is probably not far behind , make sure the screw is not in the tire :eek:
  8. Nov 7, 2009 at 3:04 PM
    Tilt
    Lyle
    Alberta, Canada
    Thanks for the pointers. I'll crawl under tomorrow and have a close look to make sure nothing's loose.
  9. Nov 7, 2009 at 3:33 PM
    SubZombie
    SubZombie Well-Known Member
    South East
    2019 Voodoo TRD Pro
    I know exactly what it is. It goes on the very front part of either side of the front fenders flares. Not really in the actual wheel well, in the front under the bumper. Clips and slides through a hole where the fender flares attach to the front bumper. I'm not even sure there is a screw associated with it, for some reason I remember it just cliping and going through the hole, but it could still have a screw, don't remember.
  10. Nov 8, 2009 at 1:19 PM
    Tilt
    Lyle
    Alberta, Canada
    Minor mystery solved. SubZ was right.....and I'm pretty sure fletch was right too. Found the connector firmly in place where SubZ said. I'm sure it was a case of 'fumble-fingers' just grabbing another part to keep things going. Guess I have an extra now.
