Misfire Cylinder 3 Running Rough
Discussion in '1st Gen. Tacomas (1995-2004)' started by ArsT100, May 23, 2011.
  1. Jun 9, 2011 at 4:49 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If the gas cap is more than 4yrs old, replace it.
  2. Jun 9, 2011 at 9:40 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Cool keep us posted. And like said above, replacing the fuel cap would be first on the list to diagnose the P0441
  3. Jun 13, 2011 at 2:52 PM
    ArsT100
    ArsT100 [OP] Member
    Avon, CT
    t100 3.4
    Here it is!!! I swaped the cylinder 2 injector with the cylinder 4 injector, after about 10 miles the check engine light came on. Later on I checked the codes and here is what I got:
    P0304 (cylinder 4 missfire)
    P0171 (system too lean)
    P0130 (O2 circuit malfunction)
    P0133 (O2 Sensor check slow response)
    Now, the P0304 seems to give me hard evidence that I had a bad injector because the missfire followed the injector. The three other codes confuse me because I haven't gotten them before and the only thing I changed was the injector????
    So I think it makes most sense to change the injector, can anyone tell me if I need to change all of the Injectors or can I get away with just the one..they aren't cheap!
    TacomaJunkie8691 likes this.
  4. Jun 13, 2011 at 4:56 PM
    98tacoma27
    Ben
    Not Beech Creek
    Don't worry about the other codes until you get the injector fixed. They could be a result of the bad injector. You can change one if you'd like.
    wilcam47 and TacomaJunkie8691 like this.
  5. Jun 13, 2011 at 8:10 PM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    ya the o2s aint nuthin to sweat over. but get that new injector before you burn a hole in the top of your piston
  6. Jun 22, 2011 at 4:35 PM
    ArsT100
    ArsT100 [OP] Member
    Avon, CT
    t100 3.4
    Injector!!!!! I replaced the injector with a reconditioned one that I purchased on ebay for $32. I've driven her for 2 days and runnin smooth and no check engine light. Dudes-thanks for all the advice
  7. Jun 22, 2011 at 5:52 PM
    davestaco
    David
    Schofield Barracks
    glad to hear its runnin good again
  8. Jul 30, 2017 at 10:39 AM
    Zerofear66
    Zerofear66 Well-Known Member
    2022 TRD Off Road Lunar Rock, 2014 Tundra Crew Max TRD 5.7L
    Is there a link with pics or video on how to change a fuel injector?
    I'm having the same issues on my 2002 Tacoma prerunner.
  9. Aug 1, 2017 at 6:10 PM
    Zerofear66
    So I replaced all 4 plugs with NGK platinum plugs. Cleaned the MAF. Disconnected the battery. Problem solved. Never had plugs fail like that before. The had about 20k miles on them. Coil packs same.
  10. Aug 2, 2017 at 7:13 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    its rare but possible...
    98tacoma27 likes this.
  11. Aug 2, 2017 at 7:32 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    Glad you got it solved. My 3.4 will misfire on occasion at startup, goes away after about 1 minute, usually happens in colder weather. Otherwise, runs like new.
    I have come to the conclusion it is a balky injector as changing the plugs and sparkplug wires makes no difference...
  12. Aug 2, 2017 at 8:59 AM
    Zerofear66
    I dumped a bottle of Techron and filled the tank with Chevron premium so I'll see if that helps as well. Unfortunately, I think I'm going to have to swap out the engine soon as I'm using a small amount of anti freeze with no leaks. I'm thinking my leaking head gasket is leading to the 3 cylinder misfire/plug fouling/ issue.
  13. Aug 2, 2017 at 10:14 AM
    austinsdad99
    austinsdad99 Well-Known Member
    1999 prerunner 3.4
    My truck had brand new ngk platinum g power plugs and cheapy wires on it when i got it, ran fine about 5k miles then had other issue, got that fixed and it would rev fine till about 3k rpm then go to cutting out.. it would not rev up past the 3k mark.. i was told maf etc etc.. for the heck of it i swapped to the ngk dual ground and a good ngk wire set.. fired it up and it revs wide open now, never would thought new plugs and wires would make it run like crap. but if there not the right ones guess they will! Also i gapped them to 0.44 they came out the box at 0.24.
    JPinFL likes this.
  14. Aug 2, 2017 at 11:23 AM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    Always check the gap when getting and installing new plugs. It takes 10 seconds, and can save you from a lot of headaches.
    A long time ago, the Toyota parts guy assured me they were gapped properly. I asked him if he could just double check anyway. "Don't need to. They're always spot on straight from the box." he says. I checked when I got home. Yeah...they were off.
    Dalandser likes this.
  15. Aug 2, 2017 at 2:53 PM
    #35
    austinsdad99
    1999 prerunner 3.4
    Yea i used to believe the "pre gapped" line too...but not all plugs are pre gapped. It took me maybe 15 min to gap them and that's both electrodes per plug.
