Misfire on cylinder one
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jaymes toy, Dec 14, 2011.
  1. Dec 14, 2011 at 6:30 PM
    Jaymes toy
    Jaymes toy [OP] New Member
    Colorado mountains
    2007 v6 4.0l
    Bobed flat bed 6in lift 3 body 35s on 15" wheels
    My dads 2007 Toyota Tacoma v6 4.0l is missing on cylinder one. Have replaced injectors plugs and have moved the wires around too it is only missing on cylinder one. Any advice.
  2. Dec 14, 2011 at 6:32 PM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    next would be to check coil pack and MAF sensor
  3. Dec 14, 2011 at 6:36 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Pull the plug for that cylinder. While it's out check the compression. If it's good, install new spark plug and swap coil packs with another cylinder. The miss should move to another cylinder if the coil pack is bad. Sounds like you've already eliminated the injectors. If there is no compression issue then maybe a wiring harness problem?
    What fault code are you getting? I think an open injector or coil pack will set a code?
  4. Dec 14, 2011 at 6:37 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    first of all u dont have plug wires on an 07???? confused? and a maf would effect more than one cylinder so thats not it
  5. Dec 16, 2011 at 11:39 AM
    Jaymes toy
    Colorado mountains
    2007 v6 4.0l
    P0500
    P0301
    P0031
    P0057
    These are the codes that come up.
  6. Dec 16, 2011 at 11:47 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Check the 10A EFI NO2 fuse.
