Mirror Upgrade
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mr.Fahrenheit, Dec 24, 2009.
  1. Dec 24, 2009 at 7:10 PM
    Mr.Fahrenheit
    Mr.Fahrenheit [OP] Dennis = sinneD
    American Canyon, California
    01 Taco 3.4L 5spd TRD
    K&N CAI, HUSKY LINERS, LOW PRO TOOL BOX, GRAY WIRE MOD, OPTIMA RED TOP, GOODRIDGE STEEL BRAKE LINES, FAB TECH LIFT,
    Hey TW
    Got a question, i have a 99 taco and i really like the size difference that the 01-04 taco have on the side mirrors. i want to install some 01-04 side mirrors but i currently have manual mirrors and was wondering if the 01-04 manual mirror work just like the 99 mirrors?? is there a little rod that goes through the door to adjust from the inside or do you just move the mirror by hand like the 99?? thanks:D
  2. Dec 24, 2009 at 7:13 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    yes it will work. Some of the mirrors do have the rod to adjust on the inside. You can install anything up to 2004 mirrors, and they will work. Obviously, if you want to put the power 01-04 mirrors, you will need to wire..I plan on doing this as soon as I can find some reasonably priced mirrors.
  3. Dec 25, 2009 at 6:21 PM
    Mr.Fahrenheit
    ok so the manual mirrors for the 01-04 all are adjusted from the inside rod?? or do they normally dont have a rod. id rather that they didnt that way i dont have to make a hole in the corner trim to accept the adjustment rod.
  4. Dec 25, 2009 at 8:18 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    no "rod" on mine, there is a square button on the arm rest that you use to control them...
    wiring should be easy, just cut before the harnesses and replace with your harnesses...
  5. Dec 25, 2009 at 10:24 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Not all are adjustable with the rod. Some are, some are electric and some you have to manually adjust from the outside.
  6. Dec 26, 2009 at 12:21 AM
    j_cyrus
    j_cyrus Well-Known Member
    Rickman TN
    I have a 99 but my mirrors are power. Will the 01-04 power mirrors work on mine?
  7. Dec 27, 2009 at 2:55 PM
    Mr.Fahrenheit
    ya what im looking for is manual mirrors from the 01-04 tacos i dont want electronic. so it sounds like some manual mirrors can be adjusted from the outside and some from the inside? i prefer from the outside.
  8. Dec 30, 2009 at 8:40 PM
    Mr.Fahrenheit
    does any one have pictures of their manual 01-04 side mirrors??
  9. Dec 30, 2009 at 10:56 PM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    Like mine????
  10. Dec 31, 2009 at 8:03 AM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    if anyone has the first gen power mirrors, I'll trade you my non powered!
  11. Dec 31, 2009 at 4:59 PM
    Mr.Fahrenheit
    no looking for 01-04 manual mirrors, inside picture.
  12. Dec 31, 2009 at 5:36 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    What do you need to see? Each of the Tacos use 3 bolts/nuts to hold them in. There is a hole between the 3 bolts ready for the install of the electrical ones.
  13. Jan 2, 2010 at 10:10 AM
    Mr.Fahrenheit
    i just wanted to see if the 01-04 manual mirrors have adjusting rod coming out of that hole. id rather not have a adjustment rod, i wanna know if the manual mirrors even have adjustment rods. my 99 manual one doesn't but does the 01-04 have them???
  14. Jan 2, 2010 at 10:15 AM
    SRQ TACO
    Damon
    Sarasota, Florida
    Those are them with the manual adjustment handle on the inside.
  15. Jan 3, 2010 at 1:13 PM
    Mr.Fahrenheit
    sorry but thats a 00 mirror. im looking for the larger 01-04 side mirrors. im wondering how the larger 01-04 side mirrors are adjusted.
  16. Jan 3, 2010 at 9:59 PM
    SRQ TACO
    Damon
    Sarasota, Florida
    All were powered I believe...
