Misfire Cyl 6 at startup
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dknappert, Sep 2, 2015.
  1. Sep 2, 2015 at 3:23 PM
    dknappert
    dknappert [OP] Well-Known Member
    david
    Hey guy I just start having this problem. Sometimes when i startup the truck is shakes a little, i knew it was a miss and i confirmed with a obd scanner. I knew i needed to change plugs anyway so i put in all new ngk iridiums and swapped the coil on cyl 2 just in case it was a coil. after clearing the codes the check engine light came back on with the same problem. Brought the truck to my father in laws part store and tested for leaking headgasket with a combustion leak detector. The blue liquid never turned yellow so thats a negative.. Any suggestions on where to look next?
    It doesnt miss at every startup, sometimes in the afternoon, sometimes in the morning, sometimes at night..
  2. Sep 2, 2015 at 3:28 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    take those irridiums..... and change them out for the proper copper core plugs as listed in the owner manual.
    Clean your MAF, and throttle body. Run some quality injector cleaner (Redline S1, Gumout with regain)
    AR15xAR10 and Lester Lugnut like this.
  3. Sep 2, 2015 at 4:36 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    After doing what he said swap the fuel injector, If the problem follows it to the next cylinder change it out.
  4. Sep 2, 2015 at 4:45 PM
    nd4spdbh
    SoCal
    good call.
    KISS method always with toyota.... as 99% of the time its the simple things that will fix your issue.
  5. Sep 2, 2015 at 5:26 PM
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    KISS?
  6. Sep 2, 2015 at 5:30 PM
    Drivesector
    TRD sport
    keep It Simple Stupid = KISS
  7. Sep 2, 2015 at 5:33 PM
    TacomaZL
    Illinois
    Oh the irony of my question hahahaha
  8. Sep 2, 2015 at 6:12 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Just because the head gasket isn't leaking enough compression gasses into the cooling system for the test liquid to change colour doesn't mean that the head gasket is not weeping some coolant into the cylinder when cold. Pull #6 plug after sitting overnight, and have someone crank it while holding a white paper towel over the spark plug hole. Any wetness or pink colour on the towel is an obvious sign.
    #6 head gasket is the one that seems to fail on the earlier 1GR's, are you 2005?
    12TRDTacoma and 1MK like this.
  9. Sep 2, 2015 at 6:46 PM
    dknappert
    david
    Yeah its a 2005.. I was afraid of having to check for head gasket problems again.. how long does it take to swap injectors?
  10. Sep 2, 2015 at 6:47 PM
    dknappert
    david
    I don't think iridiums would cause a problem, i found lots of guys on the forums that said they use them with no issues
  11. Sep 2, 2015 at 7:47 PM
    LN13
    LN13 Well-Known Member
    Dave
    Cave Creek AZ
    2024 TRD OR Hybrid
    Does overflow not return water to radiator? Mine would sometimes and then sometimes not.
    That was the same cylinder issue I had...I took it in 2x after thinking it was a head gasket..both times Toyota said compression test was fine and not head gasket....over a year later truck finally overheated and they confirmed it was head gasket. Truck had about 160K on it when I needed repair. I wanted Toyota to do the repair thinking a recall would be issued and I could get reimbursed.
  12. Sep 2, 2015 at 8:00 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    HG. Is it eating coolant? Check my build for parts and DIY costs.
  13. Sep 2, 2015 at 8:01 PM
    dknappert
    david
    mine has 183,000 doesn't use up any coolant, always stays full.. but if its just seeping then i wouldn't really notice. ill swap injectors and let you guys know what happens!
  14. Sep 2, 2015 at 10:48 PM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    You might also swap the coil pack with another cylinder to see if it follows that coil pack to eliminate or identify a coil pack issue.
  15. Sep 2, 2015 at 11:30 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Maybe you missed it in the first post, he already did with #2
  16. Sep 2, 2015 at 11:32 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    No issues with them here. Will probably buy copper denso's next time, but they are there for a while more.
  17. Sep 3, 2015 at 9:28 PM
    dknappert
    david
    Well its gotten worse, now its really drinking coolant and you can see a little steam coming from the exhaust.. Bummer..
    at least it doesn't look like a super difficult job to change headgaskets, and while i have the heads off i might as well resurface is and check all the valves. Maybe even replace the seals
  18. Sep 3, 2015 at 10:22 PM
    Wrench1225
    Wrench1225 Well-Known Member
    jim
    NY
    SR5 4x4 db cab sb
    Rock sliders,total skids,toytec3" lift w adjustable UCA's and O ME,leaf spring pack, w toytec 2.5 rear shocks,diff.drop andBF Goodrich A/T 275 70 R16 (spare fits nicely under bed) Ultra machined Wheels, front camera. Seat covers,Bed liner spray(can't put a scratch in it) currently pricing diff.lockers with heavy duty pumpkin gears. Lastly winch w low profile bumper
    Hello there what you need to do with a cylinder leak down test you have to determine which cylinder is leaking . Go to any auto parts store they sell the kit hook it up to a compressor put the required PS I in the cylinder when its at top dead center then see what the gauge tells you with regards to what percent of that cylinder is leaking I listen to determined where it's leaking from. For example if you hear aire escaping into the oil pan you know your piston rings are defective if at PCV valve intake valve is bad if you here Eric scaping in the exhaust system exhaust valve is defective need any help text me good luck this could be a bitch of a job?
  19. Sep 12, 2015 at 1:15 PM
    dknappert
    david
    Yeah so far it's its a bitch of a job... Good thing my father in law owns the local carquest shop!
    :yes:
  20. Sep 12, 2015 at 1:16 PM
    dknappert
    david
