Mirror tap blend mount
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gdemedeiros, Nov 19, 2020.
  1. Nov 19, 2020 at 12:11 PM
    gdemedeiros
    gdemedeiros [OP] Member
    William
    2019 4x4 Tacoma TRD Sport Cav Blue
    I have a blend mount setup with Escort IX and attached M1 dash cam both from Escort.
    Escort allows to set auto off timer on radar through radar app but not on DashCam app. My DashCam stays running 24:7 and I don’t know how to stop this.
    It’s getting power from the the mirror I tapped into. Please help
  2. Nov 19, 2020 at 2:51 PM
    td_05
    td_05 New Member
    2020 Offroad
    running even when truck is locked and off?
  3. Nov 19, 2020 at 2:59 PM
    gdemedeiros
    William
  4. Nov 19, 2020 at 3:09 PM
    td_05
    td_05 New Member
    2020 Offroad
    Well, I don't see a whole lot of threads on the topic for tacos. I've installed 2 on different vehicles. Different ports will always have power, vs power off with car off vs not power off until car is locked. Did you use some sort of DIY guide from another user? Obv you tapped into a hot port. Maybe try using a different spot on the harness, or use a voltmeter to determine which ports loose power when turned off.
