(Mis)adventures removing the UCA bolt on my 2020
Discussion in 'Suspension' started by BitcoinSucks, May 5, 2021.
  1. May 5, 2021 at 1:24 PM
    BitcoinSucks
    BitcoinSucks [OP] Bitcoin Doesn't Actually Suck.
    Stefan
    Santa Cruz
    2020 MGM Offroad
    The idea of bending the sheet metal out of the way to remove this thing seems impossible; I did quite a number on it with vise grips and a pry bar, and still couldn't get clearance even on the driver's side which is allegedly easier.
    Is cutting the bolt head off and just replacing it going the opposite way the best/ easiest method of changing out my UCAs? I really don't want to pay someone else to do something I otherwise feel capable of doing, but it was admittedly very frustrating to get everything disassembled and then hit this roadblock. I've been told it's possible to get it out via bending, I just can't see how without mangling the metal even more than I already have, and if the solution is $30 for a pair of new bolts that sounds much better than a few hundred for a shop to do it for me.
  2. May 5, 2021 at 1:33 PM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    I had an easier time with the passenger side. Though I learned from the drivers side first.
    You’ll only need to bend the metal to get the bolt head past about an inch... then you’ll need to beat the crap out of it (don’t forget to unbolt the little black box on the bottom side of the battery). There is a little metal piece that you can’t bend, you just have to beat it past there. Sorry I don’t have any pics from when I did mine. The bending I did was ugly and jagged. Watch out for the wire bundle on the inside part of that lip too.
    You can cut the bolt but I’d still recommend installing it the correct way. I doubt the nut would loosen and fall off if you used locktite and torqued correctly but why take that chance. I’d your going to put larger tires on, look into beating the pinch weld, I’m pretty sure that will help take care of your issue too and save you time later... I think...
  3. May 5, 2021 at 2:17 PM
    RCRcer
    RCRcer Well-Known Member
    2015 OR DC
    This might ease your mind on cutting the bolts. This was in one of the UCA threads and the debate of cutting versus bending and the bolt threads facing uphill with the nut on top.
    Someone posted this from a field service manual. I thought I copied everything he posted but I just got the one page.
    Bertw192 likes this.
  4. May 5, 2021 at 3:50 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I cut my bolts and I helped @WrecklessAbandon bend his fender. From my perspective, cutting was much easier. I have no fear of my bolts coming undone. Honestly, when you retorque them, you'll realize that they won't come undone on their own. If you're worried about it, add some witness marks to the bolt and nut, so you can quickly visually check if they're backing off.
    My vote, spend the $30 and cut them :sawzall:
    Grossomotto likes this.
  5. May 5, 2021 at 4:05 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Have done both ways many times. Cutting UCA bolt is cleaner, easier, faster.
    If you are close to clearing, can hammer the bolt out. Hammer on the head of bolt only. If close, will slip right out.
  6. May 5, 2021 at 5:16 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    Keep bending...you're almost there and you don't have spare bolts laying around.
  7. May 30, 2021 at 5:15 PM
    tacomio877
    tacomio877 Active Member
    Seth
    2019cavalryblueDCSBTRDOF
    stock
    I know this is old but.... AIR HAMMER. The harbor freight one costs like $20 and it takes 5 min each side to hammer the sheet metal a bit and the bolt comes right out
  8. Nov 5, 2021 at 6:44 PM
    Rollo67
    Rollo67 Well-Known Member
    joeyv141 likes this.
