Minor shutter/vibration from rear on 2015 TRD PRO after lift/update 12/17/17
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2004TacoBill, Nov 22, 2017.
  1. Nov 27, 2017 at 12:57 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Except those fixes may not fix the issue,if you also have too go 1 piece drive line,thats $550. And you may still have vibes,then maybe a front Ecg Bushing that is another $200 bucks .Things too really think about when you gain a lousy 2 inchs of lift !
    TacoMeSir likes this.
  2. Nov 27, 2017 at 2:50 PM
    Okaybjay
    Okaybjay Member
    Jesse
    Ontario
    2015 tacoma trail teams trd pro
    I had the same issues with mine. Can anyone here tell me if im doing my math right?
    Tranny: 2°
    First shaft: 5.6°
    Second shaft: 7.5°
    Pinion: 4.5°
    So my u joint working angles from front to back would be 3.6 1.9 and 2.5
    Am i correct that my issues is a .6 difference in my second and third joint?
  3. Nov 27, 2017 at 2:54 PM
    FJ to Taco
    FJ to Taco Well-Known Member
    Tony
    Lacey, Wa
    2015 DCSB 4x4 TRD Off Road,Snugtop Rebel
    Bilstein 5100's all around, OME 885's and OME Dakar CS047R Leaf Packs. Snugtop Rebel, pet screens,front slider drop down window. WeatherTech mats. Interior LEDS
    Just my experience:
    I lifted my 2015 TRD OR 4x4. 2 1/2 in front and 3 inches back OME (Spring packs) I put on a OME CB drop kit at time and I have no issues. I did a lot of research and chose the CB drop kit and luckily I have had no issues regarding vibrations.
    I'd try the CB drop kit first.
    P.S. Your TRD Pro looks sweet!
    2004TacoBill[OP] likes this.
  4. Nov 27, 2017 at 3:32 PM
    TacoMeSir
    TacoMeSir WiFi Guru
    Tim
    North GA
    2024 TRD Off-Road Hybrid Premium
    Stock
    ^^ This.
  5. Nov 27, 2017 at 8:31 PM
    Lostsheep
    Lostsheep Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    I’m calling BS. It’s a very easy problem to solve if you understand what you’re doing and you get the proper angles on your u joints.
    ETA: bring it by my shop and I’ll put my money where my mouth is
    Rexfordian13 likes this.
  6. Nov 27, 2017 at 8:44 PM
    2004TacoBill
    2004TacoBill [OP] Well-Known Member
    well, I got my Carrier bearing drop kit and the rear Solid Steel Axle Degree Shims from Toytec delivered today so tomorrow I'm taking my truck to a local 4wd shop that I found on Yelp who has lots of very good reviews and I'm hoping they can help. I hope they can measure the driveline angles and tell what exactly what I need to correct them back to factory specs and hopefully this will resolve the issue. I'll post tomorrow what I find out after they take a look.
    FJ to Taco and Lostsheep like this.
  7. Dec 16, 2017 at 7:01 AM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    OK so I understand that when lifting the rear it changes the angle of the rear dif and it causes a shutter at takeoff. I took the rear 1-inch blocks out of mine and the shutter appears to still be there ever so site. I mean you really have to look for it and NOT all the time like when the blocks were installed. So what gives ? I really liked the way it looked with the lift.
  8. Dec 16, 2017 at 7:17 AM
    p_chinnici
    p_chinnici Well-Known Member
    Pete
    South Nj
    2015 Trd Pro Access Cab, 2.5 Kings, Dakars
    2.5 Kings all around, HD Dakars -1 OL, Camburg Moog BJ UCA, Leer 100r topper, Prinsu rack
    looks awesome, hope you figure out the vibrations. btw what tire size are you running?
  9. Dec 16, 2017 at 12:20 PM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    Generally speaking, if the vibes are coming from the rear it’s your carrier bearing angle being off. If from the front then it’s the ecgs bushing needing to be replaced. Very common issues that are relatively inexpensive.
  10. Dec 17, 2017 at 5:29 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    You mean the factory bearing needs replaced. The ECGS IS the fix for front end vibration.
    MadRiverTaco[QUOTED] likes this.
  11. Dec 17, 2017 at 5:56 AM
    MadRiverTaco
    Brenden
    Waterbury, VT
    Yeah, I got that mixed up :anonymous: thanks for clarifying.
  12. Dec 17, 2017 at 11:28 AM
    2004TacoBill
    tires are bfg ko2 265/75/16
  13. Dec 17, 2017 at 11:47 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    OP what was the final result? When i installed the 3" in the front and rear I installed the OME CB drop at the same time expecting a vibe like my last truck had but I've never had any vibes at all. CB drop is a cheap 5 minute install involving 2 bolts it's the bheapest and easiest place to start. Of course as others have said finding out your angles first helps but I had the kit so threw it on in there and never an issue. It always strikes me odd as to how differently these trucks react to lifts and stuff
  14. Dec 17, 2017 at 11:50 AM
    2004TacoBill
    so here's the latest info......I had the Carrier bearing drop kit and the rear Solid Steel Axle Degree Shims from Toytec installed and nothing changed. I had my mechanic install the carrier bearing drop kit first and then drove it and I still noticed the minor vib/shutter from the rear upon take off. Then he installed the rear axle degree shims and I drove it and it still had the minor vib/shutter......mind you the vib/shutter is VERY minor and really not noticeable unless you have OCD like me and you know what to look for.
    I did take the truck to a local off road shop (Rebel Off Road) to have them diagnose it. They first measured the drive shaft angles and they said everything was fine there and the drive shaft angles were "straight" and didn't need any adjustments. They said they felt that the minor vib/shutter was a result of the tires.....I thought that was a bogus diagnose of the problem but oh well.....I think I wasted $120 by having them look it but I understand that they spent time looking at it and need to get paid a fair and reasonable price. They did say to absolutely leave in the axle degree shims but I could remove the carrier bearing drop kit if I wanted to as that wont affect anything.
    I took the truck back to Americas tire to have the tires rotated and balanced as it's been 2,500 miles since I bought the tires new. after they balanced and rotated the tires the GM told me that the front tires had minor cupping which he said was pretty normal for a lifted truck with those tires. The minor cupping tires are now on the back and the truck drives great with no shimmy like it had before at around 50mph. so balancing and rotating the tires took care of the 50 mph shimmy but he minor vib/shutter is still there.
    like I keep saying it's VERY minor and now I just ignore it......
    here's a shot in the dark.....any chance the actual driveshafts are not balanced properly???....I have no idea why I thought of that or if that actually means anything but my OCD is trying to find something else it could be....LOL
  15. Dec 17, 2017 at 11:52 AM
    #35
    2004TacoBill
    I was typing when you asked what the final result was.......look at my loooong update I just posted...glad you have no vibes!
    Casper66[QUOTED] likes this.
