Mirror tap gone wrong..
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nixsamis, Sep 19, 2020.
  1. Sep 19, 2020 at 4:36 AM
    Nixsamis
    Nixsamis [OP] Member
    I tapped into the rear view mirror for a V1 Gen2 and crossed the wires initially. I now have the detector working but all my constant on options aren’t working until the truck is started. I can’t seem to find a fuse that is blown. Trying real hard not to take it in to the dealer.
    davidstacoma likes this.
  2. Sep 19, 2020 at 4:37 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Please change the title as HELP is for people that are stuck.
    shakerhood and Da_TAKOma like this.
  3. Sep 19, 2020 at 4:40 AM
    Nixsamis
    Apologize new to the site
  4. Sep 19, 2020 at 5:03 AM
    Nixsamis
    Yes , still nothing. No remote door locks doesn’t keep anything in memory. No emergency flashers. Anything you can run with the truck off is not working until I start it.
  5. Sep 19, 2020 at 5:07 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I'd start by checking ALL the fuses under the hood and behind the dash.
    What wire did you tap into? I could look at a diagram and possibly help you out.
    Boghog1 likes this.
  6. Sep 19, 2020 at 5:30 AM
    Nixsamis
    The rear view mirror. There are three wires, the blue is the constant on. Beige is power with ignition on and the white/black is ground. I crossed the two power, which is the issue. It has to be a fuse(I hope)
  7. Sep 19, 2020 at 5:39 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    This is the schematic for a 2016. But the Blue wire is also shown as unswitched here. So maybe it's the same fuse in your truck? What year is your truck?
  8. Sep 19, 2020 at 5:39 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Here is the wiring diagram (for a 2017). Check those two fuses first.
    Fitz235 and DES2009 like this.
  9. Sep 19, 2020 at 5:42 AM
    Nixsamis
    I have a 2016
  10. Sep 19, 2020 at 5:45 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Look for that "10amp ECU-B No. 3" fuse shown near the left side on the schematic. Sorry, I don't know the physical location of the fuse.
  11. Sep 19, 2020 at 5:51 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    The wiring should be the same.
  12. Sep 19, 2020 at 5:53 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Here is the location for that fuse.
    Fitz235 and DES2009[QUOTED] like this.
  13. Sep 19, 2020 at 7:56 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Well? Any update?
  14. Sep 19, 2020 at 8:00 AM
    Nixsamis
    I will remove and check all fuses when I get off work today 3:00 cst
    Thank you guys
    DES2009 likes this.
  15. Sep 19, 2020 at 11:29 AM
    caribe makaira
    Caribbean, Puerto Rico
  16. Sep 19, 2020 at 11:40 AM
    caribe makaira
    Bleep100 likes this.
  17. Sep 19, 2020 at 1:19 PM
    Nixsamis
    Thank you all for the help. It was the center number 10amp fuse under the hood. Glad I joined this site! Really appreciate you guys
  18. Apr 8, 2024 at 8:09 PM
    Arrayofsun
    Arrayofsun New Member
    2023 White Tacoma TRD Sport
    I mistakenly crossed the blue and white wires on my rearview mirror too, ugh!! Thank you all for offering the solution and pointing out that it was a fuse, and where it was located. This has been eating me up all day and it solved my problem!
    Fitz235 likes this.
