Misfire Cyl 6 at startup
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dknappert, Sep 2, 2015.
  1. Sep 12, 2015 at 1:32 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Bummer, but good luck! Not terribly difficult, just time consuming. Don't follow any of foampile's blunders.
    DoorDing likes this.
  2. Sep 12, 2015 at 1:44 PM
    Wrench1225
    Wrench1225 Well-Known Member
    jim
    NY
    SR5 4x4 db cab sb
    Rock sliders,total skids,toytec3" lift w adjustable UCA's and O ME,leaf spring pack, w toytec 2.5 rear shocks,diff.drop andBF Goodrich A/T 275 70 R16 (spare fits nicely under bed) Ultra machined Wheels, front camera. Seat covers,Bed liner spray(can't put a scratch in it) currently pricing diff.lockers with heavy duty pumpkin gears. Lastly winch w low profile bumper
    Don't I know it. Take A lieve it helps or a Yl with strong hands lol....
  3. Sep 13, 2015 at 8:12 PM
    dknappert
    dknappert [OP] Well-Known Member
    david
    Just got to the timing cover. This project can be done without taking the engine out right? I saw that mechanics say it has to come out but some people said they didn't need to.
  4. Sep 13, 2015 at 8:38 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Does not need to come out. If you don't have them, get the FSM and a Haynes, all I used when I did mine.
    Once the timing cover is off, most all of the work is off the top, and by then you have already done pretty much everything that pulling the motor would have made easier.
  5. Sep 13, 2015 at 8:44 PM
    dknappert
    david
    Is there a timing cover gasket or so you just use a sealer?
  6. Sep 13, 2015 at 8:52 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I used the Toyota black FIPG, no solid gasket exists that I am aware of.
  7. Sep 13, 2015 at 10:32 PM
    Wrench1225
    jim
    NY
    SR5 4x4 db cab sb
    While your at it replace water pump, timing chain,crankshaft seal,cam shafts seal , and oil pump. Hey once you got her open might as well replace as many tins as possible. The next thing to go (if it hasn't already) is the fuel pump. The suspension on these puppies is unbelievably tough. Depends on how you ride them. If you decide to replace the tins ,ask father in law for All Data procedures to do the job. Glad to see you found the problem. Your doing the labor otherwise this one is $$$$$.
  8. Sep 14, 2015 at 6:16 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Well I was going to ask if you had checked for vacuum leaks, but onto the head gasket removal. Lol.
    There is a coolant passage which attaches both of the heads together, near the firewall. Each head has three bolts/nuts holding it on. Carefully remove that.
  9. Sep 14, 2015 at 8:50 AM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Um, no. Water pump and seals, the rest is unnecessary unless there are specific issues with those parts. Mine, and all others I have encountered that have gotten this far into the motor, have no issues with the chain or oil pump. All of the seals that are encountered should be replaced, and are part of the service kit that contains the HG itself. Fuel pump is completely unrelated to this project.
    Torspd likes this.
  10. Sep 14, 2015 at 9:04 AM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    Ill add my experience here from my 2005. had a SUPER small head gasket leak, only way to know was a coolant pressure test for about 6 hours, and i was able to see coolant in the cylinder.
    I did the head gaskets with help of my knowledgable friend in my garage. One mistake we made, was not realizing that the timing chain cover leaks on these trucks, it's a known issue. so now, a year later, my timing cover is leaking and you should definitely be aware of that when you put it back together. Maybe use extra silicon on the cover or something to try to prevent that from happening.
    Good luck!
    Thumby likes this.
  11. Sep 14, 2015 at 9:31 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The mating surfaces in the area behind the power steering pump is the most prone to leaking. Add a little extra silicone to that location.
    If yours is leaking, then use the Permatex 1 minute gasket maker. Clean and apply externally, and it will seal the leak. :thumbsup:
    ranger098 likes this.
  12. Sep 15, 2015 at 9:04 PM
    dknappert
    david
    whoah thanks guys! Yeah i put 15lbs pressure in the radiator then saw a little coolant in the cyl 6. Thats how i knew. I started taking the heads off tonight but i need a 10mm 12pt for the headbolts. Whats the easiest way to find all these darned o-rings and gaskets!? I got a headgasket set victor reinz, but heres a little list of what i need to get still
    Timing cover o-rings - Theres 5 I think
    Crank Pully bolt
    water outlet hoses (front) (Theres several of them)
    injector to manifold o-rings
    Im replacing the idle pulleys, water pump, all gaskets and o-rings i come across, had the alternator serviced.
    Checked the chain over and guides, they look really good so i'll leave them alone.
    anyway.. Ideas for best place to find the exact o-rings and such?
  13. Sep 15, 2015 at 9:21 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
  14. Sep 16, 2015 at 6:37 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  15. Sep 16, 2015 at 6:18 PM
    #35
    dknappert
    david
  16. Sep 17, 2015 at 8:29 PM
    #36
    dknappert
    david
  17. Sep 17, 2015 at 9:20 PM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Nice cross hatch there! How do the thrust surfaces look?
    Now get a catch can to keep your pistons looking good too. ;)
  18. Sep 18, 2015 at 7:32 AM
    #38
    dknappert
    david
    The thrust surfaces look great also. I dunno if i'd need a catch can, i don't race or have a turbo!
  19. Sep 18, 2015 at 9:38 AM
    #39
    ranger098
    Brian
    Minnesota
    Not to thread jack, but have you done this and confirmed that it is a long lasting fix? This is exactly what i am going to try, but was thinking it might not work....
  20. Sep 18, 2015 at 9:57 AM
    #40
    dknappert
    david
    My dad was a mechanic and owned a Part store years ago, he swears by Permitex's The Right Stuff.
    I figure if the surface was cleaned well and theirs not too much pressure where the leak is it would seal it.
