Misfire at idle and slight throttle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OdinTheTaco, Mar 15, 2021.
  1. Mar 15, 2021 at 10:39 AM
    OdinTheTaco
    OdinTheTaco [OP] Member
    Andrew
    2008 Tacoma PreRunner SR5
    Am I posting this in the correct section? If not let me know.
    2008 Tacoma DCLB 4.0L
    130,000
    So I have this slight misfire at idle, you can feel it while sitting at a light. Also under very light acceleration you can feel the truck jerk a little bit.
    No codes
    Ive changed the plugs twice, first with NGK Iridium IX Spark Plug (LFR6AIX-11)
    then Denso Spark Plug Standard (K20HR-U11), nothing changed.
    Under full acceleration it feels like its going from 80% power back to 100% power every few seconds. It didn't do this when i bought it, seems like it appeared overnight. Before I start throwing money at the truck does anyone have any ideas what is causing this?
    Im about ready to buy injectors, O2 sensors, and coils. Tried living with it for a month buts its really getting annoying haha.
    Let me know if you need any other information.
    Update:
    Replaced Coils with denson
    Replaced both upstream o2s with denso
    Still misfiing.
    Just ordered reman denso injectors that have been flow tested to match each other. If that doesnt work ill try the MAF next. Ill eventually find the culprit.
  2. Mar 15, 2021 at 1:13 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Have you tried cleaning the Mass Air Flow Sensor and Throttle Body?
    There is a lot of troubleshooting between what you have and going down the money pit. Injectors,O2 Sensors and Coils = Big $$$.
  3. Mar 15, 2021 at 1:31 PM
    OdinTheTaco
    Andrew
    Yea I forgot to mention I had done those also. I just want the truck fixed, at this point I'll pay whatever I need to haha.
  4. Mar 15, 2021 at 1:34 PM
    Stemmy
    Stemmy Certified Wombat Rancher
    Rob
    Pennsylvania
    2013 Pyrite Mica DCLB
    what brand of coils did you use?
  5. Mar 15, 2021 at 1:35 PM
    OdinTheTaco
    Andrew
    The coils on it are still the factory ones I haven't replaced those I was just seeing if I should replace them or if there is a way to test them.
  6. Mar 15, 2021 at 1:38 PM
    Stemmy
    Rob
    Pennsylvania
    you'd have a check engine light if a coil was bad & you'd definitely be able to tell. only way to see is with a scanner. I had one go bad on my '13 and pulled the code with my scangauge.
  7. Mar 15, 2021 at 1:47 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    There are a million things that could cause a low level misfire as you have. Hard to diagnose since you have no codes.
    This is what Toyota lists for trouble areas on a misfire conditions.
    •Open or short in engine wire harness
    •Connector connection
    •Vacuum hose connections
    •Ignition system
    •Injector
    •Fuel pressure
    •Air induction system
    •Mass Air Flow (MAF) meter
    •Engine Coolant Temperature (ECT) sensor
    •Compression pressure
    •Valve clearance
    •Valve timing
    •PCV valve and hose
    •PCV hose connections
    •ECM
  8. Mar 15, 2021 at 1:48 PM
    OdinTheTaco
    Andrew
    There are no codes already had a scanner hooked up
  9. Mar 15, 2021 at 2:05 PM
    kuba83
    kuba83 Member
    Texas
    2006 Tacoma pre-runner TRD sport 2wd LB
    Icon Alloy Rebound wheels, Nitto Terra Grappler, 2 inch lift Bilstein 5100's
    Maybe not exactly the same but this might be worth a read...check the 6th post from "Nutsy" I had the "hesitation on acceleration" symptoms and a new fuel pump fixed it.
  10. Mar 15, 2021 at 2:10 PM
    OdinTheTaco
    Andrew
    Nice thank you!
  11. Dec 2, 2023 at 2:43 AM
    boulderz
    boulderz Well-Known Member
    OP did you ever sort this out?
  12. Dec 3, 2023 at 8:19 PM
    Taco? Who knows
    Taco? Who knows Well-Known Member
    New England
    2009 DCSB Off Road
    I'm interested if this was sorted out also.
