Minor oil leak? really cant find it!
Discussion in '1st Gen. Tacomas (1995-2004)' started by sir1123, Feb 4, 2012.
  1. Feb 6, 2012 at 3:19 PM
    sir1123
    sir1123 [OP] Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    so how many caps are ther on one head in the rear? 2 ? i re sealed the ones that a recessed in the head...are the big halfmoons that come up and out the head reamovable? if so i think this is where it is leaking.
  2. Feb 6, 2012 at 3:56 PM
    sir1123
    Charleston
    a nyone?
  3. Feb 6, 2012 at 4:41 PM
    sir1123
    Charleston
    what are the two circles in the back? does that big hump come out?
  4. Feb 6, 2012 at 6:12 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    pics man... hard to explain something that technical with out pics. should just be one in the back and one in front from the pic i posted???
  5. Feb 6, 2012 at 6:33 PM
    sir1123
    Charleston
    sorry about that...i resealed those but i still have some kind of leakage from the big round hump on the top cam...........it is not from the valve gasket but from the somewhere under that round hump....i cant upload pics at moment.sry
  6. Feb 6, 2012 at 6:35 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    ok i gotcha now... did u put sealent at both of the bases of that hump? this drastic angle change is where the gasket can leak.
    also if it is coming from beneath that hunp on the front? thats your cam seal.
  7. Feb 6, 2012 at 6:39 PM
    sir1123
    Charleston
    ok i did put a little on those corners and it is on the back driverside....could this be my head gasket...i thought when those go bad you engine overheats and you get moister in your engine....do these go bad alot?
  8. Feb 6, 2012 at 6:42 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    no head gaskets dont leak very often... and know just cuz it may be leaking oil doesnt mean its leaking coolant or compression.
    can u verify its the head gasket tho? that seam is much further down than the bottom of the cam
  9. Feb 6, 2012 at 6:46 PM
    sir1123
    Charleston
    i know where that is i just checked it it is def. not far enough down to be head gasket....maybe it is still coming from the valve cover? do you know of anyother place it could be back there in that area?
  10. Feb 6, 2012 at 7:39 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    other than the half moons or the points on the sides of the caps... i cant think of another area????
  11. Feb 6, 2012 at 7:48 PM
    sir1123
    Charleston
    ok thanks for the help guess i need to redo them again thanks alot i appreciate the help
  12. Feb 6, 2012 at 7:59 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    no problem man.
  13. Mar 2, 2012 at 9:05 PM
    sir1123
    Charleston
    ordered my cam seals today should come in tm and hopefully stop the leak..
  14. Jun 9, 2012 at 7:59 PM
    sir1123
    Charleston
    would the rear cam plug be leaking? does it often leak on the v6?
