Mirror Control Switch Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jabrackin, Jul 20, 2015.
  1. Feb 18, 2022 at 12:38 PM
    #61
    TRDProBuddy
    TRDProBuddy Well-Known Member
    MD (Kent Island)
    2015 TRD Pro (Inferno)
    That is how I understood it as there is already power coming in on those 2 wires to power the backlight full time, which to me, they need to be cut as you would not want to splice into them and add another power source
    BlkDakDave likes this.
  2. Sep 5, 2022 at 10:41 AM
    #62
    4x4MA
    4x4MA Member
    15 ⛈ TROOPER
    Heavy ‍♂️ Lifted
    Where can I buy the plug and play harness?
  3. Sep 7, 2022 at 5:29 PM
    #63
    nazlax10
    nazlax10 Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    #63
    Williston likes this.
  4. Sep 8, 2022 at 1:11 PM
    #64
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    #64
  5. Sep 9, 2022 at 7:53 PM
    #65
    nazlax10
    David
    Woodstock, GA
    #65
    Norton likes this.
  6. Dec 8, 2022 at 10:24 AM
    #66
    gil_S
    gil_S Well-Known Member
    Seattle, WA
    Anyone know if that wiring harness includes wires to tap into to use the window fold button for the heated side view mirror mod?
  7. Dec 8, 2022 at 2:44 PM
    #67
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    I used the mirror fold switch and wires to activate a timer, which sends current to the heated mirrors via a relay.
    PreTac93 and gil_S[QUOTED] like this.
  8. Dec 8, 2022 at 5:45 PM
    #68
    Tacospike
    Two Trucks
    Anyone here try this on a tundra?
  9. Dec 9, 2022 at 6:14 PM
    #69
    gil_S
    Seattle, WA
    Interesting, so the switch doesn't stay depressed after you press it? Is there a special type of relay for the timer?
  10. Dec 9, 2022 at 7:46 PM
    #70
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    You have to clip a piece which turns it into a momentary switch. There are a few timers. I do not have the link handy but if you look up 4Runner mirror or heated mirrors there are some write ups.
  11. Dec 10, 2022 at 5:00 AM
    #71
    JAGCanada
    Canada
    gil_S[QUOTED] and reallifedog like this.
  12. Jun 26, 2025 at 3:07 PM
    #72
    TH3RMIT6
    TH3RMIT6 New Member
    Jacob
    2015 Tacoma Black TRD-OffRoad
    Tactical
    Did this mod but only the right and up buttons work on the mirror switch for my 2015 tacoma any ideas?
  13. Jun 26, 2025 at 3:20 PM
    #73
    JAGCanada
    Canada
    Did you buy a harness and rewire it?
  14. Jun 26, 2025 at 3:36 PM
    #74
    TH3RMIT6
    TH3RMIT6 New Member
    Jacob
    Tactical
    I did buy the ebay scion/toyota harness
    #74
  15. Jun 26, 2025 at 3:57 PM
    #75
    JAGCanada
    Canada
    The harness must not be connecting the pins on the new switch to the original connector. This thread will give you the pinout of the connector/Tacoma switch. You'll have to figure out the pinout of the new switch and make sure the harness is connecting the correct pins on the switch to the correct pins in the dash.
    https://www.tacomaworld.com/threads/how-to-measure-power-mirror-switch.851334/
  16. Jun 26, 2025 at 3:59 PM
    #76
    JAGCanada
    Canada
    Can you move both mirrors or just one?
  17. Jun 26, 2025 at 4:21 PM
    #77
    TH3RMIT6
    TH3RMIT6 New Member
    Jacob
    Tactical
    Both mirriors same thing
  18. Jun 26, 2025 at 4:24 PM
    #78
    JAGCanada
    Canada
    Which switch did you buy?
  19. Jun 26, 2025 at 7:02 PM
    #79
    TH3RMIT6
    TH3RMIT6 New Member
    Jacob
    Tactical
    Looks like i bought the prius switch
  20. Jun 27, 2025 at 4:24 AM
    #80
    JAGCanada
    Canada
    I had a look at the prius wiring diagram. The Tacoma and Prius function is the same, as you would expect. If both mirrors can be selected and you can move them both up and both right, the power and ground must be connected correctly. I would suggest back probing the switch to make sure it is functioning correctly. See link in #75 above.
