MISC small items for sale - various
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by racebug68, Aug 30, 2020.
  1. Aug 30, 2020 at 10:59 PM
    racebug68
    racebug68 [OP] Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    Hi, have a few things and will continue to add to this post/thread as I uncover more.
    I am absolutely in favor of bundle deals and combined shipping.
    no loss tire valve caps - $10 shipped.
    Trailer harness replacement. - $50 shipped.
    If you have scraped your trailer harness, and broken the plastic body of the 7 pin plug like I did, then you need this. The dealer wants something crazy like $200 for this part. However, the Honda is the exact same plastic body with different length wires and that is what this is.
    https://www.amazon.com/gp/product/B00P44JQMU/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    So you can dissassemble the OEM toyota plug on your truck, to get the wires/connectors out, disassemble this unit to use the full body, and plug all the toyota wires into this body and then you are brand new again. There are a few write ups on TW for this with good pics. I didn't end up using this because I bought a high clearance rear bumper that uses a different kind of trailer plug anyway, which I spliced my wiring for.
    Sheet metal rear fender reinforcements, lower bedside to bed - $10 shipped.
    These are the parts that you don't need anymore when you cut the bedside for high clearance rear bumper.
    OEM fuel pump, with filter, suction tube, harness and pressure pot - Free if you pay shipping
    This is what you are left with when you upgrade to a high flow aftermarket pump.
    ARB compressor switch face rocker, new, not broken clips (not complete switch) - $5 shipped
    Fog light bulb, with bulb holder and harness pigtails - free with other purchase
    2 flat wiring connector / extension. Good for making waterproof disconnecting electrical connections - free with other purchase
    Front airbag crash sensor, tested working. I bought a replacement but turns out I had a pinched wire causing my airbag light issue. Double checked with this sensor and my original
    sensor, both worked to keep the light off - $10 shipped.
    Diff drop spacers with longer bolts. From Toytec. $15 shipped.
  2. Sep 5, 2020 at 8:38 PM
    racebug68
    Travis
    Chandler, AZ
    bump - bunch of new things added
  3. Sep 8, 2020 at 9:54 AM
    racebug68
    Travis
    Chandler, AZ
    bump, make offers
  4. Sep 18, 2020 at 8:16 AM
    Craze82eny
    Craze82eny Member
    Willie
    2009 Tacoma
    Interested in ditch switch and on/off switch
  5. Sep 18, 2020 at 9:11 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Bump for a good seller!
    Travis, BTW, I got those metal skids mounted up :) Front one seemed to fit a bit wonky but once I cleaned out all the threads and used some c-clamps to help align the leading edge it bolted right up. Gas tank skid is up next but I'm thinking I may hold off on that till my tank is closer to empty.
  6. Sep 18, 2020 at 10:01 AM
    racebug68
    Travis
    Chandler, AZ
    For that skid, put the 4 main bolts in and leave slightly loose. Then put in the front bolts and you may need to use a jack or clamp to be able to draw it all the way up to the frame. Then tighten remaining. It came with spacers for the front, I don’t know why it was made that way but I slotted the holes to allow it to draw all the way up to the cross member.
    Good luck with it all!
  7. Sep 18, 2020 at 10:14 AM
    clenkeit
    Colin
    Lakewood, CA
    Ah, OK, that makes mores sense now. I had thought maybe it hadn't been bent quite properly. What you explain is basically what I did except I used c-clamps to bring the leading edge up to the frame - worked great!
