Mirror backup camera in aftermarket headunit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffBoyardee, May 26, 2020.
  1. May 26, 2020 at 11:37 AM
    JeffBoyardee
    JeffBoyardee [OP] Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    baltimorebirds2 and Mstutch like this.
  2. May 26, 2020 at 1:21 PM
    tbr3345
    tbr3345 Well-Known Member
    Tom
    Sacramento, CA
    2010 TRD Sport DBL Cab Silver Streak Mica
    When I installed my Jensen in my 2010 TRD Sport I just ordered a License Plate Backup Cam from Crutchfield so No I have have both. You should be able to install a switch in aftermarket wiring to get a least cam in the head unit anytime. Look at manual and wire diagram for the reverse sensor wire might be possible there. Good luck. Buying the after market one was just simpler.
    Raylo likes this.
  3. May 26, 2020 at 2:16 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    You need to tap into your camera harness . And if you want it to come on at any time you need to supply the camera a seperated 12v source
  4. May 26, 2020 at 2:26 PM
    Shellshock
    Iowa
    Mstutch and jg805 like this.
  5. Jun 19, 2022 at 7:54 AM
    Mstutch
    Mstutch New Member
    Michael
    2009 Tacoma SR5
    Idk if you had a fix to this but I have the similar issue. The video lower in this thread worked, but I probably messed up somewhere as it displayed on my head unit distorted. I'm currently trying to find a way to redirect the output from the mirror to just the head unit. Once you connect the camera you can display it at anytime from the options in the alpine screen
  6. Jun 21, 2022 at 5:28 PM
    Fooburger
    Fooburger Well-Known Member
    Jim
    Southampton, PA
    2011 Tacoma sr5 access cab
    3” w/jba’s. LCE header w/intake spacer & hps cai tube
    My 2011 mirror cam is horrible, never would I put that on my Joying. I have joying ahd rev cam and pic is amazing, nigh-time is bright as day. Super easy install. Haven’t tried to abc yet
  7. Jun 21, 2022 at 5:41 PM
    baltimorebirds2
    baltimorebirds2 tacomama
    Brooks
    Maryland, United States
    2018 MGM Tacoma TRD Sport DCSB 4x4
    TRD Pro 17” Wheels, Toyo Open Country AT3 33s” (255/80/R17), Hooke Road Offroad Roof Rack, LEDs (Low Beams, High Beams, Fog Lights, Interior Lights, Reverse Lights, License Plate Lights), Diode Dynamics SS3 Sport Fog Lights (Yellow), Sequential Turn Signals, OME Nitrocharger Plus, OME 4004's & HS 0.5 Spacer for 3" Lift, JBA UCA, Icon RXT Option 2 Leaf Springs 2.25" Lift, Yukon Clamshell Bushing, Alpine ILX W-650 Stereo, Infinity Primus 6004a Amplifier (140w*2), Sound Ordnance M75-4 Amplifier (75w*4), Infinity Kappa 693C Component 6x9 Speakers, Infinity Kappa 63XF 6.5 Speakers, TRD Shift Knob, Black Emblem Overlays, TRD Grille Badge, OEM Door Sill Protectors, Driver’s Seat Jackers, Pop and Lock Power Tailgate Lock, AJT Designs start button and trim, 4x4 knob, shifter trim, and cupholder trim, MESO Customs Vent Rings and Door Handle Covers, Gasshole, Drop Stops, AC Drain Mod, Bed Lights, Rough Country Roll Up Tonneau Cover, Window Tint, KDMAX Tune
    I have the same stereo. To get mine to work on my 2018, there was a Crux Harness on crutchfield. It took the output from the camera and turned it into a yellow rca, which I could just plug into the head unit. That being said, your camera’s output wouldn’t run to the stereo at all I wouldn’t think. Unless you can find a harness that will somehow convert it somewhere, I would find an aftermarket camera that fits in the stock location, that either outputs to a yellow RCA to plug into your stereo.
    I can’t see mine on demand, it might be because the camera might not be powered unless the reverse trigger wire sends power to it, or if it triggers a power wire sent to it. In that case, if you find an aftermarket one that is powered when the truck is on or if you can find one where you can trigger it with one of your amp turn on leads, that might allow you to see it whenever you want. Some others on here may be able to verify whether or not the camera has power to it all the all the time or not, but I’m betting that it doesn’t unless in reverse. Just some ideas.
    Hope this helps.
    Brooks
  8. Jun 21, 2022 at 6:13 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    Which joying do you have? Do you like it? I'm over this Alpine. It's pretty meh, and Android auto doesn't even work in it anymore, and to be honest, I didn't care for it, even when it did work.
  9. Jun 22, 2022 at 4:44 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    As noted above, install another cam for the head unit. Gives you redundancy and a different view. Another benefit is that you can leave a little excess cable in the back tucked under the license plate and have alternate mounts depending on whether you have bike racks, spare tire racks, trailers (with an extension cable) or whatever. Make up some GoPro mount points and clip the cam to wherever you need it whenever.
    Edit: BTW I am using an Alpine cam with my Pioneer head unit. I tried an Amazon cheap Chinese offering but it started leaking in a couple of months. The Alpine cam has been perfect for several years now.
  10. Jun 23, 2022 at 8:19 AM
    Fooburger
    Jim
    Southampton, PA
    8” with buttons, it looks to good to not love it. The Bluetooth mic doesn’t work so great for me, didnt try the external mic yet, I just turn off Bluetooth.
    I installed GY6.35 OSRAM bulbs for the reverse lights and the Joying ahd rev camera and can’t believe how bright and perfect the pic is. Don’t have to lower the tinted windows to see at night now.
  11. Jul 9, 2023 at 2:20 PM
    MHersh328
    MHersh328 Active Member
    2011 Tacoma 4.0 4dr base trim
