Mirror shake help needed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rpeker, Jan 1, 2013.
  1. Nov 3, 2019 at 2:03 PM
    seanb06
    seanb06 Well-Known Member
    Sean
    AZ
    06 PreRunner TRD OR
    Looks like the two screws under the cover are stripped on my drivers side. Is there anything in the mirror mount I can repair or is it just a new mirror to solve it do you think?
  2. Nov 3, 2019 at 4:43 PM
    binge_stinker
    binge_stinker Well-Known Member
    2005 4X4 MT6 DCSB
    Power sliding rear cab window retrofit
    Had the same issue, threads on the bracket that attaches to the mirror housing were damaged so I removed the screws, wrapped them in teflon tape, and reinstalled. I've bombed down washboard roads at 50 mph and it hasn't shaken loose like it typically would have and imagine it'll hold up for a while still. Obviously not the greatest fix but I plan on doing a 4Runner mirror swap soon.
  3. Nov 4, 2019 at 4:31 AM
    badger
    badger Well-Known Member
    07 SR5
    If you take the three screws out and remove the mirror, there is a cast metal plate that can be repaired. I would drill it and tap for a larger screw size.
    Also, an old school trick that works to kill vibration in mirrors is to use stick on lead wheel weights on the back of the glass.
  4. Nov 27, 2019 at 12:50 PM
    Colman Roberts
    Colman Roberts New Member
    Colman
    2006 Toyota Tacoma
    Can you buy the screws without buying the whole mirror?
  5. Nov 27, 2019 at 4:04 PM
    seanb06
    Sean
    AZ
    06 PreRunner TRD OR
  6. Jun 17, 2020 at 10:04 AM
    scott_b
    scott_b Well-Known Member
    The Old North State
    '12 TRD Sport AC MT
    I had the same issue and symptoms as the OP. I tried all the suggestions listed above with no change. I eventually found that the motor housing was what was shaking. There was only one screw holding it in place and two other screws in the mirror housing not holding anything. I moved the "phantom" screws to the spots for the motor housing (behind the white plastic piece) and it fixed the issue.
    Rocketball likes this.
  7. May 9, 2023 at 3:39 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    Had this issue, ended up being the mirror glass itself not clipping tight enough to the flange that holds it to the motor. I pulled it off, wrapped some thin foam pieces around the mounts on the flange, and then popped the mirror back on - it's much tighter, and no more shaking.
  8. May 9, 2023 at 1:32 PM
    trdspectacoma
    trdspectacoma Well-Known Member
    B.I Hawaii
    13 dCab preRunner
    I have the same problem with the TYC aftermarket ones. the motor just needed to be tightened
  9. May 9, 2023 at 1:40 PM
    19992021Taco
    19992021Taco Well-Known Member
    1999 and 2021 Tacoma
    Mine shakes bad on my 99. Thanks for all the tips. Need to take a closer look.
