Misfire Cyl 6 at startup
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dknappert, Sep 2, 2015.
  1. Sep 18, 2015 at 2:40 PM
    #41
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yes. The Grey 1 Minute Gasket maker. Awesome stuff.
  2. Sep 24, 2015 at 1:56 PM
    #42
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    Put the gasket maker on yesterday, a few more trips to work and back and we'll see if i got the right spots....
  3. Oct 1, 2015 at 9:00 AM
    #43
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Any update?
  4. Oct 1, 2015 at 9:25 AM
    #44
    dknappert
    dknappert [OP] Well-Known Member
    david
    Yeah got it all done last weekend. Runs great! Guess I still didn't get enough sealer olnext to the power steering pump cause I got a small oil leak coming from just under the pump.. Otherwise everything went back together nicely. Toyota engineers things to be pretty straightforward to work on, ive always appreciated that. Pretty sure the reason the leak by the PS pump it cause it kinda pulls on the cover a little
  5. Oct 1, 2015 at 9:50 AM
    #45
    ranger098
    Brian
    Minnesota
    My leak for the time being is fixed... i pulled my 4000lb boat a few miles, and have gone through a tank of gas and the leak seems to be fixed. Cleaned the engine with brake cleaner and carefully put the sealer on the engine just above the power steering pump. I am often checking it to make sure i didnt miss a little spot but so far it seems good.
  6. Oct 1, 2015 at 9:55 AM
    #46
    dknappert
    david
    What did you use to seal it? My leak is all under the pump. I figure I'll take it off to clean and seal everything
  7. Oct 5, 2015 at 1:53 PM
    #47
    dknappert
    david
    All fixed no leaks! thanks everyone!
  8. Oct 5, 2015 at 4:36 PM
    #48
    Drivesector
    Drivesector Well-Known Member
    TRD sport
  9. Oct 5, 2015 at 5:41 PM
    #49
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Your dad is a smart man - it's great stuff. Not perfect for every application, but a good improvement where regular grey or black RTV are specified for sure.
    Good to hear to you got your issue resolved and running well again.
  10. Oct 5, 2015 at 5:51 PM
    #50
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Any codes stored ? Think I'd check plug wires before pulling injectors , is it random missfire ??
  11. Oct 5, 2015 at 5:54 PM
    #51
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    OOPs, you got it figured huh.... well then piss on my post then haha
  12. Mar 28, 2017 at 10:14 AM
    #52
    Thumby
    Thumby New Member
    2005 Tacoma TRD
    Did you remove the oil pan when you removed the timing chain cover?
