Misfire! P0306 - dropped valve seat!
Discussion in 'Performance and Tuning' started by Amo-cat3, Jul 10, 2021.
  1. Jul 10, 2021 at 1:30 PM
    Amo-cat3
    Amo-cat3 [OP] Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Need some help folks,
    Yesterday truck was driving normal and went to pull out on highway at about 3/4 throttle hit 60mph and lightly let off the gas and truck started shaking violently. Check engine light started blinking so pulled codes p0300(random misfire), p0305 and p0306 (cylinders 5/6 mifire).
    Got it towed home and just put in new spark plugs (NGK LFR7AIX-11/ 2309 supercharger approved) and swapped ingnition coils and still getting the same rough engine shake and misfire codes.
    Is it possible to blow the head gasket on both banks on the backside at the same time? Coolant is full in radiator and looks normal, and engine oil looks smells normal. Hopefull I can do a compression test with the supercharger in the way on the driver side. Any other suggestions?
    Here's the plugs from cylinders 5 and 6 they look normal not wet.
  2. Jul 10, 2021 at 2:14 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    You might start by swapping the coil packs around on the passenger side since theyre easier to access and see if the code follows. The plugs look okay to me
  3. Jul 10, 2021 at 2:16 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Forgot to mention that I did swap coils on both banks and misfire did not move so it seems coil packs are good.
  4. Jul 10, 2021 at 2:19 PM
    BassAckwards
    What are you using for tuning?
  5. Jul 10, 2021 at 2:21 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    running UCON last 3 years.
  6. Jul 10, 2021 at 3:30 PM
    BassAckwards
    You may do well doing a pressure test on the cooling system and a compression test as well. I was able to do a compression test with the blower on, on my truck. But anyways, i would be suspecting of the UCON if those both come back with passing tests. I had issues with the UCON on my truck at one point and it had to be replaced. I would start by trying to narrow it down one thing at a time though
    Amo-cat3[OP] likes this.
  7. Jul 10, 2021 at 4:38 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    How long did you run the ucon before it started giving issues? I assume you shipped it back to urd and they diagnosed it?
  8. Jul 10, 2021 at 6:12 PM
    BassAckwards
    I had issues from day one and i fought for 6 months to diagnose it with the help of urd and members on here. Finally narrowed it down to the ucon and then sent it to urd and they replaced it.
    b_r_o and Amo-cat3[QUOTED][OP] like this.
  9. Jul 10, 2021 at 6:14 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    I see, well I need to do a compression test and or leak down. Should I just skip the compression test and do a leak down? You have any tips to find top dead center?
  10. Jul 10, 2021 at 9:30 PM
    mulisharydr
    mulisharydr Well-Known Member
    johnny
    2015 black TRD Sport
    Magnuson s/c 2.85 URD stealth pulley Total chaos Lt front with king shocks Dmz fab rear spring under kit with kings triple bypass shocks Dmz fab bolt in bed cage King 4” hydro bump stops Harrop rear elocker 4.30 Detroit gears nfab light bar bumper mount with 40” lightbar relentless roof mount with 50" radius led lightbar bfg TA KO2 285/70/17 powdercoated black trd sport wheels flowmaster super 10 muffler. JBA Shorty headers. ratiotek shift kit.
    Had this happen to me, not too long ago, with cylinder 3, turned out to be injectors, I swapped injectors and it changed cylinders, hand it cleans and repairs by fic and still the same, finally replaced all my injectors with injector dynamics injectors and misfire gone, worth a shot to swap injectors and see if misfire changes cylinders
  11. Jul 10, 2021 at 9:56 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    compression test (cold throttle wide open ).......leak down ( cold 100psi ) test can tell U definitively very different issues
    Im NOT familiar with a ‘ UCON ‘ tune................the plugs shown are running rich
    any tune other than stock truly matters matched to the type o driving environs
    ( not sure why a tune was necessary )
    not sure IF most of Ur driving ............In town commute
    or mostly hi-way legal speeds
    wires + coil paks is where i would start
  12. Jul 10, 2021 at 11:36 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    After pressure test and leak down if everything checks out I’ll pull the blower and swap injectors. Funny my Depo fuel pressure gauge stopped working a month ago. It’s pegged at 47 psi. First depo guage lasted a year this replacement lasted 2. Don’t buy Depo guages:facepalm:
  13. Jul 11, 2021 at 11:43 AM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    UCON ALL DAY!!
    If you got 455 injectors then take out the Ucon and run the TRD Tune. Watch your problems disappear ;)
    Torspd and JustDSM like this.
  14. Jul 11, 2021 at 11:54 AM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Yes still using 455 injectors. After doing an injector swap I'll see, been running ucon 3 years no problem until now. Maybe upgrade to injector dynamics.
  15. Jul 11, 2021 at 12:53 PM
    TRON
    TRD injectors are pretty solid. You’re lucky the Ucon lasted that long with no problems
  16. Jul 11, 2021 at 12:59 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Ucon hardware or software issues? If injector swap doesn’t show anything - will try to send ucon in for diagnostics. Then look to TRD tune the ecu. Doing comp test and leak down tomorrow.
  17. Jul 12, 2021 at 5:22 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    :annoyed:UPDATE! After compression test and leak down test I’m screwed lol!
    0 compression on cylinder 6 and leak down test shows lots of air escaping out of the intake. We’ll see from here
  18. Jul 12, 2021 at 9:13 PM
    ROAD DOG
    FEW
    what does #6 plug look like
    zero =
    broken stud/bolt upper intake
    stuck or bent valve
    bad ring stack on piston ( not likely to hear intake side )
    bad head gasket ( maybe not likely )
    air escaping out o intake could be 1st 2.............nothing beats a tear down tho
  19. Jul 12, 2021 at 10:27 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Researching online for rebuilt head. Found ADV Cylinder heads in California. Going to reach out to them , will keep everyone posted.
    b_r_o likes this.
  20. Jul 13, 2021 at 5:55 PM
    ROAD DOG
    FEW
    U havent said whats wrong with the current head.......................
    what did U find ????????
