Misfire at idle.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mark_Stuff, Apr 29, 2021.
  1. Apr 29, 2021 at 12:29 PM
    Mark_Stuff
    Mark_Stuff [OP] New Member
    Mark
    1996 Tacoma 2.7l 4WD
    So I just recently bought a 1996 Tacoma with the 2.7l 3rz in it. One of the problems that it has is that it misfires when it is at idle and slowly gets worse as the engine warms up. I've already replaced the spark plugs and wires with some from NGK. I've replaced the distibutor rotor and cap. I also just replaced the fuel injectors and fuel filter.
    The misfire got a little better after I did the plugs and wires but the problem still persists. Do you guys have any suggestions?
  2. Apr 29, 2021 at 12:40 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Welcome to TW.
    Are you throwing any codes?
    Here’s the search results for 2.7 Misfire if you didn’t want to wait on eesponses.
    https://www.tacomaworld.com/search/13760148/?q=2.7+misfire&t=post&o=date&c[title_only]=1&c[node]=4
    Good Luck!
  3. Apr 29, 2021 at 12:41 PM
    Fantastic11
    Fantastic11 Well-Known Member
    1997 3.4L 4WD / 1996 3.4L 5-Lug
    Is it throwing any codes for the misfire? If so, try swapping coils with the missing cylinder.
    edit: nevermind, thought I read 6 cylinder. As others have said, check compression, valve clearances, etc.
  4. Apr 29, 2021 at 12:42 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Have the valve clearances been checked? I had a burnt valve and it did this a little bit.
    Abeyancer likes this.
  5. Apr 29, 2021 at 12:51 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Same, neglected 4cyl's always end up with burnt valves and you start loosing compression pretty quick. Happened on my old 2.7.
    Abeyancer and 0xDEADBEEF[QUOTED] like this.
  6. Apr 29, 2021 at 1:01 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Keep in mind mine had at least 250K when I bought it and I drove it for years until the valves burnt at around 325k. It was still my fault for not adjusting them when needed.
  7. Apr 29, 2021 at 1:02 PM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    Did you do a compression test? My 96 taco blew a head gasket and had a miss with coolant burning in the combustion chamber.
    Fuel injectors would be the next thing to replace.
  8. Apr 29, 2021 at 5:43 PM
    Mark_Stuff
    Mark
    So the motor was rebuilt 9,000 miles ago. It got new gaskets all the way around. So I really hope it's not a head gasket. I'm planning on doing a compression test soon... just need to get the tool. I'll check the valve clearances though.
    It is also throwing codes. It's saying there is a misfire in the 2nd, 3rd, and 4th cylinder.
    Thanks for the responses guys
  9. Apr 29, 2021 at 7:16 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Swap the #1 plug wire for #2 and see if the code swaps.
  10. Apr 29, 2021 at 7:35 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    That many misfires? Oof
    Check the exhaust manifold, I had a bunch of cracks in my old 3rz 4runner that I believe caused it to miss ... but I wasn't throwing any codes
  11. Apr 29, 2021 at 7:37 PM
    0xDEADBEEF
    Whats the coil setup like on that engine? Could a/the coil be the culprit?
  12. Apr 29, 2021 at 7:46 PM
    Fantastic11
    Just make it misfire in cylinder #1 as well and it should start running right again. :D
  13. Apr 29, 2021 at 7:47 PM
    Abeyancer
    Jimmie
    PNW
    It's a 96 so he's got a distributor
  14. Apr 29, 2021 at 7:51 PM
    0xDEADBEEF
    Thats got to be driven by a coil at somepoint though? I would think a weak one might be the common thing between fires on multiple cylinders.
    Abeyancer[QUOTED] likes this.
  15. Apr 29, 2021 at 8:11 PM
    Abeyancer
    Jimmie
    PNW
    Duh, yea you're absolutely correct there has to be a primary ignition coil
    I've never personally dealt with a dizzy 3rz so I don't know
    0xDEADBEEF[QUOTED] likes this.
